n/a Posts
Re: Can I power my Li Poly charger from my computers PSU?
I used a spare molex to make a nice little 12v and gnd lead, and it
seams to work just fine. kenhatch@gmail.com wrote: > hrmm the charger says it needs 2.0 amps for optimal charging, will > 1.0amps be bad or just slow? > > kenha...@gmail.com wrote: > > I was wondering if I could attach the aligator clips from my charger to > > the 12v power coming from my computers power source? The 12v line is > > 12v@1.0a so it seems like it should work... but I dont want proceed > > without some confirmation... |
n/a Posts
On 14 Aug 2006 22:38:31 -0700, kenhatch@gmail.com wrote:
>hrmm the charger says it needs 2.0 amps for optimal charging, will >1.0amps be bad or just slow? > Whyat charger is it? Some will cope some won't, Eitherway a dedicated PSU is probably better. they go to 20A and you have less risk if it goes bang of wrecking something expensive >kenha...@gmail.com wrote: >> I was wondering if I could attach the aligator clips from my charger to >> the 12v power coming from my computers power source? The 12v line is >> 12v@1.0a so it seems like it should work... but I dont want proceed >> without some confirmation... |
n/a Posts
I was mistaken on the PSU amps 1.0a is its min amps 24a is its max.
Gavin wrote: > On 14 Aug 2006 22:38:31 -0700, kenhatch@gmail.com wrote: > > >hrmm the charger says it needs 2.0 amps for optimal charging, will > >1.0amps be bad or just slow? > > > Whyat charger is it? > > Some will cope some won't, > > Eitherway a dedicated PSU is probably better. they go to 20A and you > have less risk if it goes bang of wrecking something expensive > > > > >kenha...@gmail.com wrote: > >> I was wondering if I could attach the aligator clips from my charger to > >> the 12v power coming from my computers power source? The 12v line is > >> 12v@1.0a so it seems like it should work... but I dont want proceed > >> without some confirmation... |
n/a Posts
<kenhatch@gmail.com> wrote in message
news:1155620013.862133.156940@i42g2000cwa.googlegr oups.com... >I was wondering if I could attach the aligator clips from my charger to > the 12v power coming from my computers power source? The 12v line is > 12v@1.0a so it seems like it should work... but I dont want proceed > without some confirmation... I would strongly discourage you from trying this on a PSU still attached to a computer. However, you can modify an old PSU into a dedicated power supply. I have built several myself as has a friend, they are reliable and (with the right rating) can easily supply all but the hungriest of chargers. For most PSUs you will need to load the 5V side in order to generate the right voltage on the 12V side. Please, do not try to hack into a spare lead on your computers power supply. Get yourself an old supply and then modify it to suit. -- The Raven http://www.80scartoons.co.uk/batfinkquote.mp3 ** Now I will bring chaos to the world! |
n/a Posts
> I was wondering if I could attach the aligator clips from my charger to > the 12v power coming from my computers power source? The 12v line is > 12v@1.0a so it seems like it should work... but I dont want proceed > without some confirmation... > Can be made to yes, as long as you have a charger in between :-) I considered this, but looked at the hassle factor, and in the end bought an ex CB PSU off ebay 13.8v/10A. For a time I ran a clapped out tractor battery and a trickle charger in the den, but it was nasty and brutish,. It worked though. |
n/a Posts
It should work fine, many of us are using converted computer power supplies
to run our chargers. -- Red S. Red's R/C Battery Clinic http://www.rcbatteryclinic.com Check us out for "revolting" information. >> >> I was wondering if I could attach the aligator clips from my charger >> >> to >> >> the 12v power coming from my computers power source? The 12v line is >> >> 12v@1.0a so it seems like it should work... but I dont want proceed >> >> without some confirmation... > |
n/a Posts
Boy, you would call me on that. From memory it is a low ohm, high wattage
resistor. http://www.marcee.org/Articles/PCPowerSupply.htm http://web2.murraystate.edu/andy.bat...owersupply.htm Look at these links. mk "Ed Smega" <smega@en.com> wrote in message news:12e4hhfg3798h14@corp.supernews.com... > What value resistor? > > I am using an old compuer power supply and didn't know about the resistor > on the 5 volt supply. > > Ed > > > > "Storm's Hamilton" <htcomp.net@storms> wrote in message > news:12e455dlmdepd7a@corp.supernews.com... >> I've done that. works well. I bought a power supply at Goodwill for $8 >> and put a resistor on the 5V wires Orignally used to power a TRriton, now >> has posts to clip to and auto plugs for other things and a ciggy lighter >> hole for those sorts of things. >> mk >> >> <kenhatch@gmail.com> wrote in message >> news:1155620013.862133.156940@i42g2000cwa.googlegr oups.com... >>>I was wondering if I could attach the aligator clips from my charger to >>> the 12v power coming from my computers power source? The 12v line is >>> 12v@1.0a so it seems like it should work... but I dont want proceed >>> without some confirmation... >>> >> >> > > |
n/a Posts
From Ed=A0Smega:
>What value resistor? > >I am using an old compuer power supply >and didn't know about the resistor on the >5 volt supply. I use a 10 ohm 10 watt 'sandblock' resistor. It runs pretty hot and needs plenty of ventilation. It was bought at RS several years ago, and presumably is still available there. Here's a good article on the subject - http://web2.murraystate.edu/andy.bat...OWERSUPPLY.HTM Dunno if it's typical of all PSUs, but in this old one I have there's an adjustment pot that allows bumping the 12 volts up a bit, to 12.6V for a little more 'headroom'. Bill(oc) |
| Thread Tools | |
| Question Smart Plus 2cell-5cell Li-poly Charger from Komodo Hobby | bass3587 | Batteries and Chargers | 2 | Mar 26, 2006 01:31 PM |
| Question my li-poly charger that came with battery isit ok or not ???? | helli crashed | Batteries and Chargers | 2 | Jun 06, 2005 04:28 PM |
| Rant darn...my my kokam li-poly battery does not fit in my li-poly charger | kahuna_socom | Batteries and Chargers | 4 | Aug 22, 2004 04:42 PM |
| Regulated dc power supply a li-poly charger? | Hodgepodge | Batteries and Chargers | 2 | Aug 05, 2003 11:16 PM |
| Can I use my car battery charger to drive my Hitec Peak charger? | Snitch7 | Batteries and Chargers | 9 | Jan 21, 2003 06:58 PM |
