Old Oct 05, 2006, 02:02 PM
thetriguy is offline
Find More Posts by thetriguy
Joined Sep 2006
Thanks Gene...Sounds easy enough, but I know that when I installed a 5/5 on this plane didn't fly near as fast as the 8/4. Any chance a 6/5 or 7/5 would be better than say an 8/4 or 8/6?
thetriguy is offline Find More Posts by thetriguy
Old Oct 05, 2006, 02:36 PM
jerbear is offline
Find More Posts by jerbear
jerbear's Avatar
indianapolis, indiana
Joined Oct 2002
Ahhhhh .........
Guru speaks wise words for all grasshoppers .... where would we be without him ???????
jerbear is offline Find More Posts by jerbear
Old Oct 05, 2006, 03:00 PM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
The reason the 5x5 didn't give you any more speed is easily explained. Every motor is designed to turn a certain rpm. In the case of your bp-21 it's probably 1750 rpm/V.
If connected to a 3S lipo, that would give around 10V under load, your motor would turn 10x1750 = 17500 rpm. Without a prop.
If you add a prop, rpm will drop. Sometimes it drops to 80%, sometimes 60%, it depends on motor design and prop choice.
Let's say a bp-21 drops to 60% of 17500rpm on a prop, it would turn 0,6 x 17500 = 10.500 rpm.
The key to maximum perfromance is to choose a prop that, while turning at 10.500 rpm, loads the motor to just it's allowed max amps.
With the 5x5 that didn't happen.
In the case of the bp-21, that can take 13A, common prop choices are tested in these links:
http://www.rcgroups.com/forums/attac...hmentid=672938
http://www.rcgroups.com/forums/attac...hmentid=724984
http://www.rcgroups.com/forums/attac...hmentid=725157
Prop-er is offline Find More Posts by Prop-er
Old Oct 05, 2006, 08:13 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
had a full size with bp-21 ....... it flew well, but ate up my 25 acre field in nothing flat. managed to dork it in, but just nose kinda squished in. was very fixable. however, i decided to build it at 80% of plan (18'' wingspan) and use a gb/bl /8040 prop/ 830 2 cell lipo. had my maiden this evening
as a lighter version, as well as smaller, it still has all the great flight characteristics of it's larger brother. glide is great ... slow speed flight is very good .... and for my size field it's still a rocket auw / rtf is 6.3 oz. with the 830 pack. thanks for the great plans
jer
Old Oct 05, 2006, 08:44 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Well I'm certainly glad Jer "broke the ice" and changed something ... so I too can confess now .... Mine is a Profile ... full size though and seemingly very light .... built it as a chuck glider , but decided to "go for it"!!! So we're using the Guru's recommended 15t26awg/8x4/2slipo ??? Looks FUN , but already ...how do you launch it ??? My Dumb!!!
PS ... skewer wing struts keep everything aligned..
gpw is offline Find More Posts by gpw
Old Oct 05, 2006, 10:08 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
gpw
you are correct on cd/prop/batt. the new plans i used have a longer nose which not only helps with balancing for lighter motor ..... but actually allow launch via holding by nose behind prop area. skewers are great ... used because i i have no wing bracing.
jer
Old Oct 05, 2006, 10:32 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
OK, Must be confession time
I've been thinking 150% Slow Flyer for the upcoming indoor season! W/ Landing gear, of course. Probably double the elevon chord, and add a rudder, as well. We'll see!
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 05, 2006, 11:16 PM
jerbear is offline
jerbear's Avatar
Joined Oct 2002
landing gear would be a very cool addition
Old Oct 05, 2006, 11:51 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
indoor season...??? Whats that
hehe
Oh... You must mean when it gets real cold... Like 35 degrees outside... brrrr
I know what ya mean. I generally spend those days inside w/ a cup of coffee, building and complaining about the chill in my bones... hehe...
sorry... had to...
msmith is offline Find More Posts by msmith
Old Oct 06, 2006, 12:16 AM
rab is offline
rab
Find More Posts by rab
rab
Grounded in Arlington
rab's Avatar
Arlington, Virginia
Joined Aug 2004
Tail dragger or tricycle gear, what do you think?
Allen
rab is offline Find More Posts by rab
Old Oct 06, 2006, 12:46 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I'm thinking tail dragger. Tricycle gear gets too tall for my tastes it seems.
Old Oct 06, 2006, 03:41 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
I can make some scaled plans if you wish.
150% FFF 6mm taildragger?
Old Oct 06, 2006, 08:07 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Now that we've cleansed our souls by confessing to Padre Prop-er, we can continue with the FUN ... 150% sounds FUN ... I thought my printer was acting UP again when I printed this one ... seemed small , looks huge online ...Build was quick , thanks for the plans and info .... and why does this remind me of the end of a Mel Brooks movie????
V, we PROMISE not to complain to you if any of our changes don't work out... I always dislike complaints about "mutations" hahahahahahaaha
Old Oct 06, 2006, 09:56 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
I too wasn't prepared for how small it turned out. 30" sounds like a decent size to abuse this funflyer. And Gene can mount a CDR for his indoor flying.
Everybody happy.
I hope to maiden my Duplex Delta on Sunday. My Himodel 282616 Brushless Outrunner 1611KV did WOT @ 10,14A on the APC-E 6 x 5,5. It makes a very racy sound.
Old Oct 06, 2006, 11:12 AM
Sandray is offline
Find More Posts by Sandray
United States, NC, Charlotte
Joined Aug 2006
Gpw, can you link this TOG for welding instructions used with the hot glue gun? New to the craft and still doing my research. Thanks guy.
Scott
Sandray is offline Find More Posts by Sandray
Video Depron Duplex Delta TerryE Electric Plane Talk 1 Jun 21, 2008 01:53 AM
Rave 3d depron plane, free plans tripxrcer 3D Flying 5 Feb 05, 2005 12:56 PM
"Easy" to build depron Jets? Free plans possibly? Zeroaltitude Electric Ducted Fan Jet Talk 20 Oct 14, 2004 01:35 PM
Pibros foam delta -free plans. omega blood Flying Wings 6 Jul 11, 2004 09:20 PM
Free Plans for 6mm Depron.... Ado Foamies (Kits) 10 Jul 08, 2004 03:05 PM
