Old Aug 14, 2006, 07:57 AM
Bad Attitude is offline
Find More Posts by Bad Attitude
more time to fly !!!
Bad Attitude's Avatar
Asti, Italy
Joined Apr 2004
Multiplex EasyGlider Thread 3
Part 1 : New from Multiplex EasyGlider
Part 2 : Multiplex EasyGlider Thread 2 - A New Saga Begins
May the lift be with you!
Piero
Bad Attitude is offline Find More Posts by Bad Attitude
Old Aug 14, 2006, 08:41 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Up&Away checking in!
Up&Away is offline Find More Posts by Up&Away
Old Aug 14, 2006, 08:45 AM
iceman3 is offline
Find More Posts by iceman3
Norway
Joined Mar 2005
Only checking
iceman3 is offline Find More Posts by iceman3
Old Aug 14, 2006, 11:13 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Ok, I am in as well. Not to much in the way of current pics. In any case here is where I am at right now.
TeamTEOR is offline Find More Posts by TeamTEOR
Old Aug 14, 2006, 11:15 AM
darenm is offline
Find More Posts by darenm
Fly
Alamogordo, New Mexico, United States
Joined Apr 2002
Just placed my order for a EG from Tower. Time to follow the Threads.
darenm is offline Find More Posts by darenm
Old Aug 14, 2006, 02:15 PM
crazy pilot is offline
Find More Posts by crazy pilot
Just checking gravity...
crazy pilot's Avatar
Farmington, MI, USA
Joined Jun 2005
I still have no luck with my EGE... Looks like a great plane but I just can't get it to fly right.
My last attempt ended in a nasty crash... the whole nose was smashed luckily motor or the prop was undamaged. Just now looking over the glider again I decided to cut the whole nosepiece of and see where I can go from here.
And I guess I just forgot how to fly a glider because it appears to be a lot harder for me then a 3d foamy or anything else because the response is just so slow and it stalls just so easily, or maybe its just not trimmed right...
I am thinking of mounting a motor just like I am holding it up in the picture, it would be simple strong and easy to access but ugly and I am not sure how much it will affect the aerodynamics, would the extra drag reduce the performance a lot?
Any advices are much appreciated
crazy pilot is offline Find More Posts by crazy pilot
Old Aug 14, 2006, 03:20 PM
mem is offline
mem
Find More Posts by mem
mem
mem's Avatar
London, UK
Joined Nov 2005
Subscribing…
mem is offline Find More Posts by mem
Old Aug 14, 2006, 05:13 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
You could probably make a nice cowl from a piece of soda pop bottle to improve the looks and aerodynamics. With respect to the slightly increased drag without such a cowl: shouldn't hurt. I have a motor on a pylon behind the wing, and a huge lumpy camera carrier sitting on the nose like some sort of rhinoceros. Those two changes certainly increases drag, but the thing flies beautifully.
Arthur P. is offline Find More Posts by Arthur P.
Old Aug 14, 2006, 06:05 PM
Farmington, MI, USA
Joined Jun 2005
Ok thanks, I decided not to make a crawl.
Anyway here's what it turned out like. I just guessed on the down thrust so I hope I got it right.
Old Aug 14, 2006, 06:27 PM
Farmington, MI, USA
Joined Jun 2005
Another small question.
Does anyone have a problem with wings not staying firm in place? Mine seems to be moving a bit and I was wondering if there is a way to secure them besides glue. If not I think ill just CA them in there.
Old Aug 14, 2006, 10:59 PM
TeamTEOR is offline
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Crazy Pilot: I think you could put a layer or two of packing tape to build up the part of the wing that slips into the fuse.
As for my build. I am getting a little cogging with the motor, and I am wondering what that could be from. I pulled it out of the nose becuase I was also tired of all of the vibration that I was getting, something is just wrong. I did note that the pinion gear needed to be pulled forward about 2mm, so I did that and added a little more locktite to the shaft. After the locktite sets (in the morning) I will check to see if it is a problem with the setup vibrating at the gearbox or at the prop. First I'll reassemble it back together, then I'll spin up things with no prop installed. If there is no hint of vibration I will use a collet style prop adaptor/saver and put on a different prop to see if that vibration appears. Maybe it is time to get a second gearbox setup as the first could just be defective or else a better motor/gearbox setup will be in order. Is anyone packing their gearbox with any type of grease (maybe that is part of my problem as well, as I didn't add any)?
On another note my 20c (30c burst) 3s740 Kokam pack fits inside the fuse without modification. Maybe I can order up a 3s2p pack to fit in there.
Update***
I just noticed that one of my 3 motor wires was rubbing on the can as it spun, and it took some insulation away, maybe the motor was cogging as the motor can could have been getting some type of charge? Ok, It is time to change the motor choice for sure. I have to look at an outrunner that has its motor can protected so that there are no more issues like that, or an inrunner. I just need to try to continue to keep the cost down.
Old Aug 15, 2006, 02:44 AM
CANTZ506 is offline
Find More Posts by CANTZ506
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Can you reverse the motor and install it inside the fuse?
It will be more protected and there is enough room for the wires to run away from the bell.
No improvement from the aesthetic point of view, of course!
Put some tape around the wing's root.
Piero.
CANTZ506 is offline Find More Posts by CANTZ506
Old Aug 15, 2006, 08:41 AM
DACeller is offline
Find More Posts by DACeller
Joined Jun 2005
Mem,
Thanks for the suggestion; the tape would actually 'bend' the fuselage a bit thus effecting a decalage change....
Yes, I read that discussion. Someone suggests removing ALL the decalage and moving the CG back to 80mm as the optimal. I would like the tool used to determine when I have removed it all, really. I would agree that at least this is optimal. I'm not sure about the CG, but I don't think you can do it until the other if you want positive results.
I traditionally use the hand toss on neutral controls, but down-wind, to check for CG looking for the longest glide and adding/removing weight to accommodate. This works well for me and subsequent in-flight tests for same haven't caused me to change those results. Downwind because I don't get that ballooning-on-intial toss-with-nose-dive and get the plane to stay in the air longer so I can observe its flight. With a proper zero delcalage, I would redo the CG most certainly, and then see where it winds up...
(As I stated, I attempted to remove the negative Decalage before first assembling the plane; This was done strictly by guessing, but now I need "UP" elevator. So I actually went too far because my plane dives rather than ascends. I actually need to move the ELE leading edge down a bit to "zero" out the positive decalage. Again, a tool is what's need in order to measure to do this correctly.) Anybody? Ideas?
DACeller is offline Find More Posts by DACeller
Old Aug 15, 2006, 10:33 AM
mem is offline
mem
mem
mem's Avatar
London, UK
Joined Nov 2005
DACeller,
If you are looking for an incidence meter, then here are two that are available:
http://www2.towerhobbies.com/cgi-bin...?&I=LXET66&P=M
http://www2.towerhobbies.com/cgi-bin...?&I=LXPW71&P=M
Old Aug 15, 2006, 11:09 AM
Bohh33 is offline
Find More Posts by Bohh33
Thermal seeker
Bohh33's Avatar
Brunswick, Ohio
Joined Jul 2005
Just subscribing. Still have mine in the box waiting to be put together.
Bohh33 is offline Find More Posts by Bohh33
Discussion Multiplex EasyGlider Thread 2 - A New Saga Begins Bad Attitude Foamies (Kits) 2526 Aug 14, 2006 08:03 AM
Yippee! Multiplex EasyStar thread - Part 3! tim hooper Foamies (Kits) 496 Apr 08, 2004 05:40 AM
Esprit's Zombie thread #3 geng High Performance 39 Mar 12, 2004 10:12 PM
Multiplex EasyStar thread - Part 2 tim hooper Foamies (Kits) 502 Mar 11, 2004 05:10 PM
thatovalguy Bird Dog thread #3 Thatovalguy Foamies (Kits) 499 Mar 11, 2004 12:12 AM
