Joined Sep 2006
Build Question!
Good greif, this should be easy... I have the newbie blues. I can't figure the front of this thing out. According to the drawing, it looks like the point of the front fuse is in the middle of the round firewall... The whole front end, I'm just not sure what to join to what!!! I've attached a few pics! Please help, as this plane looks like it's going to be awesome! I haven't glued anything yet, just seeing how it will all go together. Hey Gene, I enclosed a pic of the plane I build from your plan. I flew it again in a very heavy wind today, it actually landed like a helicopter, just losing altitude (about an inch a second) without moving forward an inch. It was awesome! Check out how I did my landing gear!! I know, I increased the weight a lot, but man it works great!
Thanks, Mark
Mark,
I can't understand what your problem exactly is. Just tape to whole front fuse together to form a round nose. If the round firewall turns out to be too large, just cut to fit. Now you can glue all parts together. Maybe having a look at Gene's DDD pics make's things clear: http://www.rcgroups.com/forums/showp...9&postcount=18 |
HT: I just use the leads on the esc and motor the way they come, with a 4 pin Deans mini (3 of the 4 pins are symetrical, so reversing rotation is easy). If I need an extension, I try to only do it on the rx connector.
My esc is right about the back of the front former (which is wide open through the center, now)... <<<<<-----Forgot whether I mentioned that, Prop-er.
I'm one for soldering the ESC direct to the motor leads. I sometimes fool myself that it's to save weight, but mainly it's because I'm too tight to buy connectors
I've read else where that extending motor leads a little is ok, but I think I might just open the bulkhead as suggested and velcro the ESC in the nose. Keyhole surgery will be required as I regressed from 'older and wiser' to really wanting to stick it together. Looking forward to seeing my first attempt at bending Depron emerge from under the masking tape in the morning!
| Thread Tools | |
| Video Depron Duplex Delta | TerryE | Electric Plane Talk | 1 | Jun 21, 2008 12:53 AM |
| Rave 3d depron plane, free plans | tripxrcer | 3D Flying | 5 | Feb 05, 2005 11:56 AM |
| "Easy" to build depron Jets? Free plans possibly? | Zeroaltitude | Electric Ducted Fan Jet Talk | 20 | Oct 14, 2004 12:35 PM |
| Pibros foam delta -free plans. | omega blood | Flying Wings | 6 | Jul 11, 2004 08:20 PM |
| Free Plans for 6mm Depron.... | Ado | Foamies (Kits) | 10 | Jul 08, 2004 02:05 PM |
