Aug 08, 2002, 11:11 PM
United States, CA, Hidden Valley Lake
Joined Aug 2002
Battery Testing (Loading)
The best way to test a battery is to put a load on it and see if it maintains its voltage.
How much load?
My first guess would be so that it draws at its rated load. A 10 volt 1000mAh battery pack would use a 10 ohm resistor, r = e / i. Or would this be to much load?
Radio Shack sells battery checkers that put a load on the tested battery but I don't know how much load. What if your voltage isn't listed - a 4.6 volt receiver pack, useing the 6 volt setting could introduce a 25% error. The problems with these testers is the varied size, voltage and current, packs that are used by modelers.
This is brought about by my receiver battery going dead on the second flight Sunday (fortunately we were on approach when it happened). First test said fair, loaded test said DEAD.
I'm thinking about building a loader to put between my VOM and the battery. What are some of your thoughts and expieriences?
Thanks for your help,
Rick
