Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Aug 10, 2006, 09:51 AM   #1
isoarthenland's Avatar
Jart - Old School
Can there ever be enough Jart Build threads?
I can't say I'm new to sloping, I was doing it back in the 70's in Seattle with a Dodgson Design Todi...4 channels...rudder, elevator, ailerons, flaps, flaps to elevator mixing....all mechanical, no electronic mixes....but I degress...
I recently moved from Seattle to within a few minutes of Point of the Mountain in Utah and have been lurking around the RC Groups Slope site for a few months now. I submitted an entry to the SDCC thread, but really wanted to build a Jart, so I have abandoned the SDCC plane http://www.rcgroups.com/forums/showthread.php?t=527662
My TD flying has been limited since I live so close to POM, and frankly, flying a 3.7 meter Sharon F3J on such a great slope is getting a little boring...I need something FAST and for BIG AIR
Here are the things that took me down the built-up Jart path:
1) Picked up a lot of skills building 2 Harley Michaelis Genie LT/S TD planes a couple years ago and wanted to try them on something else http://genie.rchomepage.com
2) I had some left over materials from the Genie builds.
3) I wanted to have removeable stabs and wings
4) It didn't look like anyone has done it.
5) My new shop is mostly done and I wanted to put it to work
What to call it?
Jart-to-go
Jart Lake City
Have Jart, will travel
Crunchie Jart
I'm a ways into it because I didn't know if there would be any interest, but I decided to go ahead and put it out there just in case.
Russ
isoarthenland is offline Find More Posts by isoarthenland   Reply With Quote
Old Aug 10, 2006, 10:39 AM   #2
Fuse materials:
1/16 Ply sides
.014" x 2" x 36" thick uni-carbon laminate http://www.acp-composites.com/acp-ucfl.htm - Side doublers
1/8" bulkheads
Basswood block - pointy nose
1/2" balsa planks
  • Name: Fuse-01.jpg
Description: Draw outline of fuse "box" 1/4" smaller than plan Draw outline of fuse "box" 1/4" smaller than plan 25.4 KB · Views: 251
  • Name: Fuse-02.jpg
Description: Cut out sides and stick to 1/16" plywood Cut out sides and stick to 1/16" plywood 39.8 KB · Views: 160
  • Name: Fuse-03.jpg
Description: Here's that uni-carbon laminate...nice strong stuff (not quite old school)  These will be epoxied to 1/16" ply sides----strong Here's that uni-carbon laminate...nice strong stuff (not quite old school) These will be epoxied to 1/16" ply sides----strong 91.2 KB · Views: 177
  • Name: Fuse-05.jpg
Description: Hmmm, a little skinny Hmmm, a little skinny 48.8 KB · Views: 199
  • Name: Fuse-04.jpg
Description: Laminated ply and carbon Laminated ply and carbon 41.1 KB · Views: 152
  • Name: Fuse-04a.jpg
  • Name: Fuse-04b.jpg
Old Aug 10, 2006, 11:01 AM   #3
slopemeno's Avatar
Send a message via AIM to slopemeno
Cellulo-Jart...? nah.
Have you ever seen Reeds FU-2? It was sort of a pre-proto-Jart, and it was a balsa fused plane, though the glass reinforcements probably outweighed the balsa by a 2-to-1 margin. So its totally do-able, just try to keep the weight in the same range.
slopemeno is online now Find More Posts by slopemeno   Reply With Quote
Old Aug 10, 2006, 11:11 AM   #4
PNF
infopimp's Avatar
No.
infopimp is offline Find More Posts by infopimp   Reply With Quote
Old Aug 10, 2006, 11:13 AM   #5
I haven't seen the FU-2...I'll keep the weight thing in mind. The fuse, when ready, will have 2 layers of 3/4oz glass layed on with poly resin.
Old Aug 10, 2006, 12:44 PM   #6
slopemeno's Avatar
Go heavier. 2 layers of .75 oz will be fairly easy to punch through. I would PM Reed and ask him what he used on the FU-2, and maybe go a little lighter if you are concerned about overall weight.
Old Aug 10, 2006, 12:55 PM   #7
I just looked back on my Genie instructions and it actually calls fo 1.5oz glass. My Genie fuse survived a 100ft straight in crash into hard-packed dirt without issue last year at Visalia. The fuse is 3/4" wide at the point where the fin starts.
  • Name: GenieFuse.jpg
Description: Back end of Genie fuse...single edge blade shown for size Back end of Genie fuse...single edge blade shown for size 18.5 KB · Views: 196
Old Aug 10, 2006, 01:36 PM   #8
slopemeno's Avatar
I think (and this is just one guys opinion..take it for what its worth) you'll end up under weight, and then be tempted to add weight, and there goes the durability. Shoot for at least 45 oz weight once done. Reeds is 55? oz and it rips. You have the hills and wind.
Old Aug 10, 2006, 02:20 PM   #9
I've got to get over my "lighter is better" TD mentaility. It cracks me up when I see bondo being slathered on these small planes. I wonder what the fuse should weigh without radio gear?
Old Aug 10, 2006, 03:55 PM   #10
I made some bulkheads out of balsa to experiment with thickness and adding holes for my balast tube and radio gear wires. When I thought I had them right, I made them out of 1/8" ply.
  • Name: Fuse-06a.jpg
  • Name: Fuse-06b.jpg
Old Aug 10, 2006, 03:57 PM   #11
slopemeno's Avatar
Swag here, but I would say 36-38 ounces for the bare airframe.
Old Aug 10, 2006, 05:20 PM   #12
Site Sponsor
Reed's Avatar
Love this build! Funny, I was just thinking as I woke up today that I should do a built-up JART thread. Now I don't have to! Great stuff, Russ.
slopemeno has good advice here - shoot for 45oz and you'll have a very versatile medium/big air machine. She's all about speed, so keep the nose down and let her run.
Reed is offline Find More Posts by Reed   Reply With Quote
Old Aug 10, 2006, 05:35 PM   #13
Genie Builder
greyhound flyer's Avatar
Looks good, Russ. But why does that Genie have all those extra formers?
greyhound flyer is offline Find More Posts by greyhound flyer   Reply With Quote
Old Aug 10, 2006, 06:03 PM   #14
find me @samotage
samotage's Avatar
Go Russ!
How about Jart-OSV (Old Skool Version)?
Sam.
samotage is offline Find More Posts by samotage   Reply With Quote
Old Aug 10, 2006, 06:48 PM   #15
Reed...I'll take all the advice I can get!
Greyhound...apparently these little slope planes go really fast, which means, I suppose, that they land fast too ....hench the extra formers
Sam...I've been lurking around your Jart build....when I grow up I want to make a Jart just like yours
Video Old School Jart - Build and Fly isoarthenland Airplanes - Sailplanes Videos 11 Nov 26, 2006 11:37 PM
Discussion Old School Jart Video isoarthenland Slope 29 Oct 16, 2006 12:09 AM
Pietenpol from Old School R/C J Bergsmith Scale Electric Planes 59 Jun 14, 2002 12:42 AM
LiteFILM available from Old School R/C for online ordering Oldschoolrc Aircraft - Electric - Airplanes (FS/W) 2 May 22, 2002 10:27 AM
Pietenpol from Old School R/C J Bergsmith Parkflyers 2 Apr 07, 2002 03:38 PM
11
