This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 17, 2006, 09:20 AM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Originally Posted by Red 61
I like how his GWS-38 performed, but I'm not willing to spend 30 amps on it! I need something more efficient...
With decent cooling a TP 2100 PL will give you 30A "all day long" so to speak.
Besides your not going to be at WOT for the entire flight... right?
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old Oct 17, 2006, 12:28 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Ok just did static watt and amp tests on both motors.
Park 370 outrunners(1080kv)
Motor 1 with MAS 9x7x3 tractor prop:
static WOT
13.8 amps
151 watts
3/4 throttle
7.9 amps
85 watts
1/2 throttle
3.6 amps
58 watts
Motor 2 with MAS 9x7x3 pusher prop:
static WOT
13.7 amps
149 watts
3/4 throttle
7.8 amps
86 watts
1/2 throttle
3.6 amps
58 watts
These will do nicely. Yes, at WOT, the amps and watts are a little high for the motors, but, normal flying will not be at full throttle and cruising speed 1/2-3/4 is well below the max specs of the motor....plus they will unload in the air some. Even at full throttle, total amps is 27.5...so no problems with a TP 2100 3s. However.....both motors were run separately for the tests, running them both together will probably give slightly different results....with the amp draw on each motor being a little lower. Best guess will be around 12 amps per motor at WOT...but will test this to be sure once plane is together. I base this off of tests done with other setups using twin motors I have(aka FSK B-25).
Anyhow...if get 150 watts per motor at WOT...this gives me 300 watts...enough for a 3 pound plane using 100 watts per pound. There's no way this plane will weight in at 48 oz though, so I will have better then scale speed capability...not that I am trying for this...but extra breathing room is good.
kahloq is offline Find More Posts by kahloq
Old Oct 17, 2006, 03:20 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
kahloq
During my initial testing of a GWS 2208 motor on 2 cells and 9 x 7.5 HD propellers, the motor drew 7.12 amps on a 1200 mAh battery and short leads.
When installed two motor in the GWS-38 on a 2 cell 1800 mAh battery and using 9 x 7.5 HD propellers they drew a combined current of 12 amps. I put this a lot of this amp draw reduction down to the fact that the leads from the ESCs to the motors are 12 inches long and their resistamnce is a big part of the cause of the drop in the current draw.
No matter where you mount your ESCs there will be a resitance in the long length of leads between the battery and motors so I would say that you will get a similar % drop in current draw.
kensp is offline Find More Posts by kensp
Old Oct 17, 2006, 06:26 PM
Bthree is offline
Find More Posts by Bthree
NW Victoria Australia
Joined Sep 2003
Originally Posted by kensp
kahloq
The highest voltage drop will be in the internal resistance of the battery being typically 0.06ohm to 0.1ohm for a two cell and 0.1ohm to 0.15ohm for three cell ...... eg:0.1ohm x 20amps = 2volts drop internlly in the battery
This is were the 20C+ discharge cells win, they have low internal resistance but are heavier
Bthree is offline Find More Posts by Bthree
Old Oct 17, 2006, 07:00 PM
Jagzilla is offline
Find More Posts by Jagzilla
I fly for Beer
Jagzilla's Avatar
Chilliwack, B.C. Canada
Joined Sep 2004
Did the maiden of mine today. Two 6 minute sorties, no disasters! No probs on the handlaunch, and with just a bit of up trim on the elevator, all was well. Flies a bit slower than I would have liked, but I knew I was giving up a fair bit by going with the GWS 9070 3 blade props. Wouldn't go so far as to call it a floater, but it slowed down a fair bit before stall. Two nice belly landings, and the 3 blade props are still 3 blade props. Battery not overly hot, quite acceptable. I put my cog at 80 mm. I'll leave it there, it seems about right for me.
One thing I wasn't expecting is orientation issues. My plane is all silver, and because of the shape of the plane, and being all one color.....wow, you could loose this one easily! I'm not sure I'd want to fly this one too far out down the field.
Anyway, it flies nice and it definitely is a nice addition to the squadron. I'll post some pics another time after I have put the decals on.
J
Jagzilla is offline Find More Posts by Jagzilla
Old Oct 17, 2006, 08:19 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
When a static test is carried out using a battery for a power supply and the current is determined to be X then internal resistance of the battery has been taken into account.
Using a larger capacity battery for two motors lowers the internal resistance of the battery used.
So in my case of the two motors mounted in the GWS-38 with a larger capacity battery, a large part of the 15% less current will be on account of the increased resistance of the longer connecting wire.
I was just giving kahloq an example of the changes that will occur in a real life GWS-38 power unit instalation.
Ken
Old Oct 17, 2006, 10:22 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Congrats J! I know of the orientation problem. Since my first flights were unpainted, the all white airframe made orientation interesting. Needless to say the plane always stayed in close.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Oct 17, 2006, 11:32 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Pat
Pat my next flight is gona be intresing.
Ken
Old Oct 18, 2006, 03:47 AM
rudedog is offline
Find More Posts by rudedog
CAN WE MAKE IT FLY?????
rudedog's Avatar
Concord,N.C.
Joined Oct 2003
Looks good Ken
rudedog is offline Find More Posts by rudedog
Old Oct 18, 2006, 06:03 PM
Jagzilla is offline
I fly for Beer
Jagzilla's Avatar
Joined Sep 2004
Got the camera out for mine today. You'll have to pardon the two different spinners, the starboard side one is just on temp. for the photos. I'm still waiting on my mail order for my other three blade GWS spinner.
Hope you like it.
J
Old Oct 18, 2006, 06:30 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Finaly, the painting is finished and the marking are all put on the aeroplane. I am quite happy with it.
Ken
Old Oct 18, 2006, 06:38 PM
Jagzilla is offline
I fly for Beer
Jagzilla's Avatar
Joined Sep 2004
She turned out very nicely, Ken. Good choice on the scheme.
J
Old Oct 18, 2006, 07:10 PM
Tommy D is offline
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Topnotch Jag! Nice Pinup!!
Old Oct 18, 2006, 07:18 PM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
speaking of nice pinup...where is the pic you wanted turned into a decal?
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Oct 18, 2006, 07:23 PM
rudedog is offline
rudedog's Avatar
Concord,N.C.
Joined Oct 2003
Here's my nose art... looking good guys like those schemes
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
