Pittsburgh Allegheny, Pennsylvania, United States
Joined Feb 2004
btw i hate expo!! never used it, and trying it now is like learning to fly all over again! almost wrecked my buds geebee gasser this summer when he handed me the tx,me and expo do'nt go well together,i need to feel everything instantly from the git
Riot flights
Mine came out about 10 oz rtf with a 730 TP 3s pack, it was very pitch sensitive, set up as recommended with the CG about 1/8" behind nominal. Extreme roll rate at speed. I tried a 480 pack with the CG at max behind nominal and it was worse, very hard to control, nose up and very pitch sensitive. I decided then to put the CG at max forward, which took not only the speed control right at the nose, but a TP 1320 pack, AND 1/2 oz of lead. I'm now at 12 oz rtf with it ballanced. I'm using futaba S3110's and a corona 5oz receiver, so I don't see how I could have made it much lighter on the rear, and using the stock rimfire motor with 8x3.8. Now with the CG forward, it flies like a dream, especially with some expo on all controlls(40%). Not pitch sensitive, harriers at almost no forward speed, hovers, still with extreme roll rate. It's quickly now becoming my favorite plane. I used to hate it. I also have a flat-out CAP580 which can knife edge better(riot has a lot of coupling), and hover a bit better, but you can't drive the cap very fast without flutter, the riot can hover and harrier, but you can go to normal flyin speed and have lighting quick rolls and snaps
I finally decided to remove the wheel pants as they keep rotating under the wheels during flight and I wind up landing on them![]() Frank |
Latest blog entry: Spaceship One
Halfway through putting this together I thought this should be tried out as a light monoplane. So putting a 17gm MPJet motor on the front, AUW with 300mAh 2Spack is 150gm (about 5.3oz).
The winds are fairly gusty in Perth at the moment but I thought I would give it a go. The Riot is quite clean in the air so handled the wind well for such a light plane. It was just a little underpowered for hovering but otherwise this would fly pattern fairly well I think. Here is the video http://www.rcgroups.com/forums/showthread.php?t=640251 Now to stick the top wing on and put in a bigger motor. |
| Thread Tools | |
| Great Planes ElectriFly Mini Delta EP ARF | Dave Lauck | Product Announcements | 3 | Nov 25, 2007 10:53 PM |
| Great Planes ElectriFly Lancair ES EP ARF | Dave Lauck | Product Announcements | 3 | Nov 14, 2006 03:28 PM |
| New Product **NEW** Electrifly Riot 3D EP ARF | Mandy | Product Announcements | 0 | Aug 07, 2006 12:46 PM |
| Sold NIB Great Planes ElectriFly MINI DELTA EP ARF | punkindrublik | Aircraft - Electric - Airplanes (FS/W) | 5 | Jul 20, 2006 08:31 AM |
| Discussion **NEW** Great Planes ElectriFly XPD-8 EP ARF Jet & HyperFlow Ducted Fan Unit | Jim T. Graham | Product Announcements | 0 | May 30, 2006 10:48 AM |
