Aug 16, 2006, 07:50 PM
United States, NJ, Brick
Joined Jul 2005
- Hirobo Freya Eagle-SST Airframe -
- Hirobo Eagle-SST Freya Airframe - USED
This airframe has been built from my spare parts stash. Everything is clean, lubed and ready for you to dial in and fly.
Installed is the Delrin main gear, Hirobo stock tail blades and customized yellow tail stabilizers.
To fly this heli you'll need to install the following:
1. Engine/Muffler (60, if installing a 90 you'll need a different pinion gear since this airframe is geared for a 60-size)
2. Gyro
3. Servos
4. Receiver
5. Battery
6. 680 main blades
7. Canopy (Freya, EVO, Twister or Scale/FAI fuse)
Then setup all the links, do final setup and fire it up and fly this precision plastic-fantastic heli!
Reason: sold
