Old Jun 08, 2001, 02:15 PM
Ben C is offline
Find More Posts by Ben C
UK
Joined Jan 2001
Running charger on mains with 'car charger' and 12V lead acid battery?
Hi, I read somewhere that you could use a car charger to run your peak charger off of the mains if you use a 12V battery in parallel.
I just wondered, how does the 12V battery filter out noise as there is a quicker route - ie. straight to your peak charger?
Probably a dumb question, I know, but hopefully someone can put my mind at rest!
Ben C
Ben C is offline Find More Posts by Ben C
Old Jun 08, 2001, 03:22 PM
Danny Van Hoecke is offline
Find More Posts by Danny Van Hoecke
Ghent, Belgium
Joined May 2000
Ben,
I use this method and found out that the battery (in my case a 12V 9Ah motocycle batt.) acts like a kind of buffer: the input voltage to my charger never rises above 13.8V. Without battery the voltage varies much more and I don't think my charger likes this (false peak detection etc.).
Danny
Danny Van Hoecke is offline Find More Posts by Danny Van Hoecke
Old Jun 08, 2001, 03:30 PM
BobK is offline
Find More Posts by BobK
Rhode Island
Joined Oct 2000
The 12v battery is acting as a HUGE capacitor and filters the charger output rather nicely
BobK is offline Find More Posts by BobK
Old Jun 08, 2001, 04:10 PM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
The maker of my astroflight 112d specifically state no to hook up directly to a battery charger. Check with your chargers manufacturer; I have heard some can be.
-fish
fisher is offline Find More Posts by fisher
Old Jun 08, 2001, 04:47 PM
sambo is offline
Find More Posts by sambo
crystal lake illinois
Joined Nov 2000
Hi Ben:
I would not reccomend running your charger directly off the car charger. Youmget peaks which will damage the charger. OK to charge battery and rujn your Nicad charger from the battery.
Just spent $30 to repair acharger I directly connected to the auto charger.
Sambo
Ben C
sambo is offline Find More Posts by sambo
Old Jun 08, 2001, 08:46 PM
Regecide is offline
Find More Posts by Regecide
What's a Member??
Sydney,Australia
Joined Mar 2000
Yup that's what we do with our Infinity II. Hook up a car battery charger to the big batt and then hook the normal charger to teh 12v batt. Seems to work ok and the input voltage usually doesn't go much over 14v
Alex
Regecide is offline Find More Posts by Regecide
Old Jun 08, 2001, 08:48 PM
Regecide is offline
What's a Member??
Sydney,Australia
Joined Mar 2000
Alex
Old Jun 08, 2001, 08:56 PM
Gerald is offline
Find More Posts by Gerald
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
That's what I do too with my Simprop Intelli Control charger. I use my 12AH field charger battery with a 12/2 amp sears auto battery charger. This way when I'm done pre-charging my batteries at home I can take the field battery with me to the flying field and its always fully charged too, ready to re-charge packs at the field.
Gerald is offline Find More Posts by Gerald
Discussion can the astro charger charge lead acid batts? rmasu Batteries and Chargers 7 Apr 10, 2007 09:31 PM
Wanted 12 volt ac charger for lead acid starter battery flyingj Aircraft - General - Miscellaneous (FS/W) 5 Feb 16, 2007 01:53 PM
Remote charging 12v lead-acid zippogeek Electric Plane Talk 2 May 01, 2003 06:02 PM
Wattage PF-12: Can it really charge 12 cells using a 12V lead acid battery for power? Tfour2 Batteries and Chargers 7 Nov 06, 2002 01:21 PM
