Old Aug 05, 2006, 05:12 PM
4 Scale is offline
Find More Posts by 4 Scale
Trampling out the vintage
Joined Feb 2002
Power for an EDF HO 229?
There are some folks over at RCScalebuilder who are building a Horten 229, 66" span. http://www.rcscalebuilder.com/forum/...?TID=6750&PN=1
I would guess the weight before power system or battery to be two lbs. or so.
This of course is a twin; right now the dimensions of each duct are
Length: 18.68"
Inlet diameter: 2.75"
Exhaust diameter: 2.46"
Any suggestions on an EDF power system? I have not previously indulged in EDF, but this would be very tempting.
4 Scale is offline Find More Posts by 4 Scale
Old Aug 06, 2006, 07:02 PM
4 Scale is offline
Joined Feb 2002
Perhaps I can ask the question a different way. Is there any technical source that describes the parameters for EDF duct width vs length? The scale intake/outlets on the HO 229 appear to be long and skinny compared to typical EDF units. I am concerned we cannot achieve a scale look or proportion on the ducting.
Old Aug 06, 2006, 07:13 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Greg,
You should use the search function. But I will answer a few questions based on what works for me.
Looking at your project, ducting length isn't a problem. You will probably need to mount the fans more forward in your model.
The width is determined by the FSA (fan swept area). The intake FSA should be about 100% and the outlet of 90%. You can squash the outlets and inlets as long as you maintain a gradual change to and from the fan.
I hope this helps.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Aug 06, 2006, 08:24 PM
4 Scale is offline
Joined Feb 2002
Thanks.
Old Aug 07, 2006, 03:36 PM
WURPFEL is offline
Find More Posts by WURPFEL
WURPFEL's Avatar
Swiss
Joined Jan 2004
Interessting project!
based on the originaljetDIA of 600mm I kooked for an thiny EDF and found the EDF40 very pleasent.. my HO9 is much smaller than yours it`s very difficult to find a suitable taller EDF, maybe it`s works only scale in a superlight-setup aka slowflyer.
badly the long and small EDFs with huge power arn`t very good performant systems, they have great losses
maybe the bonsai-miniturbines from Lanbert are a option for you
look at the proto build out of a 3mm depron sheet to check the handling and for indooruse.
this two EDF40 (lil black things on top) are scale in dimensions of the span: the HO9 was a big bird!!
now the plane is under construction with a MH74 profile, that`s looks nearly like the original horten-one.
WURPFEL is offline Find More Posts by WURPFEL
Old Aug 07, 2006, 04:49 PM
ex-racr is online now
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
Greg,
This may prove useful:
http://www.wattflyer.com/forums/showthread.php?t=6847
Why re-invent the wheel?
Video near end of thread.
Terry
ex-racr is online now Find More Posts by ex-racr
Old Aug 07, 2006, 07:10 PM
4 Scale is offline
Joined Feb 2002
Terry that's the definition of modeling - we do it again. Smaller.
Thanks for the link and video. We are intending this to be near-perfect scale; that guy's model is pretty good but not quite scale.
From all accounts this will be a deceptively challenging model. The airfoil and canopy have to be perfect or it likely won't fly. However, the lines are stunning and we feel it's worth a try...
Thanks to you all for your help.
Old Aug 07, 2006, 09:49 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Your exhaust and inlet sizes are near what is needed for a WeMoTec Minifan 480 setup. That is probably the most used fan on this forum.
A search on Minfan 480 setups will yield tons of information.
With two of them in a 66" span Ho-229, I would go a little mild, with something like Mega 16/15/3 on 3S lipos to start with. 16/15/2 if you wnt more power on 3S.
Might be tough to get it to balance, as it is hard to get the batteries close enough to the front of the nose to help much.
The fans need to be placed as far forward as possible.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Aug 07, 2006, 10:44 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Hi Greg
Slightly different suggestion- the Wemo 505 rather than the Minifan- the fan is a bit smaller- think it will take the inlet and outlets you've got a bit easier. Ken at K + A makes a nice liner for it that's 68 mm OD. If you really need a few extra mm smaller, the Vasa 65 fan would work- but it's terribly delicate unless you really support the housing well- which come to think of it- this airplane might do quite well.
Some of the options depend on whether you want lowest weight or not-
Lowest weight- the Vasa 65 on a Medusa 028-32-3400 (think that's it)- should pull about 250 watts on 3s. around 4 oz
In the Wemo 505- the above motor will do about 300 watts on a hot 3s pack. Both setups worked fine in a 1.5lb F-86.
More watts- Wemo 505 with a Mega 3 turn on 4s. 350 watts on wimpy 4s, 450 watts on a hotter pack. Around 5.5 oz.
Figure the 450 watt setups weigh around 1 lb- the 300 watt setups will be closer to 12 oz or so.
Pay lots of attention to your inlet- if you can't come up with a nicely rounded inlet- add lots more watts.
In flying EDFs don't go less than 150 watts/lb- 200 watts/lb is kinda nice. If you want speed- go for more watts- the highest I've hit is around 275/lb.
HTH
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Aug 08, 2006, 07:55 PM
4 Scale is offline
Joined Feb 2002
Again many thanks for the comments. Those of us on this project are scale modelers first, and real newbies to EDF. Your comments are invaluable. I will check out all the alternives mentioned.
With the fans forward and a bit of a nose on this I am optomistic about the CG.
Need Ideas for an EDF-40 pburress Foamies (Kits) 9 Apr 09, 2004 09:32 AM
Looking for an EDF Slopie/Park Flyer Retro Electric Ducted Fan Jet Talk 1 Mar 08, 2004 12:49 AM
New power for an old model yogorilla Power Systems 5 Aug 10, 2003 01:54 PM
What size duct and inlet for an edf-75? Darn Servo ! Electric Ducted Fan Jet Talk 11 Jul 12, 2003 09:08 AM
average flight times for an EDF jet mario alvarez Electric Ducted Fan Jet Talk 25 Jun 05, 2002 01:41 PM
