Old Aug 07, 2002, 08:46 PM
RB is offline
RB
Find More Posts by RB
RB
Buford GA
Joined Jul 2001
Where did all the Lite Stiks go ??
I stay away for two months and poof, they are gone. I just did one up like Covey's article but I cut ailerons into the wing. It flys pretty good. I glued the wing onto the stick and should have raised the leading edge app 1/8". Trimmed out the elevator is up about 3/16" which adds drag.
It will fly inverted and will almost do a loop, kinda falls out at the top. Easy to fly in a small area.
I am using a GWS 10x8 cut down to 9". About 10mins WOT on 6x350 sanyo.
Ray
RB is offline Find More Posts by RB
Old Aug 07, 2002, 10:48 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
I have moved on to the Mini-Max, it is the same price, but a much better and reliable motor is included.
zagisrule! is offline Find More Posts by zagisrule!
Old Aug 09, 2002, 06:26 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
mini lite stick
I cut miy LS down but kept the same size rudder and the same motor.
With a 9x7 prop and a 8 cell 300MA nih pack it goes vertical..a real hot to fly in a small field.
poobs is offline Find More Posts by poobs
Old Aug 09, 2002, 07:07 PM
NightSwan is offline
Find More Posts by NightSwan
Hmm, kerosene... :)
NightSwan's Avatar
Weert(LB) - the Netherlands
Joined May 2002
I've converted mine to a mini-lite stick with ailerons.
GWS-DX-1 gearbox with 8x6 prop and qualcomms.
Mighty long flight.
Lot's-a-fun (tm)
NightSwan is offline Find More Posts by NightSwan
Old Aug 09, 2002, 08:04 PM
RB is offline
RB
RB
Buford GA
Joined Jul 2001
I finally took a pic.
I hope to fly it some more this weekend. Sugar Hill Elem if anybody in the Atlanta area wants to meet up Sat or Sun evening.
Ray
Old Aug 09, 2002, 08:06 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Maybe next one (?)
Mine is too beat up to endure the surgery to convert to ailerons
Maybe the next one
This is another little flyer inspired by LS. It ues the GWS A motor/gear, a 9x7 prop but it is a bit lighter than the mini LS
Old Aug 09, 2002, 08:13 PM
RB is offline
RB
RB
Buford GA
Joined Jul 2001
I need to do some scratch building. I bought a bow for cutting foam cores and have not used it yet. I would like to try a delta slowflyer for the GWS DX.
For a slow{ish} flyer the 1/2" pink foam should work. That is the thickest I have found in GA
Ray
Old Aug 09, 2002, 08:36 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Where's the time gone?
I split a bundle of pink blu cor foam ( is there such a thing?) with a friend over a year ago. I still haven't built anything with it.
Old Aug 10, 2002, 07:40 AM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
LightStik
This one goes EVERYWHERE with me. S-2 gearbox, 7/6 prop, and seven 280 NiMHs. It's a rocket. Loop from level. My photo.
sr71fan is offline Find More Posts by sr71fan
Old Aug 10, 2002, 08:37 AM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Me too ailerons :)
I like what RB did with his....I went to the garage this morning and started eyeing mine for posible ailerons. The major obstacle are the skewer spars that are glued to the trailing edge.
I would have to tear them off and glue them forward of the aileron hinge line.
I'll post pics if I decide to go for the mod.
Old Aug 10, 2002, 05:58 PM
RB is offline
RB
RB
Buford GA
Joined Jul 2001
I have seen another Lite Stik that had some depron ailerons added to the trailing edge. He cut the scallops off to make the TE straight.
When you cut the ailerons out of the wing like I did you end up with a poor hinge setup because the wing is not flat. It works but it is a little stiff until the tape loosens up in the "valleys" of the wing surface.
Having the wing be stiff is one of the things I wanted to accomplish with this plane. The stock wing mounting setup allows the plane to just mush out of any high G maneuver.
I did my original Pico Cub stik per Don Stackhouse. The polyedral works great for a rudder/elevator plane but the flexy wing mounting detracts from the enjoyment.
We need to devise a simple and light method of attaching the wing that will allow for some give in the event of a crash.
Ray
Old Aug 10, 2002, 06:23 PM
Kidknight is offline
Find More Posts by Kidknight
Addicted to Feigao...
Kidknight's Avatar
Lakewood, CA
Joined Sep 2001
Holes Anyone???
Mine has cutdown wings, larger tailfeathers, night lights, and the stock motor. Did I mention holes?? They took out a little more than 1/2 an ounce, but the weight was added back when I put in carbon rods(doesn't matter, had to do it anyway ). Weighs 5.6 oz. w/out battery, 7.5 with lithium. In it's day, I was able to pull off inside/outside loops as well as inverted flight (didn't expect it to be so hard w/out ailerons). Now it's just on display, waiting for the next flight...
Kidknight is offline Find More Posts by Kidknight
Old Aug 10, 2002, 07:27 PM
Gonflyin01 is offline
Find More Posts by Gonflyin01
Toledo Ohio, USA!
Joined Dec 2001
I got a pico stick a while back. Stock, can it loop? or will i pop out my wings?
Gonflyin01 is offline Find More Posts by Gonflyin01
Old Aug 10, 2002, 07:30 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Stock it flexes a lot.
It might loop if you dive first
Old Aug 10, 2002, 07:31 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
This is the wing before I yanked out the rear skewer spars.
Herb! Where did all the Mig 15 pictures go? Goneflyin Electric Ducted Fan Jet Talk 1 Nov 02, 2009 12:44 AM
Help! Where Did All The Slow Sticks Go ? RonJ GWS (Grand Wing Servo) 1 Mar 19, 2007 04:42 PM
Where did the new creations thread go??? Steve H. Vendor Talk 14 Jul 18, 2001 12:14 AM
