Old Aug 18, 2006, 01:12 PM
architorture is offline
Find More Posts by architorture
Joined Nov 2005
Eagle Tree RPM sensor placement
Does anyone use the magnetic RPM sensor from eagletree? Any pics of sensor placement?
I have one mounted (works fantastic by the way) on the aluminum piece that holds the top main shaft bearing and the magnet mounted in the mast collar. The problem I'm having is that since I chaged to hs-65's I've had to setup my head again and I'm only getting +/- 9 degrees because the washout block hits the main head if I increase the swash % any more.
I know I need to tighten the links on the swash to bring it down, but any further down and I will get an interaction with the rpm sensor! The thing that bothers me is that I've had full +/-10 degrees pitch with the hs-56's and RPM sensor, now I cant get it, what gives??
_________________
Trex 450SE V2
cc35/medusa 34-28-3400 3s tp2100
hs-65mg
Futaba401/9650
JR 6102pcm
architorture is offline Find More Posts by architorture
Old Aug 18, 2006, 07:02 PM
stall warning is offline
Find More Posts by stall warning
NE Pa
Joined Aug 2005
Put the magnet on the main gear.
It's easier on a Logo but do-able on the Rex. Look at the top gear. You could
slightly embed it in one of the spokes just before the plastic gets thicker near
the tooth ring. You may have to clearance the frame for the magnet.
I then goop the sensor to the frame.
Mine is the earlier plastic frame, yours may be different.
Ron
stall warning is offline Find More Posts by stall warning
Old Aug 18, 2006, 10:32 PM
Joined Nov 2005
Thanks, good idea, I may do that. I'm going to try rebuilding the head again to get clearance. Hope it works.
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Eagle Tree Systems 57 Apr 24, 2009 11:19 AM
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Product Announcements 13 Dec 28, 2006 04:50 PM
Article Eagle Tree Products GPS Expansion Module & RPM Optic Sensor Michael Heer Power Systems 4 Sep 12, 2006 01:19 PM
Discussion Eagle tree magnet mount for rpm sensor Jasonscott Mini Helis 0 Mar 18, 2006 01:10 PM
Multiple RPM Sensor Support from Eagle Tree Systems, LLC Dave Lauck Product Announcements 1 Nov 09, 2005 01:39 AM
