This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Sep 12, 2010, 01:29 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
Guys,
Anyone have a super fast hobby king setup for the P-38?
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Sep 12, 2010, 01:35 PM
angelfood is offline
Find More Posts by angelfood
Joined Sep 2009
Contact Jeff at headsuprc.com: that's where I got mine, and it's cheap!
angelfood is offline Find More Posts by angelfood
Reply With Quote  (Disabled)
Old Sep 12, 2010, 01:48 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Originally Posted by Fidy$Trainer View Post
Guys,
TP 2410-12 delta with GWS 10x6 props super simple 20 amp esc and a 3s 2200. About $30 total for motors and esc's. Look on youtube under my screen name here to se e mine fly.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Sep 12, 2010, 04:11 PM
jbc is offline
jbc
Find More Posts by jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
I sort agree with Carrera above but I'm not sure if his was a typo as I would go with the TP 2409-12T not the 2410. The 09 is rated much higher than the 10, I've seen the 09 in a twin boom ME109 running 2x1000 3S in parallel with 8x4 props and it was pretty quick, only a shade slower than my 4S 600W p38. For more speed you can run a 7x6 or 8x8 just watch your amps. Seeing as this plane likes to be nose heavy, you can run your esc's in the booms hidden beneath the intakes, acts as counter balance without adding dead weight. You can use these towerpro 40A I used them in a Stryker for ages which pulled a constant 40A and the esc never had a problem, they're only $10 and probably one of the best 3S 40 ESC's I've used. Bang for buck you won't beat this setup, well over 400watts! Also don't try save a couple bucks by using the Turnigy equivalent brand bell motors which claim to be the same, they're not. I've had both and the turnigy died, replaced with the towerpro in the same setup and it's still going plus towerpro is rated a little higher. The only down side is the shafts can be a little weak but they're cheap enough, easy to change and HK carry them. Hope this helps, keep us posted how ya go....
John
http://hobbyking.com/hobbycity/store...unner_2409-12T
http://hobbyking.com/hobbycity/store...ed_Controller_
jbc is offline Find More Posts by jbc
Old Sep 12, 2010, 05:09 PM
jamesdr is online now
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
I've run the 2409-12's in my P-38 - very fast. And also in my smaller GWS warbirds. The caution is that thses motors are REALLY hungry - ~200 watts per and they will kill a battery unless you size one correctly. You can also get the Turnigy 2409 version for $6 < http://hobbyking.com/hobbycity/store...idproduct=6614 >
Jim
jamesdr is online now Find More Posts by jamesdr
Old Sep 12, 2010, 07:10 PM
Joined Jan 2004
No, I meant the TP2410-12 delta. I'll have to give the TP2409-12 a try.
Old Sep 12, 2010, 07:12 PM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
in reno right now....
Eljimb0 is offline Find More Posts by Eljimb0
Old Sep 12, 2010, 07:15 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Jim
Jim not worth getting the turnigy, I was warned to spend the WHOLE extra $3 to get the towerpro and didn't listen and my turnigy died DOH!, ....then went and got the towerpro...still going strong
Old Sep 14, 2010, 06:46 PM
USA, GA, Atlanta
Joined Sep 2008
Can you tell me what motor's your running to get 600w? I'm assuming that's validated against a watt meter or some other device? The motor's you listed below are only rated at 200 and I'm sure they probabbly over rated at that? I'd love to go for 600W+ I've got a 600W+ GWS 190 with a 35-42 1250kv and that motor is HUGE compared to 2409.
John
I had another quesiton do the various kits come with diffrent types of foam? For example does the non painted kit(NPS White) have a diffrent foam than the silver or green version?
I was planning on using this motor.
http://www.hobbyking.com/hobbyking/s...idProduct=5244 It seems a bit bigger than the 2409
Are there any problems fitting a 2200mah battery? What other batteries are you guys using?
Old Sep 14, 2010, 08:39 PM
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
I don't know what he was kind of P-38 he was running for 600watts but, after pasting several P-38 due to a motor failure, I'm kind of thinking my next one will be well powered but not going to be pushing my motors for he sake of watts.
Jim
Old Sep 15, 2010, 06:54 AM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Jim
I'm run a 4S not 3S system with twin 830kv motors that are well withing their rating which allows me to get 600Watts and that was using a wattmeter. I always test my motor prop combos before installing them into planes/EDFs, that way I know what ESC to run and what kind of performance to expect. I've got pics and links on the previous page, also I'm using 3blade props which aren't as efficient as the 2 blade so will draw a little more.....but they look WAY cool!
Old Sep 15, 2010, 02:24 PM
USA, GA, Atlanta
Joined Sep 2008
Sounds good now if you would only tell us what motor's your using you would make a lot of us very happy. I'd like to do a 600w p-38 too
Old Sep 15, 2010, 05:03 PM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
My post on the previous page has the link to the motors
Old Oct 07, 2010, 12:15 AM
jbc is offline
jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Finally got the video done and posted hope you enjoy
P-38 Lightning (by GWS) FLIGHT & Box Review (9 min 54 sec)
Old Oct 07, 2010, 03:44 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Jbc,
Thank you very much for this nice video and your comments.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Discussion Gws 二次大戰 名機 Gws-38 GWS CHEN Japan 6 Jan 01, 2007 10:36 AM
GWS-38 Twin Fighter Randori GWS (Grand Wing Servo) 154 Dec 13, 2006 02:35 PM
Discussion GWS-38 soon 廣營新的戰鬥機即將上市. GWS CHEN Taiwan 15 Dec 11, 2006 11:35 PM
New Product ****Must check GWS New Airplane GWS-38**** RAY GWS Product Announcements 24 Oct 25, 2006 11:21 PM
New Product GWS-38 (P-38 Lightning)... its here. Blaze.45 Hot Online Deals 18 Oct 05, 2006 12:39 PM
