This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 20, 2006, 06:57 AM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Ken -- how do you get the computer printout to match the color of the paint? I have never been able to make it work!
Red 61 is offline Find More Posts by Red 61
Old Oct 20, 2006, 09:43 AM
Blaze.45 is offline
Find More Posts by Blaze.45
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Red, if you are moderately skilled with Adobe Photoshop... using CMYK settings on your document instead of default RGB will tremendously help with color matching.
CMYK was made for printing.
RGB was made for computer graphic art.
Although, a lot has to do with the settings and quality of your monitor for that.
-Chris
Blaze.45 is offline Find More Posts by Blaze.45
Old Oct 20, 2006, 10:49 AM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by Roger Lombard
I don't know what Windex is
It's a blue window cleaning fluid. I've heard that some of the soap agents in the window cleaner stuff help the paint flow more evenly as well as the alcohol evaporating quickly.
I used water last time and did OK. But even with the very low humidity here I had to be very careful to keep the coats thin so it didn't run.
rdeis is offline Find More Posts by rdeis
Old Oct 20, 2006, 11:15 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Originally Posted by kensp
I use a product called "Methylated Spirits" to thin my acrylic paint before airbrushing. "Methylated Spirits" is a mixture of 95% ethanol with 5% methanol added so that it is undrinkable without a person becoming sick. ........
Ken
Not if you add plenty of tonic water.
JOKE - DO NOT TRY THIS AT HOME
Roger Lombard is offline Find More Posts by Roger Lombard
Old Oct 20, 2006, 03:14 PM
mtbrider is offline
Find More Posts by mtbrider
Ay up it's warped
mtbrider's Avatar
Derbyshire UK
Joined Feb 2003
Meths used to be a tramps special, "blue". The cider is so cheap now they do not bother any more with it, except perhaps Roger
mtbrider is offline Find More Posts by mtbrider
Old Oct 20, 2006, 03:53 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Roger...do they have Formula 409 over there? Its also a cleaner in a bottle and comes in a few colors(red being the original). Windex is simply a brand name for a glass cleaner. I am sure they have bottled glass cleaner in the UK, yes? Any glass cleaner solution will have the same effect as Windex. Windex is just formulated to not leave any streaks on glass when you are wiping it off.
kahloq is offline Find More Posts by kahloq
Old Oct 20, 2006, 04:18 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
For anyone that wasn't sure how to set up differential thrust on a twin and they want to do that instead of retrofitting functional rudders, here is a quick simple guide(this assumes you are using a JR or Spektrum radio as the throttle channel is number 1, rudder is number 4 and AUX is 6). If using Futaba or Hitec or whatever, simply repalce the correct channel number for the desired function...so if your radio has channel 4 as throttle...input that into the spot of number 1 on the instructions below and do same with rudder and AUX. 7 channel plus radios have more then 1 AUX channel, so you should be able to utilize whichever one you want that isn't used as non-proportional. Anyhow...here goes:
Here is how to set this mix up(this comes form Horizon)
Mix A is 4 1 with moving the stick in each direction to +100.
Mix B is 4 6 -100 both ways.
Mix C is 1 6 +100
This will slow one engine down to effect the plane and make it turn. This can be set up much more advanced style if you wish and can designate a percentage of throttle response to initate the desired direction change on some mid-to-higher end radios as well as limit at what throttle range this diff. thrust can be used at. The Jr 9303 actually has differential thrust preprogrammed as a mix, so its a matter of activating it somehow(I dont have 9303 so i dont know how to do that).
Old Oct 20, 2006, 04:45 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Red
I use Photoimpression 3 to select my colours and test print on paper. If its wrong then I use another colour on the pallate, an so on unill its the right colour. Then to get a final match I can change the paint colour slightly by varying the paint mix.
The GWS Aeroplanes are not exact scale so we need not have the exact shade of colour that the full sized had.
Ken
kensp is offline Find More Posts by kensp
Old Oct 20, 2006, 05:00 PM
rudedog is offline
Find More Posts by rudedog
CAN WE MAKE IT FLY?????
rudedog's Avatar
Concord,N.C.
Joined Oct 2003
well guys I'm a cheapy, I've almost always used Testors outta the can.......go figure
rudedog is offline Find More Posts by rudedog
Old Oct 20, 2006, 10:25 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
I've used Model Masters spray on all GWS planes
Old Oct 21, 2006, 07:39 AM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
A couple of aerial shots of mine from yesterday. Really enjoying flying this bird! Seemed to be a hit with the boys out at the field.
J
Jagzilla is offline Find More Posts by Jagzilla
Old Oct 21, 2006, 09:28 AM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Nice pics! Really like the second one. 8^)
Art Newland is offline Find More Posts by Art Newland
Old Oct 21, 2006, 01:20 PM
RAY GWS is offline
Find More Posts by RAY GWS
Joined Jul 2004
I second.
Very nice.
RAY GWS is offline Find More Posts by RAY GWS
Old Oct 21, 2006, 01:29 PM
Red 61 is offline
Outcast outlaw
Joined Aug 2004
I third the second.
Old Oct 21, 2006, 11:32 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Thought I'd share a few pics of what I am doing with mine as I build it. I decided to put the esc's in the booms since the cockpit area is so cramped. I cut a hole in the side of the boom and put a reverse airscoop over it for an air exit and drilled a decent sized hole through the front for air intake(see pics). Also, I installed servos in the booms where the radiator scoops are placed(one on each boom on the inside facing halves). These will be used as elevator servos. Yes, I am using two servos...one on each end of the elev. This will allow me to later add a rudder if I so choose and use 1 for elevator, so I had to install the servo anyhow and might as well use it for now. I will not mess with making functional rudders if differntail thrust is good enough.
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
