Old Aug 23, 2006, 12:04 AM
Moorpark, Ca.
Joined Apr 2004
A new plane from an old favorite, RIP. Final pics added
Well, not being one who likes to get rid of anything, I figured I'd use up some more stuff I have laying around. My bro-in-law had just receintly finished up a twin star II and and I was rummaging through some parts and pieces of planes long since retired, I came upon my old GWS A-10 wing. Hmmmmm!! It kind of looked like a mini version of the twin star wing. (Light bulb comes on now), I know, I'll make a smaller version of a twin motor, high wing plane roughly based on the porportions of the twin star. I'll turn the landing gear nacells into motor nacells. And.... Well, I have some EPS foam containers, the kind that perishable foods are used to ship across country. This is very good EPS, quite dense. I cut one up into blocks and glued them together to make a block ~ 3"X4.5"X32". Hand drew a side and top profile on the block and using a band saw and a scroll saw roughed out the fuselage. Then using a sanding block started to put the finer details on. I then got some 5mm & 1.5mm depron and laminated the vert & horiz stabs. 5mm between 1.5mm sheets. Here she is so far with the stabs and wing just sitting on the fuse. I have some little eskay XT400 outrunner motors I plan to use with some 3 blade 6X4 MAS props. It's going to be aileron, elevator controls. And I plan to put tricycle landing gear with a sreerable nose wheel on.
RickAvery is offline Find More Posts by RickAvery
Old Sep 11, 2006, 11:59 PM
Moorpark, Ca.
Joined Apr 2004
Well, I've finished up the basic airframe and finally flew her tonight. She really flew quite well and needed very few trim clicks to trim out. The steerable tricycle gear works great. She needed more of my air strip to get airborne than I thought she would need. Almost in the weeds but finally lifted off and climbed out. The props are MAS 6X4s & I used a Dymond 1800mah, 3cell, 12c LiPo for a 7 min flight. When I charged the batt, it only took 600mah. 10min+ flights should be no problem. Quite a fun project. Now to dress her up. Happy flying.
Rick
Old Sep 12, 2006, 01:12 AM
Dig it up, we'll fix it..
Mugs914's Avatar
Vista CA (Near San Diego)
Joined Apr 2005
That's a great looking ship, Rick! I'd like to see more pics. Could you show your motor installation?
I like high wing twins and kind of had my eye on a Twin Star II, but I like your idea better...
What kind of paint job were you thinking about?
Keep the pics coming!
Cheers,
Mugs914 is offline Find More Posts by Mugs914
Old Sep 14, 2006, 06:00 PM
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
Great looking plane! I have been looking for a small nose wheel steering mechanism, like you have installed in there, for a plane I'm building. Is that a commercially available one? TIA for any info.
Bill
wmcneal is offline Find More Posts by wmcneal
Latest blog entry: A beautiful morning 05-08-2013
Old Sep 15, 2006, 12:01 AM
Moorpark, Ca.
Joined Apr 2004
Bill,
I've tossed the packaging but I think it was made by Du-Bro. I purchased them at Martys Hobbies in Thousand Oaks Ca. They have a web site. It was the smallest set I could find and fit great. Good luck.
Rick
Old Sep 15, 2006, 02:16 PM
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
Looks great RickAvery! I like multi-motor planes.
foamflyer is offline Find More Posts by foamflyer
Old Sep 15, 2006, 04:15 PM
AMA 125691
wmcneal's Avatar
Joined Jul 2002
Rick,
Thanks, I think I've found it.
http://www2.towerhobbies.com/cgi-bin...?&I=LXD845&P=M
Old Sep 16, 2006, 01:09 PM
Moorpark, Ca.
Joined Apr 2004
OK, here's the finished product. Thanks to all for the kind words. It sure means a lot as this is the first plane that I've built almost all of the parts. Except for the GWS A-10 wing, all was built on my bench using the TLAR method. Happy flying!
Rick
Old Sep 16, 2006, 01:51 PM
R/C Addicts Anonymous....
minifly's Avatar
Cape Town, South Africa
Joined Jan 2003
I'm guessing you could increase the prop size...it will give you more power for the climb out, etc.
minifly is offline Find More Posts by minifly
Old Sep 16, 2006, 05:56 PM
Snoopy's Wingman
Aceshigh84's Avatar
Minneapolis, MN
Joined Dec 2004
Wow, that thing looks great. With the paint, one of the best I have seen in a while. Just a suggestion on your long take off run. Your main gear is quite far back in relation to where I am guessing the CG is. That is one major thing I had to keep in the simulations when I was working on my senior design project. One of the planes from the previous year had a low enough stall speed but couldn't get enough moment to rotate about the gear to reach the necessary AoA. You may have clues to suggest otherwise but I would try moving your gear forward. A general rule of thumb is to have 10% on the nose and 90% on the mains.
Aceshigh84 is offline Find More Posts by Aceshigh84
Old Sep 16, 2006, 07:02 PM
Moorpark, Ca.
Joined Apr 2004
Aceshigh84,
Hmmmmm... I had never thought of that! The placement of the rear LG was a result of needing weight to the rear as the nose gear and servo added a bit of weight way up front. If the larger props I have ordered don't seem to cure the pucker factor at take off, I'll move the gear forward and give it a go. I'll most likely have to do some more work in the battery bay to move the battery back further. The basic porportions i.e. wing span to fuselage length, distance of the leading edge to the nose, Tail feather sizes & the CoG as mentioned, were taken from the Multiplex Twin Star II. So really, the CoG placement was just a guess. Thanks for the complements and Ideas. This project is far from complete. Class is in session.
Rick
Old Sep 16, 2006, 07:24 PM
Snoopy's Wingman
Aceshigh84's Avatar
Minneapolis, MN
Joined Dec 2004
Shoot us a video if you have a chance Rick.
Old Sep 16, 2006, 09:00 PM
KZ RIDER
raythomas's Avatar
Confederate States of America
Joined Nov 2001
If moving the gear forward doesn't do the trick. Have you thought about increasing the incidence on the main wing? Maybe 1/8 of an inch at a time and try it.
raythomas is offline Find More Posts by raythomas
Old Sep 16, 2006, 09:39 PM
Moorpark, Ca.
Joined Apr 2004
Ray,
Thanks! Another excellent idea and easily doable with my mounting setup. I may try that before I relocate the rear LG.
Rick
Discussion Old Dawg New Tricks, Spy Photos of new plane from EAM EAMRC Foamies (Kits) 50 Jan 16, 2007 10:26 PM
New Plane from Old plan! tallflyer Foamies (Kits) 4 Aug 21, 2004 03:30 PM
Plane in a tree - new ideas on an old problem! jdpowell22 Beginner Training Area (Aircraft-Electric) 5 Aug 02, 2002 06:09 AM
Thanks, from an old flyer 8250 Parkflyers 5 Jul 02, 2001 03:07 PM
