This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Feb 05, 2011, 12:59 PM
dLdV is offline
Find More Posts by dLdV
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Originally Posted by SMRTIC View Post
I'm in the process of finishing out another GWS P-38. I've debated whether or not to add functional rudders. I plan on hand launching my P-38, so I don't need them to assist in directional control on the ground. The only benefit I can see is having them to assist in an engine out situation, but I don't think it would be enough to compensate for the drag of a freewheeling prop on a dead motor. What's everyone else's opinion?
I had 3 crahes from a bad battery, where LVC would cut one motor before the other. On the third crash I finally saw what was happening and found the cause. At any rate, the plane immediately dropped a wing and then plummeted straight down, almost a right angle event. Ailerons and elevator were completely ineffective, no response at all. I don't believe a rudder would've worked either.
In other words, it was no longer flying, just an object falling out of the sky.
dLdV is offline Find More Posts by dLdV
Old Feb 05, 2011, 01:08 PM
jbc is offline
jbc
Find More Posts by jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
Some info that may help others if you feel your 38 comes in a little hot then mix in flaperons and it makes a MASSIVE difference to this airframe, I did this with mine as I felt it was landing slightly quicker than I wanted (needed speed or would stall on approach) it also maybe because I use a slightly heavier non stock 4S power system. But anyway I mixed in flaperons and WOW what a difference, she now literally floats down at less than half the speed she used to
jbc is offline Find More Posts by jbc
Old Feb 05, 2011, 01:16 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
Originally Posted by jbc View Post
Some info that may help others if you feel your 38 comes in a little hot then mix in flaperons and it makes a MASSIVE difference I did this with mine as I felt it was landing slightly quicker than I wanted (needed speed or would stall on approach) it also maybe because I use a slightly heavier non stock 4S power system. But anyway I mixed in flaperons and WOW what a difference, she now literally floats down at less than half the speed she used to
Thanks for the advice, I'll have to give it a try.
On a related note, I was forever fixing the front landing gear, every 2 or 3 landings. If you have a heavy setup and land on grass, the DuBro 1/2A front landing gear is a good mod. I made mine slightly longer than stock. It hits the ground first and springs up for a gentle hop. I like that, myself, but you may not.
Posted before, but like the mod so much, gotta post again. Credit username RedLite for the idea.
Old Feb 05, 2011, 05:03 PM
Gene is online now
Find More Posts by Gene
United States, CA, Anaheim
Joined Aug 1999
SMRTIC, I think you're right about the rudders not having enough effect to control the plane if one motor goes out. I have had a motor go out in a different twin but they were brushed motors and the reason it quit was it just wore out and stopped. I've never had a brushless motor go out in my P-38's, but that doesn't mean it won't happen some day. It could happen from one of the motor wires coming unplugged or even a speed controller going out. If it does happen and you have altitude, your best bet is to just throttle back and land it. On my brushed motor situation, it was a Twinstar with two Speed 400 motors. The Twinstar is a high wing, stable, relatively slower flyer. All it did was slow down. I knew something was wrong, so I just landed it.
Gene is online now Find More Posts by Gene
Old Feb 05, 2011, 05:10 PM
Gene is online now
Joined Aug 1999
dLdv, great idea on the nose gear. The factory set is a little weak. I'll have to try that on my next build.
Old Feb 05, 2011, 05:24 PM
dLdV is offline
dLdV's Avatar
Joined Dec 2007
As long as the former is mounted strong, you won't regret it, I promise. So far all good flights and good landings, and it taxis a hex of a lot better. Real happy with that mod. The set is only $6 or so. You may want to get an extra wheel collar if you put the steering arm below the plastic mount. I just have shrink tube holding it in, but zero problems with that.
Old Feb 05, 2011, 08:23 PM
JMAH is offline
Find More Posts by JMAH
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
I modded mine with functional rudders, mostly because I couldn't stand the looks of the oversized ailerons that GWS intended. I cut the ailerons down to scale size and added the rudders for aerodynamic effectiveness for coordinated turning and aerobatics.
In my engine-out experience, it made no difference to have the rudders. The motor seized up, the prop didn't even windmill, and she rolled into a low altitude spin in a hurry.
Plus, it was just a fun project to make them work!
Jeff
JMAH is offline Find More Posts by JMAH
Old Feb 06, 2011, 03:44 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I adopted a two pronged approach to an engine out situation with my P-38. Firstly I made operating rudders. Secondly I got rid of the high thrust 3 blade propellers and changed to high pitch 2 blade propellers. These have less thrust and this means that the rudders have a chance of overcoming the offset thrust of an engine out situation.
Ken
kensp is offline Find More Posts by kensp
Old Feb 10, 2011, 07:45 PM
1Radioflyer is offline
Find More Posts by 1Radioflyer
Luvin' Life
1Radioflyer's Avatar
United States, MI, Portage
Joined Apr 2007
Originally Posted by JMAH View Post
...by crashing it in a field!
I thought I noticed that one motor turned slower than the other, but ignored that as irrelevant. This afternoon, DoubleH and I tried to get in a quick flight before supper to test out my last repairs.
Turns out the motor issue wasn't irrelevant. On a fly-by it started making a nasty screeching noise, followed by the prop coming to a standstill.
My attempt to maneuver to an emergency landing resulted in a spin and ground impact. Pretty much every component on the plane is broken except the boom-tail joint I repaired last week!
Call the carbon-fiber company. We're gonna need some spars!
(Also call HeadsUpRC. The GWS motors are going away.)
Jeff
Jeff,
Sorry to see the result off these crummy GWS motors. I just recently picked up the P-38 with brushless motors. After removing the motors from the plastic I found them "knotchy" when turning them by hand. One wouldn't even turn at times. I took them apart and found metal filling the can. The outer magnets are so poorly made that they fall apart and jam the motor.
I went with twin E-Flite park 400's and Castle 18amp ESC with separate BEC.
I saw a lighting on here I loved in yellow so I went with that scheme
I hope she flies well when the weather warms up
This has been my on and off winter project and I love the way it has turned out.
Blessings Y'all,
Jay
1Radioflyer is offline Find More Posts by 1Radioflyer
Old Feb 11, 2011, 07:15 AM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Originally Posted by 1Radioflyer View Post
...After removing the motors from the plastic I found them "knotchy" when turning them by hand. One wouldn't even turn at times. I took them apart and found metal filling the can. The outer magnets are so poorly made that they fall apart and jam the motor...
Blessings Y'all,
Jay
Your experience sounds eerily familiar! I've not taken the seized motor apart yet, but when turning it by hand it feels like it has rocks in it!
Your lightning looks great. What spinners and props are you using?
And very nice application of "y'all"--we southerners appreciate that!
Jeff
Old Feb 11, 2011, 05:35 PM
Luvin' Life
Joined Apr 2007
Hey Jeff,
The spinners are Dubro 2" 3 blade cat# 541.
The props are Master Airscrew 8x6x3's. One is a pusher and the other in a regular.
I have 2 blade APC 9x6's also one pusher on regular.
I'm wondering if the 3 blades will belly land OK or if they'll grab.
Blessings!
Jay
Old Feb 11, 2011, 06:51 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Hey Jeff,
Blessings!
Jay
Never had a problem belly flopping with 3 bladers. I agree w/ Jeff, nice plane.
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Feb 22, 2011, 07:53 PM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Motors on the way
I finally broke down and ordered two PowerUp 450 Sports to replace the failed GWS motors. Package is in the mail, so they say.
I'm hoping the weather will cooperate and there will be a flight report by the beginning of next week!
It'll be ugly as I still haven't replaced the smashed nose of the center gondola. Need to find a piece of foam to glue on and form into a new one. I don't see putting one of those flimsy plastic GWS ones back on it.
Jeff
Old Feb 27, 2011, 08:14 PM
JMAH is offline
2 Cor 5.21
JMAH's Avatar
Tennessee
Joined Jul 2009
Motors are installed and rarin' to go (naturally the weather isn't cooperating in the least--high winds, thunderstorms, etc...maybe Tuesday).
But we did power it up, and it felt powerful. Like it could be real fast. Flight report to follow, hopefully sooner rather than later.
Jeff
Old Feb 27, 2011, 08:54 PM
Luvin' Life
Joined Apr 2007
Jeff,
I pray the best on the next flight! The weather here hasn't been flight friendly either.
Blessings!
Jay
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
