Old Aug 19, 2006, 10:25 AM
skankpile is offline
Find More Posts by skankpile
Joined May 2006
GMFC problem on tapered wing
I'm getting this error in GMFC:
Speed above step motor limit on X left axis : 0.78 mm/s, Move to block start d1
What the heck does it mean? I'm trying to cut a P51 wing with a 190mm root and a 90mm tip. The Tip is centered in the root.. but for some reason no matter what I do I cant get rid of this message.
I've read through the manual (help guide), and it mentions syncing the wire at root and tip, is this what I need to do.. the guide does not mentio how to do it..
anybody have experience here?
skankpile is offline Find More Posts by skankpile
Old Aug 19, 2006, 10:50 AM
max z is offline
Find More Posts by max z
max z's Avatar
The Netherlands, ZH, Boskoop
Joined Mar 2001
I think I know why. Interestingly, my version of GMFC does not show the cut speed option "Measured" for Poly expanse. Only "Maximum" and "User choice" show up.
I think what is happening is that you have chosen "Maximum" cut speed, so now it is trying to cut the root rib with the maximum speed that you specified for your table configuration. Since it is a tapered wing, the left wiresupport will have to move at a greater speed to achieve this, which is then above your specified maximum, hence the warning. Try "User choice" with a cut speed lower than max.
Max.
max z is offline Find More Posts by max z
Old Aug 19, 2006, 11:04 AM
Joined May 2006
well.. it kinda worked.. if I set the cut to manual and 0.2mm/s it will work, but it now will take 45 minutes.. is this way too long? There must be a better way
Old Aug 19, 2006, 11:09 AM
max z is offline
max z's Avatar
Joined Mar 2001
Have you checked your table configuration to see what max. cut speed is set at? Does it reflect the actual mechanical limitation of your drive?
Old Aug 19, 2006, 11:33 AM
Joined May 2006
yep.. that was it.. 400 steps and 2.54mm rod did the trick.. thanks man I overlooked it
Old Aug 19, 2006, 11:37 AM
max z is offline
max z's Avatar
Joined Mar 2001
Old Aug 20, 2006, 12:40 AM
OzDragonFlyer is offline
Find More Posts by OzDragonFlyer
Model Bender
OzDragonFlyer's Avatar
Australia, NSW, Newcastle
Joined Jun 2004
another solution... in foam configuration, slow down the max/min cutting speeds.. you will also have to reduce the heat to keep the kerf the same.
GMFC produces this error because it's trying to keep the wire above min speed (usually calced for the smaller tip chord). On tapered wings, the longer root chord needs to be cut faster, sometimes exceeding the machines velocity settings.
OzDragonFlyer is offline Find More Posts by OzDragonFlyer
Old Aug 20, 2006, 05:35 AM
max z is offline
max z's Avatar
Joined Mar 2001
OzDragonFlyer,
I had always thought that the min. and max. speeds specified under Foam Management were just for kerf compensation calcs, and the only restricting speed value is the max. cut speed under Table Configuration. Are you sure?
I have just tried to specify a ridiculous max. speed way beyond the table max. and the software happily accepts it. (I have not tried cutting since my machine is stored away right now).
Max.
Discussion Problem flying my wing on slope Gameness Slope 10 Jun 30, 2006 02:54 PM
Question Wing spacing on tapered-wing bipe? Bad Driver Modeling Science 1 Jun 04, 2006 08:20 AM
Wing problem on brand new plane Rodders 3D Flying 0 Aug 11, 2004 02:54 PM
Problem! Carbon fiber wing spar on slow stick new@this Parkflyers 8 Aug 30, 2003 11:59 PM
HELP! Wing warpage problem on my Wright Flyer... Carbine Scratchbuilt Indoor and Micro Models 1 Mar 03, 2003 06:39 PM
