This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Sep 09, 2006, 06:55 PM
dogon1013 is offline
Find More Posts by dogon1013
Watts Rule, Glows Drool
dogon1013's Avatar
orlando, FL
Joined Mar 2003
i suspect that's the issue, they claimed to have them on order for quite a while.
dogon1013 is offline Find More Posts by dogon1013
Old Sep 09, 2006, 09:27 PM
cincy is offline
Find More Posts by cincy
Plane Crazy
cincy's Avatar
Cincinnati, OH
Joined Feb 2003
2208-18T Numbers
Originally Posted by kensp
I have just purchased two 2208s but I also have a Matched Pair of 2205s that I am thinking of trying. Here are the test results for the best propellers. The 7 x 5 APC seems to be the best one.
Ken
I have some of these coming too. If you get a chance to post your numbers on them that would be awesome.
cincy is offline Find More Posts by cincy
Old Sep 10, 2006, 03:58 PM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
I got some amp measurements on the 2208 on 3S.
with the GWS HD 1060 it pulled 11.5amps
with the APC 8*8E prop it pulled about the same, 11.7amps
that's about the max suggested for the motor and it did get hot pretty quick.
Old Sep 10, 2006, 04:39 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
This is the results I got, on the 2208-18T when using the GWS 8 x 6 HD on 3 cells.
GWS 8 x 6 HD Propeller
8.68.....Amps
10.96...Volts
452.....grams thrust
16.14...oz thrust
8,000...RPM
95......Watts
45.45..MPH pitch speed
Pleanty of thrust and pitch speed and well within the 120 Watt power limit.
Ken
kensp is offline Find More Posts by kensp
Old Sep 10, 2006, 08:27 PM
denial15 is online now
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
Would an APC 8x6 perform similar to the GWS 8x6HD?
denial15 is online now Find More Posts by denial15
Old Sep 10, 2006, 09:05 PM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
I do not have an APC 8 x 6 to test but I asume that the results would be similar. There is one problem however. APC recomend a maximum of 8125 RPM for the 8 x 6 Slowfly propeller and with unloading in flight the combination would probably exceed that. It would be best to use the APC 8 x 6 EP Propeller
Ken
Old Sep 11, 2006, 08:49 AM
L0stS0ul is offline
Find More Posts by L0stS0ul
Ship first, Improve often
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Just got the payment information from GWS. Looks like they are ready to ship out the kits. Anyone know if that fax number they give to authorize payment is toll free or not? I was expecting paypal or something like that not having to fax the information.
L0stS0ul is offline Find More Posts by L0stS0ul
Old Sep 11, 2006, 09:24 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Same here - I did the same thing you probably did and ask how to make payment. GWS asked for a credit card and I am hesitant to send it out via e-mail.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Sep 11, 2006, 10:04 AM
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Your most likely going to pull more amps with the APC over the GWS but you might get a slight performace bump.
Make sure you check it with an amp meter either way.
Vintauri is online now Find More Posts by Vintauri
Old Sep 11, 2006, 11:53 AM
dogon1013's Avatar
orlando, FL
Joined Mar 2003
It doesn't look toll free to me. I think the 886 is the country code
Old Sep 11, 2006, 12:18 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I had my wife forward me the email from home. I filled out the CC form, and I bet we can just scan them and send them back via email instead of faxing. I will ask Joyce to see if we can do this.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Sep 11, 2006, 12:29 PM
MN WATTS Master
Vintauri's Avatar
Joined Jul 2003
Pat
Wow your a daring individual. E-mail is one of the easiest things to steal over the internet. I'd recommend not doing that if I were you.
GWS should be able to setup a secure page to let users input the information.
Old Sep 11, 2006, 12:32 PM
L0stS0ul is offline
L0stS0ul's Avatar
Virginia
Joined Apr 2005
Well I asked my HR person here how to fax internationally and was told to just put 011 in front of the country code. I tried that with the first number that Joyce gave and I listened to it go through and talk to something and send the pages but then when it came back I got a BUSY/NO RESPONCE return code from my fax machine
sucks.
Our lady here recommended if possible to use our copier to create a pdf to send. It's like 2 am in Taiwan though so I doubt we will hear anything till later. Would like to know if my fax went through but I doubt it did. I hate faxing. would be nice if GWS could set up a paypal account and send us all invoices
Old Sep 11, 2006, 12:53 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
GWS Chen PM'ed and said GWS would support essentially a split transaction where
"you could fax the credit card form with the essential informations partially filled to GWS, then send your e-mail with the rest of informations to GWS account. Your name, address and The Authorized Amount could not be filled up partially, and you'd need to state your full name on your mail enabling GWS to identify these deals respectively." A little kludgy but if you are a modeler, a kludge is part of the game.
Jim
Old Sep 11, 2006, 01:34 PM
L0stS0ul is offline
L0stS0ul's Avatar
Virginia
Joined Apr 2005
I finally got a fax to go thru. had to use the second number she gave. The first one did not respond. Chen told me the same thing. I was already having the connection fee and being charged for a minute anyway so made since to just send both pages
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
