Currently, Aileron, elevator, throttle and rudder(because of the steerable nose gear). The 2nd throttle can only be channel 6(AUX) since channel 1 is normal throttle, ailerons are channel 2, 3 is elevator, 4 is rudder, 5 is unused because it is gear...this is a non proportional channel to the best of my knowledge...its on/off as far as I know), and channel 6(flaps or AUX). Horizon said to use channel six, hence the mix of C 1 6 +100. Kensp...the mixes for JR ase different, at least for the radios I am using. there is not a separate mix for 0-50, 50-100. There is the ability to set a mix of -100 to +100 on some mixes. Uisng two servos is fine to test things, but it doesnt really tell me what the motors are doing. I have everything wired up in the plane and can test what does what with the plane secured in place..at least this way, I know that at least one engine is actually starting and at what trim or stick setting. |
Well, heres a few more pics of plane....still not done...I wenty flying today and maidened another plane for most of the day(60 sized Graupner Extra 300S with twin cylinder Saito FA90-ts).
Note the elevator pushrods and how they are covered. I should have used short servos instead of the HS56HB since they are quite tall above the mount plates....but..I figured once these are in...theres no way to get them out so using Karbonite gears was better then plain plastic. |
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
I have yet to receive mine, however I'm wondering if anyone has access to a full size P-38 (in a local museum or something).
I'm mainly interested in the location of the navigation / anti-colission lights... ![]() EDIT --> Oh yeah, I need landing light location too...
rudedog,
I think the idea is to use diff thrust for steering INSTEAD of a nosewheel servo. That will help save some weight, and the expense of another servo. I have to say though, I really like the way mine handles on the ground. This is the best ground handling plane I own. I may try retracts soon too! ![]() Pat |
Latest blog entry: Nico Hobbies
Orange County, CA
Joined Feb 2002
I'm considering them for another project and would love to have someone else try them first! (-: |
Ken |
Thanks for the link! Pat |
[QUOTE=Fiasco]If you have two programmable mixes on your radio,
Mix 1: throttle master to rudder slave Mix 2: rudder master to throttle slave QUOTE] Not enough mixes for differential throttle. Requires 3. And yes, diff thrust is useable in the air, steerable nosewheel is not. I wanted to do it just to have some semblance of rudder for cross wind landings. |
I have test run my GWS-38s motors with the Differential Thrust working and it is ready for a test flight tomorrow morning.The total time taken to set the system up was about 15 minutes including the fault finding. The use of the two servos that allowed me to watch what was being mixed with what and how much was being mixed was a big help to me. See http://www.rcgroups.com/forums/showt...8&page=6&pp=15
Ken |
| Thread Tools | |
| Discussion Gws 二次大戰 名機 Gws-38 | GWS CHEN | Japan | 6 | Jan 01, 2007 10:36 AM |
| GWS-38 Twin Fighter | Randori | GWS (Grand Wing Servo) | 154 | Dec 13, 2006 02:35 PM |
| Discussion GWS-38 soon 廣營新的戰鬥機即將上市. | GWS CHEN | Taiwan | 15 | Dec 11, 2006 11:35 PM |
| New Product ****Must check GWS New Airplane GWS-38**** | RAY GWS | Product Announcements | 24 | Oct 25, 2006 11:21 PM |
| New Product GWS-38 (P-38 Lightning)... its here. | Blaze.45 | Hot Online Deals | 18 | Oct 05, 2006 12:39 PM |
