Old Aug 05, 2006, 08:58 PM
flying evader is offline
Find More Posts by flying evader
Back in the game
flying evader's Avatar
United States, TX, Frisco
Joined May 2006
Charging - Pushing the limits of 1C
As most chargers my charger charges in increments of mah.. I currently charge my 1900mah battery at 1700mah, charges cool as a cucumber. Would I damage the battery if i charge at 2000mah? and if so, is temperature the best indicator of whether it is too much?
Interested to know how far people push the envelope above 1C...
flying evader is offline Find More Posts by flying evader
Old Aug 05, 2006, 09:20 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Standard disclaimer: Charging at greater than 1C should only be with cells / batteries so approved by the manufacture.
There are many of us charging at 2 and 3C however we are using balancers and taking extra precautions.
This single cell test was conducted to see what effect 2C charging and 12C discharging would have on cell life.
http://www.rcgroups.com/forums/showt...70#post5360770
Post here has results of charging at different rates with TP-1010C / 210V combo and links to additional charge logs.
http://www.rcgroups.com/forums/showp...06&postcount=2
The newer generation high C cells rated 13-20C are more tolerant of high charge rates than the older cells were. There are cells approved for 3C charge rates when approved charging equipment is being used.
Charles
Old Aug 05, 2006, 10:46 PM
Back in the game
Joined May 2006
reading here are my takeaways for high discharge batteries:
- know thy batteries, each will behave differently
- Diminishing returns after 1.5C: The greatest charging time reduction is from 1 to 1.5, after that charging time is cut but each .5 has less and less impact
- the above is also true for reaching full capacity
- no impact on battery life, if balancing is done routinely
- and obviously great care and caution must be exercised, as always with Lipo
thanks.
Old Aug 06, 2006, 07:22 AM
Southern Pride
True in general but in many cases the charger in use plays a major role in determining the actual charge time difference.
A Triton charges almost as slowly at 2C as it does at 1C but a TP-1010C is fairly close to being linear.
Charles
Old Aug 06, 2006, 10:12 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
I can super fast charge my TP Prolites or any LIPO pack with balance connector at 3C, for eaxample a 2100 mah at 6 amps using the AF 109 with tp 205 balancer , ready to fly in less than 1/2 hour, all cells read exactly 4.18 v each and there is no heat on the packs, only on the balancer as it bleeds off the excess current at 420 ma max to match up all 3 cells
As long as U can keep the voltage pressure of each cell ~ 4.2V , U R safe
hall woo is offline Find More Posts by hall woo
Old Aug 06, 2006, 10:53 AM
Back in the game
Joined May 2006
i'll do some tresting with me apache 2500. max charge is 2.5 amps and most of my batteries are in the 1500-2000mah... so i dont anticipate going over 1.5
Thanks again!
Pushing the limits of FFF blueman Foamies (Scratchbuilt) 505 Apr 04, 2005 08:38 AM
Any merit in charging at <1C ?? CooHead Batteries and Chargers 10 Aug 09, 2004 04:52 PM
Safety charging lipos below 1c? sprice50 Batteries and Chargers 17 Apr 03, 2004 02:35 PM
NiMh charging (more than 1C) brianchristie Batteries and Chargers 2 Dec 31, 2003 12:31 PM
Pushing the limits on 1406 2y? Steven D Electric Plane Talk 2 Jul 01, 2001 05:53 PM
