You know you can run any amount of motors off of one battery... as long as the battery can supply that many amps.
Personally, I'd start by giving us an expected AUW to work with. As a standard, I'd probably try Himax 2015-3600's in the new gen EDF-55's. By my bench tests, it only draws 10.5A WOT... and is said to have 6-8oz of thrust each max. I would have measured the thrust myself, but I don't have a proper thrust stand. -Chris |
From BPHobbies:
Feigao 1308434S at 6.63-1 ratio, 2753 Rpm/V, 0.2293 Ohms At 11.1V in EDF 55 running EP-2245x6 rotor gets 7.4oz thrust at 5.3A. $16 http://www.bphobbies.com/view.asp?id...49&pid=U969152 If you have a lighter plane you would like to put this in try the 1308441S, also $16. 6.2oz at 4.3A, with 11.1V. |
I know, but I like the low current draw and the fact that it will last more than a handfull of flights before burning up
I hear the stock brushed motors are kinda random in how long they last. Some people have had many, many, many flights and some have had ONE. I figure, for $6 more why not go brushless? ![]() On his 71" A380, we're looking at 29.6oz thrust on a fresh pack at 21.2A, which should be way more than enough for fun flight. The cheapness of the motor and esc make it that much more attractive, and the low current means he can use smaller (read: cheaper) batteries to power it. Unfortunately, only the 41 is in stock now. More efficient, but less total thrust. Where are the thrust data tables for the 2028 in an EDF55? |
Taipei, Taiwan
Joined Oct 2005
Chen |
I also found this thread just a few minutes ago:
http://www.rcgroups.com/forums/showthread.php?t=457151 Thank you for looking those up |
Melbourne, Australia
Stacker,
I am running a blue motor in a gen 2 edf55 with a heat sink from Air craft world. On a tower-pro speed controller on 3s I can push the motor towards 25 amps. However it severly glitches the radio equipment. An align 25 amp speed controller from my trex draws around 20 amps. i can measure these exactly for you if interested cheers anth |
G'day Chen,
I have tried both of my dual conversion receivers with no improvement. I assumed it was as a result of using a lower quality speed controller. However that said, when testing the speed controller on another motor at much lower power settings it did not glitch. Thus I assumed it was a combination of the high power setting on a cheap speed controller for this specific motor. As the airframe I constructed is powered quite nicely at 20 amps, I have decided to avoid using the tower pro controller on this motor and sticking with an align, or hyperion controller. i can provide more detailed performance specs for the motor in the edf 55 with the blue motor for a hyperion 1500mah and an alight 2100mah 3s packs from a power draw perspective. But as the motor is ducted in an airframe, I may struggle to accurately measure rpm anymore. Thrust should be okay though, through the nose on scale method. Cheers anth |
| Thread Tools | |
| Discussion Which brushless motor to go with castle tbird 18 esc? | Aten W Arthog | Power Systems | 3 | Feb 15, 2006 08:00 AM |
| which brushless motor to go with? | crazy pilot | Electric Plane Talk | 11 | Sep 09, 2005 11:26 AM |
| HELP...which brushless motor I must buy? | massimo | Electric Heli Talk | 0 | Feb 14, 2002 06:44 AM |
| Which brushless motor for Kyosho Spacewalker | Michael in Toronto | Electric Plane Talk | 11 | Jan 04, 2002 12:06 AM |
| Is flying at partial throttle with a sensorless brushless motor bad? | Mitch G | Power Systems | 6 | Dec 12, 2001 02:15 PM |
