Old Jun 09, 2001, 06:09 AM
Doc Watson is offline
Find More Posts by Doc Watson
Doc Watson's Avatar
UK
Joined Mar 2000
Home made oleo legs......
I wanted some oleo legs for my X32b Vtol project ( www.awatson1.fsnet.co.uk ) and after spending loads of money on 3 brushless motors, 3 ESC's, fans etc I wanted to build my own.
I used two pieces of brass tube (K&S) with one fitting inside the other. After much dremel cutting and some fine filing I think the results are quite good. I will post some pictures later today to show the results.
The tubes enclose a spring which has a maximum 3kg force (to fully compress it) and I only hope that any heavy landings will be absorbed. The total cost for all the parts required must have been less than $10!!!!
I also made my front wheel attachment from carbon fibre tows with excellent results, again pictures will follow later today.
Doc
Doc Watson is offline Find More Posts by Doc Watson
Old Jun 09, 2001, 06:20 AM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Doc
When we used to make our own oleos for GDF, we used a spring rate of 6xmodel weight per in.
So a 5lb model would use a 30lb/in spring on each main leg.
Cheers
Gordon
Gordon is offline Find More Posts by Gordon
Old Jun 09, 2001, 06:33 AM
Doc Watson's Avatar
UK
Joined Mar 2000
My expected (or should I say planned) AUW is 9lb!! so do I need stiffer springs?, remember its not landing 'conventionally' its the VTOL thing. I also have three UC legs which will spread the load, this makes a difference, right?
I just calculated that my spring compresses fully to about 1/2 inch so thats about 13lb/inch stiffness. Still dosent sound as if its stiff enough using your figures.
Doc
[This message has been edited by Doc Watson (edited 06-09-2001).]
Old Jun 09, 2001, 10:21 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Springs alone make for rather poor energy absorption characteristics. Dampening of some sort would be required to prevent 'bounce back'.. perhaps the coil- over units from RC cars might be worth considering as an alternate.. barring price considerations some of the available units are adjustable for compression/rebound as well as spring rate... wieght and bulk might be a consideration tho... certainly worth exploring.
Bare is offline Find More Posts by Bare
Old Jun 09, 2001, 11:17 AM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
For damping you can stuff the oleo tube with a foam like EPP that can compress with a slow full recovery. You can actually use the foam instead of springs. This would be similiar to what is often used in bicycle suspensions.
Gerald is offline Find More Posts by Gerald
Old Jun 09, 2001, 06:37 PM
Doc Watson's Avatar
UK
Joined Mar 2000
Hear is the one I made earlier.......
Doc
Home made plane flies!! Jeremy_D Parkflyers 4 Jan 02, 2008 08:00 AM
Home made zagi motor tray William A Foamies (Kits) 15 Jul 04, 2001 03:29 AM
Home made triple-Jet first flight bruceh Foamies (Kits) 3 Jun 30, 2001 06:50 PM
home made carbon fiber ? mjse Electric Plane Talk 2 May 26, 2001 06:55 AM
home made carbon fiber ? mjse Parkflyers 0 May 25, 2001 02:42 PM
