Old Aug 05, 2006, 11:57 AM
Don McGill is offline
Find More Posts by Don McGill
Happy2ndChildhood
Don McGill's Avatar
London Ontario
Joined Aug 2005
Question
Need some questions about brushless motors answered
1) On a BP21 motor, says Bm2408-21 on the can. I was running this in Gene Bond's Blucub2 and having heat problems with motor and battery, never checked esc. Was using a Phoenix 25 esc. It also momentarily cut out the odd time when running high throttle. I see that the stator has a painted on insulator, not plastic like gobrushless. I also noticed today that one hammer head has insulation chipped off right to the bare stator. Can this cause a short and being a 25amp esc it not cut out till you put lots of throttle to it?
2) Should I be using a smaller esc with a motor like this and why, or is bigger esc fine?
3) When winding a stator, if I press accidentally on top of wire when positioning a wind with finger nail, and can see a dent in that strand under magnifying glass should I consider this a short and start over?
4) If one screws up say second tooth of a phase and is short one turn by the end of the tooth is it ok to run wire out to the end of the tooth to do one last turn then down and to the third tooth of that phase, or is it better to rip that whole phase out and start it again?
Don McGill is offline Find More Posts by Don McGill
Old Aug 05, 2006, 01:00 PM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
Unlikely - especially if there is no wire near it. Shorts between stator laminations are not good, but not as bad as shorts between the wire and the stator.
The bigger one is fine. I'm wondering if you should be using a smaller prop though - this motor sucks amps. I'm not a big fan of this wind - but then again I'm not in the "go like stink" crowd This motor pulls 13-14 amps on a GWS 8040 DD prop - kinda high in my books.
It's not a short, just a dent. A short is when metal touches metal without the benefit of insulation. The easiest way to check this is with an ohmmeter - it should read infinite between the wire and the stator (check against both sides of the stator) Some guys actually put their wound stator in between 2 pcs of wood, and then into a vise to compress things down so the bell doesn't hit the winds
I'm trying to read between the lines on this one, Don. I'm assuming that you can't get one more wind in by the center, so your putting it on further out? If this is the case, then your answer is yes. A wind is a wind is a wind - it doesn't matter where on the tooth you put it, as long as it's there. It doesn't even have to be nice and neat - some of the motors coming from China look like winding-wise, but they work perfectly fine.
If you're asking about missing a wind on the 2nd tooth then winding the third tooth, and then going back to the second tooth to add one, I dunno. My gut says it should be okay, but the anal part of me would tear it down and start over.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Aug 05, 2006, 06:15 PM
Happy2ndChildhood
Don McGill's Avatar
London Ontario
Joined Aug 2005
Thanks Brad, yes, last question was all about the same tooth, eyes got buggy and missed ninth turn on bottom layer, did not realize till I finished the last turn on top and because the turns were perfectly neat it was obvious I was missing one at the hammer head of tooth. Yes all my purchased outrunners look like a rats nest, due partly to all the teeth being wound with three wires. With this I think I will finally get a motor finished tonight. Have wound this same stator a few times now and ripped it apart, not being happy with the appearance of the wind. Seems I can now wind with finger nails and skewer and get it looking perfect. Not sure I am finding motor winding fun. Maybe that will change when I get one airbourne.
Old Aug 05, 2006, 06:26 PM
Joined Dec 2003
Why? Neatness makes absolutely no difference electric/mechanic/magnetic-wise. Must be anal like me Guess I'm the opposite - I found them more fun at first.
B
Old Aug 05, 2006, 08:39 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
B
A pile wind is longer and has more resistance than a neat wind.
Old Aug 05, 2006, 10:00 PM
Happy2ndChildhood
Don McGill's Avatar
London Ontario
Joined Aug 2005
Less resistance is good right? I'm a "go with the flow" kind of guy. Actually I don't understand the theory behind it, but I am assuming that means I will either lower or raise the amp draw? Hopefully neater is lower.
Oddly enough Brad, it does not bother me to see a rats nest in my bought outrunners, and I am happy with their price/performance, but if I took the time to wind it and it does not look visually appealing to me.....would feel like a waste of time no matter how well it flew.
Old Aug 06, 2006, 06:43 AM
Joined Dec 2003
That's splitting hairs, Vinnie. What do you figure it will add? Are we talking micro, nano, or pico-ohms?
Let's call it no discernable difference - other than the mess
Yes, less resistance is what we're after. That's why we use different wire gauges to wind different # of turn motors - the idea is to pack in as much copper as you can fit onto the stator. A handy thing to remember is that doubling up the wires (using 2 in parallel) = 3 AWG sizes down - a pair of #26 = #23 Sometimes it's easier to use twinned or tripled wire instead of one thick one - these are the times whre the stator ends up looking like a rats nest.
Brad
Brad
Old Aug 08, 2006, 04:59 PM
roosevelt is offline
Find More Posts by roosevelt
Make 'n Break!!
roosevelt's Avatar
Walled 'tucky, MI. USA
Joined Apr 2006
Don't know if this helps but I just got the same motor and the bell was rubbing on the gold mount. I cut the gold mount off just in front of the set screws and epoxied it back on. Amps and heat dropped dramatically.
roosevelt is offline Find More Posts by roosevelt
Old Aug 08, 2006, 08:45 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I just got to ask whats with the prop
nice fix btw
olmod is offline Find More Posts by olmod
Old Aug 08, 2006, 09:09 PM
Make 'n Break!!
roosevelt's Avatar
Joined Apr 2006
nice fix btw
That's my variable pitch prop. hahaha! Actually that's what happens when you don't use a prop saver, I guess.
I tried an 8x4.3 slofly prop on my wing with some big honkin 8 cells. It didn't work. Dropped like the brick it was.
I chopped an 8x4HD down to 6x4 though on 3s and it kicked but. Low amps too.
Some questions about motors fuwu Racing Boats - Electric 2 Dec 22, 2004 03:27 PM
slowstick anybody? need some questions answered.. bassplay Parkflyers 11 Apr 03, 2003 11:53 PM
Some questions about chargers lempert Electric Plane Talk 6 May 29, 2002 02:27 PM
Questions on brushless motors,Who's the best? KOMET 44 Electric Plane Talk 18 Mar 29, 2002 04:25 AM
SOme questions about the litestik jayboy Parkflyers 5 Feb 07, 2002 12:41 PM
