Old Jun 06, 2001, 05:52 PM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
What is wrong with my servo
If I move my TX stick to full output, the servo ofcourse moves full travel. But at the end of full travel it moves back a little bit. As if it overshootes the "stop" and then moves back.
The servo does that in both directions, and only at full movement of the TX stick. And Im sure its the servo, because i have two servos mixed together for my delta, and only one has this problem.
Why??? What´s wrong with it.?
Hope you understand what i mean, as my explenation might not be too good.
SJ is offline Find More Posts by SJ
Old Jun 06, 2001, 07:54 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I understand what you mean, that's quite odd, but does it do it only at speed?
..a
Old Jun 07, 2001, 04:50 AM
SJ is offline
SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
hmmm...
Just looked again. It only does this in one direction. And yes, it only does it when i move the stick quickly. If i move the stick slowly, the it works normaly.
Is something rotten inside my servo ?
Its a MS-X3
Old Jun 07, 2001, 07:38 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Just sounds like 'lag' to me. The little motor is spinning like crazy to get the arm there as quickly as possible, but it's overshooting a little, so it backs up to compensate. You probably won't (shouldn't) be using 100% of the travel anyway, so it shouldn't be an issue.
Just make sure there's no play in the arm in any position.
..a
Old Jun 07, 2001, 09:14 AM
Crete1 is offline
Find More Posts by Crete1
Okemos, Michigan
Joined Feb 2001
What servo brand is it? Hitech??
I've heard of something about Hitech servos from the LHS.. But I'm not suggesting that's the problem.
Crete1 is offline Find More Posts by Crete1
What is wrong with my Berg 5 DSP-II? dimple Radios 1 Oct 22, 2004 11:34 AM
WHatts wrong with My Servo? kushal_22 Radios 1 Feb 22, 2003 09:05 PM
What is wrong with my charger j8m8l Batteries and Chargers 5 Dec 08, 2002 11:51 PM
What is wrong with my zagi? mumboender Foamies (Kits) 7 Feb 26, 2002 03:31 PM
What is wrong with my FMS sim? e-flyer Parkflyers 4 Jun 15, 2001 06:38 AM
