Old Aug 21, 2006, 08:24 PM
spllouder is online now
Find More Posts by spllouder
SW Missouri
Joined Aug 2006
need help ! first-time heli setup , TAIL ?
ok i got my new HB cp2 and iam a newbie to heli r/c so , i read alot and cant firgure this one out ?
ok i try spooling up my heli and before it even begins to start to take off the tail just spins to the left like theres too much rpms , so i try turning the portion down and its all they way - and my trim is all they way left and i have to give it some left stick to make it stay put , i cant even lift of because when it gets lighter on the ground it wants to spin like a top ?
what do i do plz help ,
p.s also i unpluged the tail motor from the 4-1 and ian not sure if i have it pluged in right should the pos be on the same side as the main motor ? thanks
spllouder is online now Find More Posts by spllouder
Old Aug 21, 2006, 09:27 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
It sounds like you have the tail motor plugged in backwards. Flip it around and try it. If you are standing on the right side of the heli, with the nose to your right (facing the tail blade) it should rotate counter-clockwise.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Aug 21, 2006, 09:36 PM
billyzelsnack is offline
Find More Posts by billyzelsnack
drops screws
Iowa City, IA
Joined Dec 2005
Also, make sure your tail prop is on well. They come loose pretty easily.
billyzelsnack is offline Find More Posts by billyzelsnack
Old Aug 21, 2006, 09:55 PM
SW Missouri
Joined Aug 2006
i had motor plug in right . put the prop was on to tight i ease up on the fuel line thing and now i can full power up and tip toe and the tail stay put but i still have the trim all the way to the right , exactly what does the gyro do ? my tail does not twitch realy left and right just just souns like rpm move up and down a little tough ?
also what do i ajudst for gyro ? thanks for all the help
Old Aug 21, 2006, 10:04 PM
drops screws
Iowa City, IA
Joined Dec 2005
I've heard people set it up two ways.
If your trim is to the right..
UNPLUG BATTERY. (The 4-in-1 will make any changes unless you do so)
Center your trim.
Turn your proportional pot to the left a tiny bit.
Keep going until it is working well.
Once proportional is working, adjust gain.
Turn gain all the way up.
Keep turning down until it stops wagging or more if you like the tail less stiff.
Old Aug 22, 2006, 10:14 PM
SW Missouri
Joined Aug 2006
got the tail pretty good now. got to hover it up and landed but landing on a old wire i dint see in the grass and smack my blades on the wire . dam , blades just have some nicks fixed with tape , but it fliped a blade overdo like both blades were pointing in the same direction . nothing broke thou , just flip it back over the linkage for the pitch adjusment and how they face the right way ,but now the blades track badly , i spool it up and blades are badley out of track ,
i tried adjusting the adjuster but wont help , blades seem still straght too . i get a alot of head wobble , is this from the blades out of track ?
Discussion Help!? First Time Heli Buyer skiermike123 Mini Helis 42 Jan 02, 2007 03:04 PM
Discussion New Blade CP/First time heli pilot, need advice ormandj Micro Helis 29 Jun 26, 2006 12:59 PM
First time Electronics Setup on Corona, Help!?! mtbiac Electric Heli Talk 7 Jan 02, 2003 04:45 PM
Need help, First sailplane "Caleb" ciressarg Electric Sailplanes 4 Jun 21, 2002 12:25 PM
ECO 8 First Time Heli Buyer jdoan Electric Heli Talk 1 Nov 16, 2001 04:54 AM
