Old Aug 21, 2006, 12:56 PM
epwierman is offline
Find More Posts by epwierman
epwierman's Avatar
Joined Aug 2004
Help!
Can anyone help me calc this?
Hi,
I have an odd set up that test flew really well yesterday. I'd like to get an estimate of watts, but the p calc I used doesn't show the batts I am using, nor does it likely illustrate the limited burst application of how the motor is actually being run.
Here is the set up.
Neu Motors 1512/ 1 D
6.7 gear reduction
14.5 x 14 slim folding (RFM carbon)
plus 3 degree pitch spinner/yoke
Castle PHX 125 esc (3 volts per cell was the programmed cut off, no cut off inflight)
5S2P Hyperion Litestorm 3700 mah batts (7.4 amp pack)
The motor is run for 3 to 4 seconds and the plane (hotliner/F5B) accelerates in the verticle climb to what I estimate is 140 mph, then the motor is shut off.
After approximately 7 climbs (I wish now that I had counted accurately) , including glides in between, the temps on landing were as follows.
Batts- 111 F
Esc- 120 F (on the top side, exposed to vent)
Motor- 124 F
BTW, the prop is horribly stalled at first segment of acceleration, the higher pich initial part I ssume near the hub; at 80 ish mph, it "hooks up" and zooms pretty good from there to top speed.
Recharging of batts showed 4000mah used of the available 7400 total, cells were still in balance after the flight and peak voltage after charge was normal.
If anyone has any input, it would be great hear.
Eric
epwierman is offline Find More Posts by epwierman
Old Aug 21, 2006, 01:08 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Are you sure it is 1512/1D - the only 1D Motocalc has is the 1521/1D??
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Aug 21, 2006, 01:14 PM
epwierman's Avatar
Joined Aug 2004
It's the F5B 16 cell comp motor. It is actually a 1512/1 D. If you look at Neumotors site, it is listed there, in the "competition" motor section.
Specs are;
1512/1 D
1000-1200Watts Continuous / 2500- 30sec
Max rpm: 60,000
Stator Dia. 1.5"
Magnet/rotor length 1.2"
Shaft: 5mm
Shaft length: .75"
Weight: Smooth-280g
Dimensions 2.4"L x 1.56" dia.
Thanks for checking this project out.
Can anyone help me figure this out... av8ersteve Batteries and Chargers 3 Aug 10, 2005 07:36 AM
Can Anyone Help Me Identify This Connector?? mikefaith Electric Heli Talk 2 Apr 22, 2005 07:47 AM
Can Anyone Help Me Find This Plane ? Bob Cook Electric Sailplanes 3 Feb 08, 2003 08:55 PM
Can Anyone Help Me Re-wire This Speed Controller?? TONY DENTON Power Systems 1 May 27, 2002 11:27 PM
Can anyone tell me ?? About this motor Gene Gold Power Systems 5 Oct 04, 2001 03:32 PM
