Old Aug 05, 2006, 06:20 PM
mlgreene is offline
Find More Posts by mlgreene
Seymour, Indiana
Joined Mar 2004
Ideas for mounting a Futaba S9650 Servo to Corona
I just got a Futaba S9650 digital servo to install on my Corona 120 for the tail rotor. Itís a little too large to fit where I have a Hitec HS-81 mounted in the aluminum crutch. I looked at the Ballistic Tech boom servo mount but it looks a little too large for the 9650. Does this mount work ok with the 9650? How did others mount the 9650 to the Corona?
Thanks for any help
mlgreene is offline Find More Posts by mlgreene
Old Aug 06, 2006, 02:50 AM
Jam Rectified is offline
Find More Posts by Jam Rectified
Todays a good day to fly
Jam Rectified's Avatar
Joined Oct 2005
Hold up there buddy - I will take a picture of mine and post for you - dead straightforward really.
Cheers
Jam R
Jam Rectified is offline Find More Posts by Jam Rectified
Old Aug 06, 2006, 08:47 AM
Joined Oct 2005
Hi Mike,
Pictures as promised, hope they help, I just used a couple of the plastic boom mounts...If I remember correctly I think Gadget actually mounted a 9650 on his alu crutch which also works great. I like mounting on the tail but you may have to make yourself a new carbon pushrod...but thats not the end of the world.
Cheers
Jam R
Old Aug 06, 2006, 12:36 PM
mlgreene is offline
Seymour, Indiana
Joined Mar 2004
Jam R
Ok thanks for the pictures. I have a couple extra boom clamps. Iíll give it a try. I seen a picture from someplace that they drilled a couple of holes in the crutch and mounted just under where the boom mounts to the crutch. Both ways look like they will work just fine.
Old Aug 06, 2006, 12:41 PM
Joined Oct 2005
Hi Mike,
Yeah, I am sure I have seen a picture of Gadgets heli with a 9650 mounted on the crutch, I didn't have space to do that on the BT blade crutch, mounting on the tail gives you lots os scope for helping with balance, if your tail is dead light you could always mount right out on the end and just have a really short pushrod - I guess would be more precise although that would probably be wasted on the stock tail....
Cheers
Jam R
Old Aug 06, 2006, 12:45 PM
Joined Oct 2005
Hi Mike,
Dug it out for you :
http://www.rcgroups.com/forums/showthread.php?t=530177
Bottom of the page is a picture of Gadgets set up..
Cheers
Jam R
Old Aug 10, 2006, 06:17 PM
mlgreene is offline
Seymour, Indiana
Joined Mar 2004
Jam R
Thanks for the help. I went with what Gadget did with this. Seems to work well. I have now added the Craz-E-tail V2 and that has made it even better yet.
Where can I buy gear sets for Futaba S9650 servo for my logo 10 UAVProducts Electric Heli Talk 2 Mar 24, 2005 05:51 PM
FOR SALE...Futaba DIGITAL SERVO mikekosatka Aircraft - Electric - Airplanes (FS/W) 3 Feb 07, 2004 10:37 PM
Ideas for mounting GWS IPS in Dumas FF conversion mu2freighter Scratchbuilt Indoor and Micro Models 2 Oct 16, 2003 10:23 PM
Ideas on mounting Mega brushless on Corona bigryan Electric Heli Talk 5 Dec 19, 2002 12:42 AM
