He's Right
I added triangle balsa as pictured below to a 3d plane with lots of potential for torsion. The smaller 3D plane I am building right now is going to simply have a piece of Depron, beveled to match up with the fuse / wing and glued into place where the triangle balsa is now. The wood, will certainly be less likely to break than the Depron, but it's also easy to glue. However the more weight youhave on something like that, more power it takes to fly the more damage there is in a crash. So a strip of Depron or FFF should really add a great deal of strength without all the weight. The Nasty has only 4 torsion triangles around the wing / fuse area with a single CF spar running the length and it's very stable.
That works better, but would be much stiffer if you were to fill in all four corners. More like a torque tube.
A good example would be to take a cardboard tube like a Monocote tube abd slit almost from end to end. Now take it by both ends and it is easy to twist. Now glue the slit with hot glue or CA and it will be impossible to twist.
| Thread Tools | |
| That carbon strip on shocky's | Simon Ka | 3D Flying | 1 | Apr 20, 2004 10:52 AM |
| CDs report on the 11-16 Foamie MoM race at Carlsbad, CA | slopejocky | Slope | 3 | Nov 18, 2003 07:27 PM |
| eBat on eBay - a new foamie wing? | turaboy | Foamies (Kits) | 1 | May 11, 2003 12:48 AM |
| AXI 2814/12 on a Zagi style wing??? | RandyK1 | Foamies (Kits) | 0 | Jan 18, 2003 02:07 PM |
| Construction resumes on B-25 foamie | DerekB | Foamies (Kits) | 29 | Aug 29, 2002 04:42 PM |
