This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 07, 2006, 02:26 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Originally Posted by Smokin' Beaver
Ken, the question now is - will the P-38 fit?
Phil
Phil
No problems. I am lucky my family is grown up and now supply their own transport.
Ken
kensp is offline Find More Posts by kensp
Old Oct 07, 2006, 05:37 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Ahh...Beautiful....
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Oct 07, 2006, 12:07 PM
yancovitch is offline
Find More Posts by yancovitch
Joined Oct 2006
whats this about a new foam for the p38? if so, will it be used on all the planes?
yancovitch is offline Find More Posts by yancovitch
Old Oct 07, 2006, 12:19 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
yan
The "new foam" so far has only shown up on the horizontal stab of the GWS38. The rest of the foam is tryical of GWS. Not being over there, it looks like the rest of the plane was injection molded and the stab is sort of done in a hot press. The surface is very smooth and hard. If you have sen the wings of a Scorpio, that is what they are like.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Oct 07, 2006, 12:22 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
I'm about 75% finished on the build. Since I missed the rush to fly "first out of the box" (damn work!) I'm going to complete the build and then do a WBPU/tissue glass job. I'll post it here in the GWS forum area.
Jim
Old Oct 07, 2006, 11:53 PM
ParkJeff is offline
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Originally Posted by jamesdr
... it looks like the rest of the plane was injection molded and the stab is sort of done in a hot press. The surface is very smooth and hard. If you have sen the wings of a Scorpio, that is what they are like.Jim
Sort of like depron?
Look forward to your results of glassing the 38. I was hoping to do the same but have heard that weight might be an issue even without. I'm still waiting for one to land at a shop near me so all I know is hearsay at the moment.
Jeff
ParkJeff is offline Find More Posts by ParkJeff
Old Oct 08, 2006, 01:30 AM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
More like molded depron. See the attached photo.
I have test mounted some TowerPro 2409-12s. With the mount pushed all the way back, I'm getting about 1/4" gap between the front of the cowl and the back of the spinner. It's livable but I need to see if I can do better.
Jim
Old Oct 08, 2006, 02:36 AM
Bthree is offline
Find More Posts by Bthree
NW Victoria Australia
Joined Sep 2003
Jim
Easy, cut 1/4' off the back of the plastic stick mount, will still be strong enough.
Bthree is offline Find More Posts by Bthree
Old Oct 08, 2006, 11:27 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Chen from GWS Just posted this!
Both A gears and B ones have been tested well on it. I'd like to state this link for your reference,
http://www.gwsus.com/english/product...em/eps350c.htm
My Chinese colleague applied EPS350C-B on it, while colleague in
Taiwan applied EPS350C-A instead. The manual and spec. were
written by my colleague in GWS China.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Oct 08, 2006, 02:55 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
jamesdr, I have the same problem. Up close, the gap looks unnatural. But in the air, you can't tell. And yes, the tail looks like molded depron.
Bthree, good idea! I'll see how I wind up once I switch to BL motors.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Oct 08, 2006, 06:16 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Pat
If you use the GWS GWEMM28T mount, the 2208 motors with shaft reversed and GWS 9 x 5 Propellers then the gap will be 2.5 mm.
Ken
Old Oct 08, 2006, 06:44 PM
Scoobyvroom is offline
Find More Posts by Scoobyvroom
Jack of all trades!
Scoobyvroom's Avatar
Rockford, MN
Joined Jul 2003
James do you happen to have any numbers for the 12s you are running I have the 9s and I am having problems with excess heat..
Chris
Scoobyvroom is offline Find More Posts by Scoobyvroom
Old Oct 08, 2006, 07:07 PM
Bthree is offline
Joined Sep 2003
Chris, if you are referring to the BM2410-09Y
Did a complete test run on this motor and a towerpro 25A controller
Results came out exactly per aero-nuts data sheet
EP9070 10.45v @7.5A = 78W Temp 70degC @ 5400rpm
hot but quite flyable
EP1080 10.1v @9.5A = 96W Temp 90degC @4400rpm
clearly too hot and literally smoking
So they are good for about 80watts, smokes at 90watts, and demagnetises at appox 100degC
Old Oct 08, 2006, 09:22 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Chris
For Motocalc, I use 1570KV, 1.2A no-load, 0.22 resistance and 2.1 oz. I will be using an 8x4 APCe to start on there. I have the same motor/prop on my GWS Corsair and have not had any problems with heat. I ordered an Eagletree data logger and it will be here this week. I will be able to get some in-flight numbers for that motor next weekend.
Jim
Old Oct 09, 2006, 08:11 AM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Thanks Chen
I guess I'm Limited because i want to use a 2S Li-Po to save weight.
Merlin
MERLIN V16 is offline Find More Posts by MERLIN V16
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
