Old Aug 16, 2006, 01:23 PM
jaskew is offline
Find More Posts by jaskew
I want an eye in the sky.
jaskew's Avatar
Joined Mar 2005
Idea
(Completed!) Spektrum DX6 Trans. antenna replacement using 2.4GHz Wireless parts?
You don't have to look far to find many, many people posting around on the 'net how easily thier antennas broke on the DX6 transmitter.
There have been a few hints of people replacing the antennas themselves, i.e.:
Even just installing RP-SMA bulkhead is just a matter of getting a professionally built U.FL connector to RP-SMA bulkhead (15 bucks @ jefatech.com) which is a plug on the RF Deck same as you'd have a removeable antenna on your Dlink wireless router to use a different antenna to suit your coverage needs. All protected under Part 15.
(that's from: http://www.runryder.com/helicopter/t250254p3/ )
So, it can be done and apparently it is also legal (provided you do it privately and under quantities of 5).
Me, I'm sick of the issue and I want to put on a removalable antenna.
Best that I can tell, the following items would be needed:
U.FL to RP-SMA Female Bulkhead 12"
5.5dBi Rubber Duck Antenna
Any gotchas' with that? Is the 5.5dBi to high? Is the pigtail too long? What might I be missing in this equation?
If someone with any knowledge can tell me this might work and that it would be OK, I'm gonna do it, then I'll post the results.
And yes, I did dig all through the threads on the DX6, but I didn't find one specifcally targeting antenna replacement. If such a discussion does exist, I would love to see it.
jaskew is offline Find More Posts by jaskew
Old Aug 16, 2006, 01:27 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Mine broke at the hinge. Lots of duct tape fixed it.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Aug 16, 2006, 03:19 PM
birdlives1955 is offline
Find More Posts by birdlives1955
That thing's operational!
birdlives1955's Avatar
New Orleans/Dallas
Joined Jan 2006
I saw a friend accidentally break his the other day, it was really too bad. Strange how they made them so brittle.
-Matt
birdlives1955 is offline Find More Posts by birdlives1955
Old Aug 16, 2006, 03:59 PM
Frank Hurd is offline
Find More Posts by Frank Hurd
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Guys, I sure like an opinion on this!
This would be a great feature! Could you electronic genius' give us an opinion?
Frank
Frank Hurd is offline Find More Posts by Frank Hurd
Old Aug 16, 2006, 04:09 PM
dalbert02 is offline
Find More Posts by dalbert02
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
Many 2.4Ghz antennas here http://www.hyperlinktech.com/web/rub...antenna.php#24
dalbert02 is offline Find More Posts by dalbert02
Old Aug 18, 2006, 08:30 PM
jaskew is offline
jaskew's Avatar
Joined Mar 2005
Ordered parts
Well, since no one told me not to do it, I've ordered the parts.
I will update as things progress.
Old Aug 19, 2006, 02:44 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
12" of pigtail probably isn't going to be a problem, although in general with these things you should use the shortest pigtail that will work without strain. Make sure the pigtail doesn't foul the backs of the stick mechanisms. 5.5dBi will give you more range, but (and this is a big but) it will do that by reducing the coverage of the TX antenna, so you're going to have to be even more dilligent that usual at not pointing the antenna at the model. Keep it square broadside on as much as you possibly can.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Aug 19, 2006, 08:16 AM
TomLee is offline
Find More Posts by TomLee
Denver, CO.
Joined Feb 2006
Went to Nearson.com, got a 7dbi swivel with a 4" pigtail.I will be installing today and testing Monday. I bought the swivel so I can point the antenna down and avoid pointing the antenna at the model. I have been using a straight 5db gain with a 4" pigtail and found out if I pointed at the model, I could lose contact at 200 or 300 yards. Turning sideways to the model would regain control.
I was told I have a tendency to point the transmitter at the model as I am flying. By pointing the antenna down, that eliminates that problem.
I am flying glow (60 to 1/4 scale) with a 6102DX. newest airplane being a 120 Tiger with a 1/4 scale Laser (G2300) to follow.
TomLee is offline Find More Posts by TomLee
Old Aug 19, 2006, 10:04 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Andrew,
What would the spec be if looking for a screw-on antenna with the same performace as the original and is dBi the only important parameter ?
kgfly is offline Find More Posts by kgfly
Old Aug 19, 2006, 07:50 PM
Joined Jun 2006
The standard antenna is a 3dBi, and so long as you're buying omnidirectional antennas, the only things that matter are that it work at 2.4GHz (5.8GHz coverage won't hurt, but isn't relevant... lots of WiFi gear is dual band), that it fit mechanically, and the dBi gain. Anything from 2.4dBi to 8dBi should work ok, although the coverage area on an 8dBi is getting pretty narrow. Best to stick to 5.5 and under, really.
As for pointing the TX at the model... that's fine, so long as you have your antenna in the 90 degree up position. The best signal is always perpendicular to an omni (you aren't going to find one where that isn't the case that you'd think of using on a TX... downlooking omnis exist, but they're huge and expensive).
It is possible to use a 'patch' or 'yagi' directional antenna too, but that means you have to take care to always point the antenna at the model (square on for a patch, along the boom for a yagi). That could get massive range though, yagis come in up to 16dBi gain, at the expense of a 20 degree wide beam...
Old Aug 24, 2006, 10:19 AM
HowardSmith is offline
Find More Posts by HowardSmith
HowardSmith's Avatar
Whitby, Ontario
Joined Feb 2006
Any word yet? I just broke my antenna last night and am interested in doing this also.
Thanks.
HowardSmith is offline Find More Posts by HowardSmith
Old Aug 24, 2006, 01:29 PM
andy55 is offline
Find More Posts by andy55
Joined Jun 2005
I replaced the Rx antenna on a spektrum receiver with a piece of coaxial cable and I use a 3 dBi omnidirectional antenna, see
http://www.anderswallin.net/2005/10/...-modification/
I'm going to get a DX6 (as soon as find a european distributor with reasonable prices), and I'm interested in a TX antenna modification too.
Preferably one that positions the Tx antenna along the back of the Tx. That means that the whole tx can go inside my transmitter cover which can be completely sealed. this works very well for using the Tx in rain.
andy55 is offline Find More Posts by andy55
Old Aug 24, 2006, 05:22 PM
Joined Jun 2006
2.4GHz antennas don't work well close to other conducting objects (not without a lot of careful design, anyway), so that's not a good plan.
Old Oct 09, 2006, 06:39 PM
jaskew is offline
jaskew's Avatar
Joined Mar 2005
Finally added an
Ok, so it's been a few months, but I've added on an antenna. I used:
U.FL to RP-SMA Female Bulkhead 6"
from http://www.jefatech.com/
Doing the standard range test I got about 50 feet away before things started cutting out. Before I had troubles getting even the required 30 feets, so I'm quite happy.
Any questions?
Old Apr 02, 2008, 12:26 AM
loserdave is offline
Find More Posts by loserdave
Registered Loser
loserdave's Avatar
Joined Feb 2008
Hey Jaskew,
Did it work??
any better range??
loserdave is offline Find More Posts by loserdave
FS: 2.4Ghz Wireless 4 Camera system plus bonus remote control shschon Aircraft - Electric - Airplanes (FS/W) 0 Apr 16, 2005 12:52 AM
FS: 1x Used 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 Dec 06, 2004 11:46 AM
FS: 1x Used 1x New 2.4ghz Wireless video cameras with receiver Nik-rc Aircraft - Electric - Airplanes (FS/W) 4 Nov 30, 2004 06:21 PM
FS: Draganflyer IV w/2.4Ghz wireless camera Razmo Aircraft - Electric - Helis (FS/W) 6 Aug 19, 2004 09:30 AM
