Old Aug 13, 2006, 12:02 AM
Photon is offline
Find More Posts by Photon
Ph.D in Depronology
Photon's Avatar
Armageddon
Joined Aug 2004
Twinax v2
After my original creation, about 18 months ago, it's time for version 2.
The changes from the original (http://www.rcgroups.com/forums/showthread.php?t=351795) are:
1. Wider wing tip and more wing area, better low speed behavior
2. Wider gap between the booms. Larger prop
3. No landing gear, lower airframe weight
4. More power (always good)
5. Added airscoop and evacuation path through fuselage.
Maidened this morning in almost zero wind. Slight trimming was needed and then I tried some tight loops, rolls, dives, gliding. Everything done very nice.
The 150W/lb gave enough power for some unlimited vertical.
Due to air scoop, all components were cool to the touch after a 5 minute flight mostly at WOT. Only motor was warm (around 40 degree C, 110F)
Specs:
Weight 420g (14.8oz)
Span 39"
Wing loading 10oz/Ft^2
Motor: Himax 2812-0850
Prop: APC 9x7.5 SF
ESC: Jeti Advance Plus 18
Battery: CommonSenseRC 3S 1650mah 10C
Servos: 3x GWS Pico+F/BB
Current at WOT: 15A
Thrust : Weight: >1
Photon is offline Find More Posts by Photon
Old Aug 13, 2006, 12:18 AM
Photon is offline
Ph.D in Depronology
Photon's Avatar
Armageddon
Joined Aug 2004
Here are the new plans for this one.
CG should be on the carbon spar initially.
Old Jun 23, 2009, 09:24 PM
Kronikpilot is offline
Find More Posts by Kronikpilot
BOXFUSE KING!
Kronikpilot's Avatar
NO WIND CITY GUAM U.S.A
Joined Jan 2009
since no one pick-up on this awesome build I decided to build one. I modified some parts to give it a different look!
heres what I got so far. SCHOOL GETS IN MY WAY EVERYTIME I START A NEW BUILD!
mayday.
Kronikpilot is offline Find More Posts by Kronikpilot
Old Jun 23, 2009, 09:44 PM
Hopalong X is offline
Find More Posts by Hopalong X
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Mayday
Looks good. Keep us posted.
Hopalong X is offline Find More Posts by Hopalong X
Old Jun 24, 2009, 06:34 AM
BOXFUSE KING!
Joined Jan 2009
thanks Mike, electros installed I will post pics tomorow and hopefully a flight report.
set-up:
2s rhino 1050mah.
3000kv hxt motor
6x4 pusher prop
18 amp ss esc.
I ran up the motor with these set-up and it looks like unlimited vertical is a piece of cake put her nose againts my palm @ full power she was pushing hard.
mayday.
Old Jun 24, 2009, 06:06 PM
BOXFUSE KING!
Joined Jan 2009
Yipppeeeee! shes a floater! awesome slow flight characteristic can be use as a trainer. The electros were perfect (12min. floating around flight). I remove the motor and use the battery as ballast and I was sloping like a champ! I was surprise no one really try to build this one, I've always wanted a small glider/sloper and I found my love. I will be painting her and post some pics.
happy soaring/sloping!
mayday.
Old Jun 24, 2009, 06:32 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Glad she flys well.
I might have to cut some foam Friday.
If you get some video that would be great also.
If your like me you have no one to run the video camera.
Happy flights.
Check with you later for more pics.
Old Jun 25, 2009, 05:11 PM
BOXFUSE KING!
Joined Jan 2009
Hey Mike build one you won't be disappointed! I finally got me a decent sloper/glider v.s buying THE FLING from TH. It's a simple build and shes got alot of room for flight improvements. I put the battery hatch on the bottom to keep the canopy slick for sloping. I also added CF brace on the wing to the boom so I can do dives and simple aerobatics .(not needed for glider config). no wing flex set-up: I use 6mm cf spar, I cut the wing all the way thru and glue the spar without cutting it.
here are the pics for now and I will post flight vids when I get a chance.
happy flying.
mayday.
Old Jun 25, 2009, 05:55 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Looks great.
The coloring should help you keep track of her in the air.
Great job!
The in air pics with the red nose and tails make it very easy to make out orientation.
Old Jun 25, 2009, 07:40 PM
BOXFUSE KING!
Joined Jan 2009
Originally Posted by Hopalong X
Looks great.
thanks MIKE great minds think alike. yeah the paintjob is more for orientation, she can get small really fast even with the 2s set-up. I will be adding more details on the tail side today, will post pics and maybe flight vid asap. I'm glad you like it.
mayday.
Old Oct 14, 2009, 01:22 AM
hwat rc is offline
Find More Posts by hwat rc
Australia, QLD, Maleny
Joined Jul 2009
i'm thinkin of building this one mayday (great design) but plz post a video
Henry
hwat rc is offline Find More Posts by hwat rc
Old Oct 14, 2009, 03:45 PM
anthiee is offline
Find More Posts by anthiee
Joined Jan 2009
Seems to be an awesome plane :P. I've decided some month ago to build this airplane - it's my first... I had minor problems with cutting the depron gluing them together nicely, familiarizing myself with the materials... Basic stuff I'm not experienced with but if I don't make these parts well, the plane might be a nightmare... The rods are done and the motor will be mounted soon.
I included some pix.. give me your opinion
Anthony
anthiee is offline Find More Posts by anthiee
Old Nov 21, 2009, 07:34 PM
dynomike75 is offline
Find More Posts by dynomike75
dynomike75's Avatar
kalispell montana
Joined Nov 2009
just built one of these at 48" anyone want to see it before i maiden tommorow
dynomike75 is offline Find More Posts by dynomike75
Old Nov 21, 2009, 11:16 PM
dynomike75's Avatar
kalispell montana
Joined Nov 2009
here the are anyway
Old Nov 22, 2009, 06:18 PM
BOXFUSE KING!
Joined Jan 2009
dynomike I want to see the pics, hope the maiden turns out good. This bird is an awesome flier and it really look good in the air.
mayday.
