Old Aug 08, 2006, 12:22 PM
spitfire123 is offline
Find More Posts by spitfire123
jimi hendrix
Joined Apr 2006
im building a custom exhaust for my .91 engine but need help*****PICS****
hi.
i am making a custom exhaust fo my s.c 91 engine but have hit a few problems:
1)i have done 2 out lets which are 1.5cm each x2 = 3cm, is the exhaust outlet to big?because im worried that there wont be any pressure in the fuel tank.and during flight it may cut out when im doing rolls
2)where do i mount the fuel nipple?(the exhause is ajustable and can go all the way round in any possision)im having it pointing up?
before i had an pits exhaust for this engine and the out let messured 1.5 cm and the engine kept cutting because it was to small
the dimensions of the exhaust barol is
lenth:6.2cm
with:6cm
p.s i will be painting this exhaust
thanks
spitfie123
spitfire123 is offline Find More Posts by spitfire123
Old Aug 08, 2006, 01:33 PM
trab1925 is offline
Find More Posts by trab1925
trab1925's Avatar
Nebraska, Lincoln
Joined Apr 2006
Uhh, I don't even know what to say to you.. haha It looks interesting. Hope it works because you can break something in the engine if the pressure isn't great enough. I suggest NOT using it because mufflers are desgned with blow back in mind and pressure. I highly don't suggest it. Mufflers are desgned in a specific way for the exaughst flow and can be harmful to an engine if made wrong. Soo, good luck?
trab1925 is offline Find More Posts by trab1925
Old Aug 08, 2006, 02:00 PM
Lightnin is offline
Find More Posts by Lightnin
Non-Discriminatory User
Lightnin's Avatar
Joined Mar 2003
Some people run glow engines with straight pipes and essentially no muffler so don't worry about post #2, sorry trab.
Now concerning your original post I am more worried looking at you muffler that the exit holes are too much exit area.
Also, how do you know the original was too little of an exhaust, maybe it was too much and the pressure was not enough to ensure un-interupted fuel flow and the engine cut out as a result.
1) Place your pressure nipple near the top of your muffler, this will at least help keep acumulated burnt oil and such from entering the pressure tap and making it into the fuel or plugging up your pressure line.
2) Proceed systematically from this point on. Start the engine with the new muffler and plug one of the exhaust ports. Find a way to run it this way at different attitudes and speeds. Then try with both unplugged and note any important differences. I think you get the drill.
Report back please. BTW nice attempt at a muffler.
Lightnin is offline Find More Posts by Lightnin
Old Aug 08, 2006, 02:07 PM
jimi hendrix
Joined Apr 2006
thanks for the reply lightinin,
i no the pervios exhaust was to small becausewhen i tried it open with the same tuning setting the throttle responce was better and it dident cut out!.
and i cant have a strait pipe because there are noise restrictions in england.
p.s i can just take 1 of the outlets out and cover it up and just have one.
Old Aug 08, 2006, 02:08 PM
jimi hendrix
Joined Apr 2006
what are you on about m8.
get your facts right
Old Aug 09, 2006, 02:53 AM
trab1925 is offline
trab1925's Avatar
Nebraska, Lincoln
Joined Apr 2006
Well with gasoline it is at least. I thought that glow was some what the same sence they are 2 stroke. I made made a glass pack from an aluminum can, a copper pipe drilled holes in and put steel wool in the can and pipe strait through. It worked for about half hour. Then it had too much blow back and I had a carbon build up and the engine was temporirly seized until I got a hold of a sulivan tank. It sounded awesome though! So I was thinking it is some what the same. But still good luck!
And yeah I did get bored...
Old Aug 09, 2006, 05:13 AM
jimi hendrix
Joined Apr 2006
but the petrols are different to the nitros.
petrols need exhause pressure.
Old Aug 09, 2006, 05:49 AM
trab1925 is offline
trab1925's Avatar
Nebraska, Lincoln
Joined Apr 2006
Yeah lightnin decided to let me know about that too.
Old Aug 09, 2006, 06:42 AM
jimi hendrix
Joined Apr 2006
lol
ok
as lighting to read my new post(ITS BENITH HIS)
im goin to test iy in a min.
Old Aug 09, 2006, 08:53 AM
jimi hendrix
Joined Apr 2006
right............
i fired my s.c up and under 1.5 throttle it works great!
but over half throttle it cuts.(so is it to rich ore too lean)?
it allways does this because thay are the hardes engines to tune.
but it idols great and sound like v8 AND IS VERRY THROUGHTY!
please help!
Old Aug 09, 2006, 08:56 AM
jimi hendrix
Joined Apr 2006
oh yes any when i put my finger over 1 of the exhaust hols it affcts the preformabce dramaticly(crappy)and somtimes even cuts out!
wso i think 2 is ok!
WHO NOES MAYBEE I NEED BIGGER?
what do u guys think?
Old Aug 09, 2006, 09:29 AM
Lightnin is offline
Lightnin's Avatar
Joined Mar 2003
I think you should follow this link: http://www.rcgroups.com/forums/showthread.php?t=205602
And use it to tune you engine and then report back.
Old Aug 09, 2006, 11:54 AM
StrangeGager is offline
Find More Posts by StrangeGager
United States, MI, South Lyon
Joined Aug 2004
Even if you do get it tuned right, the engine will shake that tin can to pieces in no time at all. My suggestion would be to find a muffler that has similar exhaust flange dimensions and buy that. The SC engine probably has the same flage as an OS 91 FX.
StrangeGager is offline Find More Posts by StrangeGager
Old Aug 09, 2006, 02:06 PM
trab1925 is offline
trab1925's Avatar
Nebraska, Lincoln
Joined Apr 2006
^Agreed. All I really can say. If this engine you plane on keeping just buy a new muffler. I bet it does sound AWESOME but still, I just suggest a muffler that's made for it. Then again who knows it could be awesome?
Old Aug 09, 2006, 03:00 PM
jimi hendrix
Joined Apr 2006
yea thats what i was thinking but i would loose the sound!
can any 1 find me a link for a s.c 91 muffler?
because i wanna find out the price and accturly look at the exhaustt on the engine.
Build Log Building The Lackawanna Tug For My Father [ssssh! Itís a Secret.] scubber Scale Boats 56 Jan 02, 2014 02:18 AM
Help! SkyFly - happy with it for my 1st plane, but can't ROG - help !? rigor Parkflyers 7 Dec 06, 2006 03:23 PM
Discussion 8s emoli custom packs for my Swift. litespeed Electric Heli Talk 17 Aug 16, 2006 11:23 PM
Question What exhaust for my 50 size russern Fuel Heli Talk 6 Oct 26, 2004 02:22 AM
Ok guys my ifo is flying but i need you to read this. JStory Electric Plane Talk 4 Jul 31, 2001 07:28 AM
