Old Oct 29, 2006, 01:40 PM
thetriguy is offline
Find More Posts by thetriguy
Joined Sep 2006
I'm going to wait before putting everything together to see how the "masters" do theirs... I'm sure they will inspire me to make a change or two. Only problem is most people's landing gears aren't beefy enough for my kind of flying!!! The kind where you are constantly fixing bent music wire after landing!
Mark
thetriguy is offline Find More Posts by thetriguy
Old Oct 29, 2006, 02:54 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Changes I made, FWIW...
Not sure they are good or bad, but anyway, here's where I am:
- elevons = 4" chord
- rudder = 4" chord (hinge line parallel to TE)
- fuse sides end just past TE of wings, and single layer tail is sandwiched w/ 4" overlap
- top and bottom nose skin cut separate from wings (width of fanfold is only 23")
Right now, I'm gluing the ply firewall over the foam firewall & nose skins. I poked some holes in the foam and am using ProBond w/25% Elmers & a drop of blue paint.
Top wing on (needed it for the tail position).
3mm tubes in both wings w/ hot glue, bottom one 1/2" ahead of elevon hinge line, top one butted to back of former slot.
Once firewall is dry, I'll glue the bottom wing on and cut some access hatches on the bottom. Still studying how I will mount the landing gear, but I know it will be fiberglass rods criss-crossed somehow. I need to have both wings on to get a good idea what's the best way. It will be a wide-track, though, for ground stability.
I'm going to start off with a GWS 2208/18T on 3s with a 9050HD prop. s/b about 70w, 14.5oz, 32mph... Depending on the finished weight, it may need more motor
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 30, 2006, 07:20 PM
Joined Sep 2006
Prop-er,
I flew my new DD today (20" version with new fuse design). I had some balance problems with the small motor that you are using. The only way I could get it to fly right is to throw gravel into the front compartment (I know, stupid). I don't know what the solution is. I hate to add weight, but can't move the battery any farther forward because of the former. Was your plane really tail heavy?? I can't wait to see Gene's 150%!!
Mark
Old Oct 31, 2006, 12:11 AM
mnflyerfff is offline
Find More Posts by mnflyerfff
Joined Jul 2006
Gene:
Was this going to be an indoor capable version? It isn't much fun flying outside in the Winter in Minnesota.
mnf
mnflyerfff is offline Find More Posts by mnflyerfff
Old Oct 31, 2006, 06:53 AM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
Mark,
Mine was tail-heavy. It flew great once I had sorted out the throws and expo.
Still added three chunks of fishing lead. I guess it was close to 50 grams total extra weight right up front in the nose. It helped for stable flying in the strong winds.
You can make a hole in the former, so you can place the battery more forward. Dont worry about strength. It's by far strong and stiff enough.
Prop-er is offline Find More Posts by Prop-er
Old Oct 31, 2006, 06:55 AM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
Gene,
You were supposed to glue the fuse side templates together, and cut them out of foam as one side piece... I've drawn the templates this way to save you all a good two to three extra pages...
But I like your pics very much!
Now, go out and trash it!
Prop-er
Old Oct 31, 2006, 07:03 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Yea, I deviated on the sides for no great reason. It was just an idea I had... Sometimes I stop to think and forget to start again
It would have been easier to do the double thickness tail. Less chance of introducing a warp as well. That's how I did it on my 20", and it was simple and easy. I just thought since I was using a rudder on this one, I'd try it this way. Really didn't save any weight, just complicated it.
And, yes, this one is for slow flying. If it doesn't fly that well, adding horsepower and weight are easy!
Old Oct 31, 2006, 07:15 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Changes eh ???? Aargh !!!!
gpw is online now Find More Posts by gpw
Old Oct 31, 2006, 07:52 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
But... changes in error, so the plans are fine!
Old Oct 31, 2006, 08:01 AM
gpw is online now
gpw
gpw
gpw's Avatar
Joined Jul 2002
What would happen if we reversed the direction of the wings ... RHOMBOID ????
Old Oct 31, 2006, 08:47 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
And the prop?
Old Oct 31, 2006, 11:56 AM
Joined Sep 2006
Looks good Gene! Prop-er, I'll move the battery forward and adjust my rates some. I had a lot of throw also, no D/R set up.
Mark
Old Oct 31, 2006, 03:33 PM
Prop-er is offline
Launchpad McQuack
Prop-er's Avatar
Joined Sep 2004
Glen, welcome as a new member to the crazy lunatics design group....
Old Oct 31, 2006, 11:43 PM
jerbear is offline
Find More Posts by jerbear
jerbear's Avatar
indianapolis, indiana
Joined Oct 2002
new member ...................... ???????????????????????????????????????????????
hell, he's the one who founded that organization. lol
jerbear is offline Find More Posts by jerbear
Video Depron Duplex Delta TerryE Electric Plane Talk 1 Jun 21, 2008 01:53 AM
Rave 3d depron plane, free plans tripxrcer 3D Flying 5 Feb 05, 2005 12:56 PM
"Easy" to build depron Jets? Free plans possibly? Zeroaltitude Electric Ducted Fan Jet Talk 20 Oct 14, 2004 01:35 PM
Pibros foam delta -free plans. omega blood Flying Wings 6 Jul 11, 2004 09:20 PM
Free Plans for 6mm Depron.... Ado Foamies (Kits) 10 Jul 08, 2004 03:05 PM
