This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Feb 28, 2011, 07:20 AM
JMAH is offline
Find More Posts by JMAH
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Originally Posted by 1Radioflyer View Post
...Blessings!
Jay
Thanks, Jay. You, too!
I also need to find a couple of those Dubro spinners like you have. It's going to look pretty sad when it maidens with no nose cone, only one cowl, and no spinners!
Jeff
JMAH is offline Find More Posts by JMAH
Old Mar 04, 2011, 06:06 AM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Still not all that happy with the performance. The 9050x3 props look good, but they just didn't produce the kind of speed that I'd like to have (a Lightning shouldn't be the slowest warbird at the field...that just ain't right, right?)
It was a pretty efficient set-up, though. A 6+ minute flight used less than 1000mAh from the 2250 battery.
Switching to 1060 props yielded better speed, but it was a little too windy to really put the thing through its paces. Seems sluggish aerobatically but it was getting knocked around pretty good yesterday afternoon.
Jeff
Old Mar 04, 2011, 08:36 AM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
You might try a 9*6. You will drop a bit on thrust but could pick-up some prop speed with the smaller blade. As long as you under 70oz weight, you should be OK.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Mar 05, 2011, 12:08 AM
Gene is offline
Find More Posts by Gene
United States, CA, Anaheim
Joined Aug 1999
For flight, get rid of the three bladed props. They just don't perform like a two bladed prop. They look cool but you pay for it in flight performance. Sorry, that's how it is.
Gene is offline Find More Posts by Gene
Old Mar 05, 2011, 01:01 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Absolutely get rid of those 3 bladed props. Go with the APC 9x6E props or even counter rotating 8x6E props. How many amps are your ESCs rated for?
Kevin.
RCDad is offline Find More Posts by RCDad
Old Mar 05, 2011, 06:46 AM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Kevin.
Yep, the three-bladers are gone. My ESCs are rated for 30A. We also have a few 9075s lying about that I might try...
Old Mar 05, 2011, 11:38 AM
Gene is offline
Joined Aug 1999
I use the GWS DD 9070 and they work fine. 9075's will draw a little more amps and give you less flight time, but if your ESC's are rated at 30 amps give it a shot. I use Castle Creations Phoenix 25 amp on mine. I use an ESC for each motor with a Park BEC in the final "plug-in" at the receiver. If you're comparing the speed of your P-38 to other models at the field, remember that most people are not flying their models at a "scale" speed. Some of them are doing F-18 speeds in WW2 airplanes.
Old Mar 05, 2011, 12:57 PM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
...If you're comparing the speed of your P-38 to other models at the field, remember that most people are not flying their models at a "scale" speed. Some of them are doing F-18 speeds in WW2 airplanes...
You're spot on, Gene! We have a severe problem with non-scale speeds around our home field.
And since it's my son and brother-in-law that I fly with, I really don't see how I can pass up tussling with them at similar speeds! Can't bear the shame around the dinner table of being constantly humiliated in our aerial battles...
Jeff
Old Mar 05, 2011, 01:51 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Jeff
Hey now hold on there! My P-38 is slower than yours already and I'm going more toward scale speeds now anyway. HH is a lost cause when it comes to scale speed and mock dogfights. We need to make sure he has the slowest plane so he can't just fly straight up or do his famous 3' loop! Now thats scale!
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Mar 05, 2011, 11:11 PM
RCDad is offline
Bay Area
Joined Feb 2004
Sorry guys, but for this application I do not like GWS props. They do not hold their shape well in the air at speed and will even break if you really push them. Breaking a prop in flight could spell disaster for a twin.
Kevin.
[QUOTE=Gene;17593303]I use the GWS DD 9070 and they work fine.QUOTE]
Old Mar 07, 2011, 04:39 PM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
The 9075 props worked out really well. I ran about 7 minute flights and took 1000 mAh out of the first battery and 1300 out of the second. It isn't going to set any speed records at the home 'drome, but at least it's starting to fly faster than DoubleH's Cub!
Fiberglass reinforcements on the boom-tail joint worked well also. I tried to make the (belly) landings as smooth as I could, and it came home intact. And that's rare for me with this plane!
Old Mar 07, 2011, 10:54 PM
SMRTIC is offline
Find More Posts by SMRTIC
SMRTIC's Avatar
Joined Jan 2007
Finally my GWS P-38 is done! Completely fiberglassed and Callie Graphics made the decals for me. I've always wanted to build a model of this P-38. Hopefully the weather will give me a chance to maiden it soon.
SMRTIC is offline Find More Posts by SMRTIC
Old Mar 08, 2011, 07:31 AM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
The Lightning looks great, Bill! Did you ever post details about your motor/ESC/prop setup?
Jeff
Old Mar 08, 2011, 08:34 AM
1Radioflyer is offline
Find More Posts by 1Radioflyer
Luvin' Life
1Radioflyer's Avatar
United States, MI, Portage
Joined Apr 2007
That looks beautiful!
1Radioflyer is offline Find More Posts by 1Radioflyer
Old Mar 08, 2011, 04:44 PM
RCDad is offline
Bay Area
Joined Feb 2004
Gorgeous P-38 SMRTIC! What did the AUW come out to? What mtors and battery are you using?
Kevin.
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
