Old May 21, 2001, 07:16 PM
Flyer103 is offline
Find More Posts by Flyer103
Flyer103's Avatar
United States, GA, Maysville
Joined Oct 1999
R/C Guillow's B-24
Hi folks,
Does anyone have any experience with very small geared electric motors intended for free-flight models? Ideally I would like to turn props no larger than 5" in diameter.
I'm considering building the Guillow's B-24 for R/C. I already have the kit, and, much to my pleasant surprise, it came with very nice light wood.
My general thinking is to go for the bare minimum weight, using stick & tissue type construction and eliminating the landing gear. As I understand it, some of the smaller units from HiLine are intended for models of about 50 square inches and operate on 2 cells. If that's the case, four of them should be about right. Wired together in series four of them should work well with a typical 8-cell slow-flyer pack. But I have no direct experience with this type of motor, with the exception of the little direct drive unit sold by Kenway which powered a peanut scale FF with excellent results.
Any thoughts?
Gene
Flyer103 is offline Find More Posts by Flyer103
Old May 23, 2001, 05:01 PM
Flyer103 is offline
Flyer103's Avatar
Joined Oct 1999
Ralph,
Thanks for all the great info! Question: What is the diameter of the Gunther prop you're using? I need to be at or below a 5" diameter or the blades may not clear. The B-24 is 1/28th scale!
Thanks again 8-)
Gene
Old May 23, 2001, 05:05 PM
Flyer103 is offline
Flyer103's Avatar
Joined Oct 1999
Ralph,
One more question please: Have you tested your setup on 4 cells? The reason I ask is that my ultra teeny tiny ESC is rated for 8 cells max. I'm wondering if it would be possible to run a combined parallel/seriers arrangement (two parallel motor sets in series)
Gene
Old May 24, 2001, 04:35 PM
ChuckHHill is offline
Find More Posts by ChuckHHill
Concord, CA, USA
Joined Dec 2000
The Gunther prop is 125mm x 110mm or about 4.9" x4.3"
I think the total wing area is around 220 sq inch. I hope to do a Guillows B-17 some day.
Chuck Hill
ChuckHHill is offline Find More Posts by ChuckHHill
Old Jun 01, 2001, 05:38 PM
Flyer103 is offline
Flyer103's Avatar
Joined Oct 1999
Ralph,
Sounds good. The only thing that concerns me is that I have never built a gearbox from scratch. Do you have any diagrams per chance to get me started?
Gene
Old Jun 04, 2001, 09:29 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
There might be a lazier approach- try the HY-50F motors which come with a gearbox and are set up with a 5" prop. Dead nuts easy to install- drill one hole and you're done. They sell for about $20 apiece at Cloud 9 R/C. The motors work on up to 6 cells NiMH, and probably draw about an amp or less. I've been using one in a Skylark on a 6 cell, 140 mAH NiMH pack and I like it- I bought more. I've been contemplating an F7F twin.... I don't recommend the HiLine stuff for this purpose - those motors were intended for FF and go for high amp draws at low voltages.
P.S. 8 ounces is a pretty agressive target for this size airplane. Careful on your wing /fuse attachment- you've got long wings out there.
Sam Brauer
Norwalk, CT
Megowcoupe is offline Find More Posts by Megowcoupe
Old Oct 26, 2007, 09:05 AM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
Gene! Tell us please you success story.
Thank you,
Kostya
salat is offline Find More Posts by salat
For Sale Guillow's B-17 & B-24 ShaverR6 Aircraft - Electric - Airplanes (FS/W) 0 May 18, 2007 10:51 AM
6 Miles from R/C Buyer's Warehouse! Tim Jonas Electric Plane Talk 18 Jul 16, 2002 01:02 PM
FS/Trade r/c car's ductfan2 Cars - Cars and Parts (FS/W) 0 Mar 04, 2002 08:11 PM
Guillow's B-17 JCastle Aircraft - Electric - Airplanes (FS/W) 0 Dec 27, 2001 10:42 PM
R/C Microflight's Mustang AirVenture Power Systems 4 Sep 17, 2001 11:17 PM
