Old Aug 27, 2006, 09:42 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Molding the nose is the most fiddly part... Might be just as well off to do it in a tapered square. I could have had it together a long time ago...
I'm going to go ahead and seal it up, then cut the pockets and a door for the equipment.
No reinforcement (carbon or skewers) needed for fanfold... planty strong at this span and weight
Should be flying soon!
Gene Bond is offline Find More Posts by Gene Bond
Old Aug 28, 2006, 12:49 AM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
Thanks for your very welcome comments, Gene!
I will change the plans asap. Might even add a tapered square nose option.
Prop-er is offline Find More Posts by Prop-er
Old Aug 30, 2006, 08:10 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Here's the pictures...
Got the maiden in today Flies great!
I wound up using a Tower Pro 2406 w/ a 7x4 prop on 3s830's... ZOOM!
Final AUW was 7.5oz.
The video says it all. Wide speed range, control down to verly low speed, no real pitch sensitivity at speed, just perfect!
Full Video: http://media.putfile.com/Duplex-Delta-Maiden
Old Aug 30, 2006, 08:31 PM
9LIVES1968 is offline
Find More Posts by 9LIVES1968
Titanium Has My Back!!
9LIVES1968's Avatar
Birmingham,Al
Joined Dec 2001
Nice video Gene! Looks like proper has another winner. Are you going to mod it for rudder?
9LIVES1968 is offline Find More Posts by 9LIVES1968
Old Aug 30, 2006, 08:47 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Probably not. It really doesn't need it, except at very low speed, high alpha. I can't see it being a great 3D plane, so won't bother.
Old Aug 30, 2006, 09:06 PM
bass3587 is offline
Find More Posts by bass3587
bass3587's Avatar
Arlington,Texas
Joined Jan 2005
Nice video Gene!! Thanks for the plans Prop-er!! I like the slow speed stability of the delta.
bass3587 is offline Find More Posts by bass3587
Old Aug 31, 2006, 01:17 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
Top job, Gene. Looks absolutely stunning (as always)! Great flying! And take a good look at the nice round nose, cause that's where the building hours have been spent...
Did the CG shown on the plan worked out for you?
The plans update is scheduled for this weekend.
Old Aug 31, 2006, 05:56 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Yep, that flight was with your suggested CG, which put the pack right against the former. I see no reason to change it! I am going to open a hole on the bottom-rear, to let a little cooling air through.
Thanks again for your work!
Old Sep 04, 2006, 09:08 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Sqwarshed the nose after 5-6 great flights this weekend... Helpful hint, *Don't adjust/program your radio while doing an inverted parchute!* Eventually, you run out of altitude
BTW, it does (did) really cool looking inverted parchutes... Hope it will again!
Old Sep 05, 2006, 08:09 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
Thx for the hint
Haven't heard about an inverted parchute figure yet. How does it look like?
Will update the plans soon. Really. Maybe this afternoon.
Old Sep 05, 2006, 10:21 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Inverted Parachute is super-simple!
1. Fly inverted
2. Decrease throttle while holding elevator to maintain attitude
3. Go all the way!
4. Watch it float down (almost) vertically, and control the glide with aileron or rudder.
5. Power-up before you run out of altitude!
It's cool when entered from a spinning dive, or even a rolling vetical climb!
Old Sep 05, 2006, 10:53 AM
Jeff_Churill is offline
Find More Posts by Jeff_Churill
Great Lakes Guy
Jeff_Churill's Avatar
United States, MI, Farmington Hills
Joined Feb 2005
Nice concept....just when you think you've seen it all?? Nice plane, nice video Gene...but man that thing just looks so odd in the air? Makes it that much better
Jeff_Churill is offline Find More Posts by Jeff_Churill
Old Sep 05, 2006, 02:06 PM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
man! how did I miss that one!
Prop-er, what a great Idea! I love the odd stuff!!! congratulations!
must be a cool little sport-aerobatics plane!
Congrats also to Gene. The model looks great (as always!).
To bad I couldn't see the video - the putfile-server does not like me ...
chara is offline Find More Posts by chara
Old Sep 05, 2006, 05:51 PM
Spitfireski is offline
Find More Posts by Spitfireski
Can glue better than fly!
Grand Blanc, MI, USA
Joined Aug 2005
Definetly cool !! Looks like it can easily confuse you with it's orientation. A variable pitch prop could even confuse more!
Love the inverted parachute, my favorite is going into from vert climb way up then just cut throt. then fall flat all the way down.
Spitfireski is offline Find More Posts by Spitfireski
Old Sep 05, 2006, 08:20 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Here you go: http://www.rcgroups.com/forums/showthread.php?t=566166
Video Depron Duplex Delta TerryE Electric Plane Talk 1 Jun 21, 2008 12:53 AM
Rave 3d depron plane, free plans tripxrcer 3D Flying 5 Feb 05, 2005 11:56 AM
"Easy" to build depron Jets? Free plans possibly? Zeroaltitude Electric Ducted Fan Jet Talk 20 Oct 14, 2004 12:35 PM
Pibros foam delta -free plans. omega blood Flying Wings 6 Jul 11, 2004 08:20 PM
Free Plans for 6mm Depron.... Ado Foamies (Kits) 10 Jul 08, 2004 02:05 PM
