Old Oct 01, 2006, 07:45 PM
thetriguy is offline
Find More Posts by thetriguy
Joined Sep 2006
OH, the props I used were an 8/4 and 8/6, NOT 9/4 and 9/6!!!!
thetriguy is offline Find More Posts by thetriguy
Old Oct 01, 2006, 08:38 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Oh Great!!!! :rolleyes ... I finally get the plans from Ms and now they're changed... Arrrgh!!!!!
gpw is offline Find More Posts by gpw
Old Oct 02, 2006, 08:37 AM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
Dear foam lunatics,
I've ended up changing quite some things on the plans. I've lengthened the nose by 10mm, corrected tab hole positions, added a nice square hole in the former, changed the former shape, made a simple tapered nose and I threw away all the excess control surfaces.
Letter and A4 sized templates are now one single file, containing six pages.
Good luck building your free Depron Duplex Delta 3 !!!
Vincent
The plans can be downloaded from:
http://www.rcplans.nl
Prop-er is offline Find More Posts by Prop-er
Old Oct 02, 2006, 10:03 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Looks good at first glance
Thanks again!
You may want to edit the links on the first post to these links, so guys won't have to dig as far.
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 02, 2006, 10:39 AM
Joined Sep 2006
Thanks Prop-er!
Old Oct 02, 2006, 10:49 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
My pleasure.
Glen, You've got the updated plans in your Mac mailbox...
Gene, I've updated the first post.
Old Oct 02, 2006, 04:41 PM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
I've been busy tonight... (it's 23:30 over here)
Went together fine. Glue's drying. Made one modification.
If I clamped the tail together, the whole fuse would obviously come together.
I've put a piece of foam between the tail, on the bottom wing's back to prevent this. Might add that to the plan.
The idea of a removable top wing was stupid. I've glued everything together now, and will make hatches to get acces to the inner fuse. (Just like Gene)
Started cutting templates at 19:00, all glued together at 23:00. (I'm a slow builder)
Got an electro fly meeting this saturday. I want it to fly there.
I've got a jobless BP-21 on the shelf. Not for long. Should be fun.
It's much smaller than I thought...
What about elevon throws? 10mm enough?
Square firewall fitted like a glove this time...
Old Oct 02, 2006, 07:29 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Originally Posted by Prop-er
... Made one modification.
Not sure quite what you mean... I glued just the bottom-rear, up around to the top front of the fin, where the notch for the rear of the top wing is... Ran a bead, and glued together around the edge. The triangular 'tail' of the bottom wing sets the spacing for the fuse on the bottom vs the top... At least that's what I assumed you intended
I thought about it, letting it sit for a day or so, but I really needed to glue to the top wing, to hold the shape of the fuse. Then decided on the hatch
Yup, and that's a bunch'o'motor Mine's more like a 14-15t CDR motor.
Should be plenty.
Hope you have at least 1/2 the fun I do with it!
Old Oct 02, 2006, 07:33 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Thanks V ... Got the plans ... Can't wait to start on this one ... Got a little Blue and silver Chi motor that should be perfect on this , and it's only 12 bucks .... Lets see now how many Euros is that ...???
Old Oct 02, 2006, 10:04 PM
Joined Sep 2006
I flew it again today! I forgot the canopy though! It flies well without it! I didn't have a battery heavy enough to balance, so unfortunately it was slightly tail heavy. The new plans with the nose 1CM longer should help! The video below stinks, but the plane does not! Thanks again everyone who helped me get this bird in the air!
Mark
http://media.putfile.com/Duplex-Delta
Old Oct 02, 2006, 10:07 PM
Joined Sep 2006
BTW, did I forget to mention UNLIMITED VERTICAL CLIMB?? I reinforced the top wing with a carbon rod also. This plane will do anything not I want it to. FAST spiraling dives, etc. I'll try and post a better video soon!
Mark
Old Oct 02, 2006, 10:22 PM
Joined Sep 2006
Dang it!! I meant to say this plane will do anything I want it to.. Not anything not I want it to... that doesn't even make sense!! :-)
Mark
Old Oct 02, 2006, 11:24 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
What can I say... The video was kind of lacking but I promise you, better than nothing! what I am trying to figure out is how you were able to "transform it" into a yellow cub? That my friend was wicked cool. and I never saw your hand move!
Robert
willin is offline Find More Posts by willin
Old Oct 03, 2006, 04:29 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Originally Posted by willin
... what I am trying to figure out is how you were able to "transform it" into a yellow cub? That my friend was wicked cool. and I never saw your hand move!
That was slick! The best I can do is turn them into a bag of parts
Old Oct 03, 2006, 06:04 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
Thought the BP-21 probably was too crude for this little gem. Ordered a nice Chinese 40gr 1611 kV motor. Should run a APC E 6 x 5,5 at 12000 rpm, giving 90km/u (56Mph) and 350 gram thrust. AUW weight around 250 gram.
Video Depron Duplex Delta TerryE Electric Plane Talk 1 Jun 21, 2008 12:53 AM
Rave 3d depron plane, free plans tripxrcer 3D Flying 5 Feb 05, 2005 11:56 AM
"Easy" to build depron Jets? Free plans possibly? Zeroaltitude Electric Ducted Fan Jet Talk 20 Oct 14, 2004 12:35 PM
Pibros foam delta -free plans. omega blood Flying Wings 6 Jul 11, 2004 08:20 PM
Free Plans for 6mm Depron.... Ado Foamies (Kits) 10 Jul 08, 2004 02:05 PM
