San Carlos, California, United States
Joined May 2002
http://www.swashplate.co.uk/ehbg-v16/ch12s16.html http://www.swashplate.co.uk/ehbg-v16/ch12s18.html http://www.swashplate.co.uk/ehbg-v16/ch12s17.html The first part of the post by ukgroucho is covered by section 12.17.2.4 Setting Limit in the EHBG. The second part of the post by ukgroucho is incorrect as far as I know. It assumes you can set the tail servo neutral position by using the "switch 3 times between HH/yaw rate mode" feature. This is not the function of this feature. The "switch 3 times" option actually changes the gyro's stored center stick position. Basically, if you center the rudder stick and change the subtrim, the gyro will now think you are trying to turn the heli because the signal has changed. If you change the subtrim, you can use the "switch 3 times" option to tell the gyro to update its center stick position. This has no effect on the neutral tail servo position used by the gyro. Also, if you are a newbie and try to hover in yaw rate mode as the second section suggests, then it's likely you will lose orientation and crash. Toshi |
I think we're saying the same thing here Toshi...
The setup process for rudder Neutral is trying to determine the optimum amount of pitch to apply to allow the 401 to move from turning the heli to 0 turn. This optimises the ability to stop the tail dead after a piro or turn. You determine the rudder neutral pitch in Normal mode by hovering and adjusting sub-trim. Adjusting sub-trim in Normal is fine, but it's NOT good to have any subtrim in AVCS mode as the 401 considers this to be a constant stick input. This is why you do the triple transition from Normal to AVCS gain. You are "re-centering" the gyro in AVCS mode based on the sub-trim you determined for rudder neutral. When you do this you are telling the 401 the optimum position to return the slider to (rudder neutral) when you center the rudder lever. You are setting a rudder neutral position for AVCS mode. As you state this has no effect in Normal mode. |
Joined May 2002
I'm saying the "switch 3 times" calibrates the CENTER STICK POSITION. When the gyro sees the transmitter stick in this position, it assumes you don't want to turn the heli. This affects the relationship between the rudder transmitter stick and the gyro. You're saying the "switch 3 times" sets the gyro's NEUTRAL TAIL SERVO position, which is something totally different. You're stating this changes the relationship between the gyro and the tail servo. In heading hold mode, there isn't a direct relationship between the rudder stick position and the tail servo position. In fact, by definition, there is no neutral tail servo position, because the heading hold gyro applies however much throw is required to hold the tail position. If you have crosswind blowing on the left or right side of your heli, the tail thrust will need to be less or more. So there is no "neutral tail servo position". Toshi |
| Thread Tools | |
| Yippee! Setup tips for my new 9C? | IwantaJet | Hand Launch | 2 | Oct 15, 2004 10:28 AM |
| Got a Gy401. Need setup tips. | ashdec87 | Electric Heli Talk | 11 | Aug 18, 2004 12:44 PM |
| Any setup tips for my new micro hummingbird? | doodledap | Micro Helis | 16 | Aug 10, 2004 12:57 AM |
| thoughts on my Eplane setup... | foambattery | Foamies (Kits) | 2 | May 30, 2001 11:17 PM |
| Ok, I got my brushless setup, I have some questions: | jhudak7 | Electric Heli Talk | 3 | May 25, 2001 07:35 PM |
