If this is your first rc plane make sure you have someone with you on a buddy box for your first few flights at least. This is not what I would consider a beginners airplane. |
Waco, TX
Joined Jan 2004
The only place I removed the covering from was the battery and rx access bays and the bottom wing where it joins the fuse. IMO thin or medium CA is more than enough to hold the diminuitive stab in place. This is a light plane and not necessarily a high speed one so I think the CA will hold just fine.
Griffin,GA
Joined Jan 2004
This plane sounds like it's extremely pitch sensitive. Eventhough you may have many hours flying the real thing RTFM, I don't think this will be a good first RC plane. If you do decide to learn on this plane, definitely make sure you do it with an experienced pilot on the buddy box with you, and with the rates turned way down. A lot of these 3D planes are very docile on low rates, but the verdict is still out on this one. I'm not trying to be discouraging. I and everyone else here just want to see you have a successful start into RC. Good luck and I hope you enjoy it.
Well..We are still deciding if we are flyin'or driving.... 2dogrc |
Latest blog entry: Drunk Reindeer Spotted
Joined Oct 2006
can any one please advise what is the average flying duration of riot 3d when equipt with towerhobbies mentioned electronics. As mentioned above papsmurf flewed for only 2 min if it is so it does not worth it 2 min are really hopeless no one can be satisfied for such a beautiful plane.
I guess the flight time depeds on your setup. I just got mine and i'm using the original great planes rimfire outrunner. With a 800mah Polyquest 20C pack I was getting 10 min flights easy. I used a 10x3.8 prop on it and it would haul around 12oz planes with ease. With this plane thought i'll probably go down to an 8" prop. My airframe weight so far is 4.5oz with 3 hs55's installed. I figure ~9.5oz RTF.
Waco, TX
Joined Jan 2004
There was an issue with the motor and ESC when I got the 2 minute flight. I recharged the battery and flew it later that day and got 8-10 minutes easily without reaching LVC. It was getting dark so I had to pack things up for the day. I checked my radio settings today and there was no expo on the elevator apparently. I am using an eclipse 7 and frankly it has too many buttons and flight programs sometimes it seems and I think I switched between one of the flight modes as I do remember programming the expo in. I will try again and see how much better it is. I was told by another person (who should know) that the plane is somewhat pitch sensitive at speed. I also have a LS de novo on the way I am going to try using in it.
flew my friends on the weekend its a great little plane!
his is 2204/54AXI powered and is amazing can do all the normal 3d stuff well. had a hard time knife edging it at first but added a bunch more expo to the rudder and its all better now. at high rudder travel there is a fair amount of roll coupling but at lower movements its fine. i would recomend if going light on the power system to move the servos up so the rudder is on the back of the bottom wing and the elevator on the side of the fuse about the same location. (will make it easier to get cg with tiny packs) great flyer just a little expensive for a 20" plane though. ededge2002 |
| Thread Tools | |
| Great Planes ElectriFly Mini Delta EP ARF | Dave Lauck | Product Announcements | 3 | Nov 25, 2007 10:53 PM |
| Great Planes ElectriFly Lancair ES EP ARF | Dave Lauck | Product Announcements | 3 | Nov 14, 2006 03:28 PM |
| New Product **NEW** Electrifly Riot 3D EP ARF | Mandy | Product Announcements | 0 | Aug 07, 2006 12:46 PM |
| Sold NIB Great Planes ElectriFly MINI DELTA EP ARF | punkindrublik | Aircraft - Electric - Airplanes (FS/W) | 5 | Jul 20, 2006 08:31 AM |
| Discussion **NEW** Great Planes ElectriFly XPD-8 EP ARF Jet & HyperFlow Ducted Fan Unit | Jim T. Graham | Product Announcements | 0 | May 30, 2006 10:48 AM |
