Old Aug 03, 2006, 12:33 AM
Buzz Bomb is offline
Find More Posts by Buzz Bomb
Ham Call Sign: KK4KGJ
Buzz Bomb's Avatar
United States, GA, Stone Mountain
Joined May 2006
Why does the Slow Stick fly so slow?
Hi all...
I'm currently designing a float plane for the lake in my backyard. The lake is really the only place I can fly a plane safely in my neighborhood. I'm doing all this so when I get withdrawl from not being able to fly because of family/fatherly responsibilities, I will have something I can fly right quick in my backyard. The Aero Ace that was taking up this role is getting boring.
I want the plane to have a lot of thrust but not a lot of speed. I have no problem doing that. What I want to know is what makes a plane like the GWS Slow Stick fly so slow?
Is it the wing design that does it? Or is it weight vs lift? Incidence of the wing, etc?
Buzz Bomb is offline Find More Posts by Buzz Bomb
Old Aug 03, 2006, 12:41 AM
willhaney is offline
Find More Posts by willhaney
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
It has a large wing, some call it a kite or parachute. It has a high AOA (angle of attack) that is; it is angled up compared to the stabilizer. It has a low wing loading (it's relatively light).
These qualities make the Slow Stick slow.
Now, boomerace, hell be along, hes made and flown more Slow Sticks than anyone. He can tell you everything youd ever want to know about Slow Sticks.
Will
willhaney is offline Find More Posts by willhaney
Old Aug 03, 2006, 01:25 AM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
Large wing area + light weight = light wing loading -> slow flight
Thick section with undercamber = drag -> slow flight
I've seen a slow stick float plane around here somewhere called the 'float plane'. Enjoy!
glydr is offline Find More Posts by glydr
Old Aug 03, 2006, 01:34 AM
Buzz Bomb's Avatar
Joined May 2006
I think I asked the question in the wrong way. I understand about high lift to weight, thrust vs speed, drag, etc. I was more concerned with the wing design than anything.
I've looked at pics of the slow stick and I see that it has some dihedral, but it is also swept back to some degree. What is that called? More importantly what does the sweeping back of the wings do?
Old Aug 03, 2006, 01:44 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Sweep (which is the right term BTW) increases the angle of attack of the stall... which helps control at slow speeds. You can go too far, though... past 30 degrees, you can get a 'deep stall', where after the stall the AoA wants to keep on increasing.
The thick airfoil is likely to make more lift at higher AoA as well. If you want a real slow flier, you need a high-lift airfoil.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Aug 03, 2006, 01:48 AM
Buzz Bomb's Avatar
Joined May 2006
I'm not quite getting what you mean by AoA of the stall. Could you explain more about that?
Old Aug 03, 2006, 02:42 AM
Joined Jun 2006
Ok, people usually talk about a stall speed... but really, the wing stalls at a particular angle of attack (that is, angle between the wing chord and the relative wind). That sets a speed because there's a speed at which the angle of attack you need to maintain level flight equals the stall angle of attack; you can't fly level any slower.
Landing speed in fullsize flying is 30% above the stall; with models you can't really tell, but you'd aim for about that, because any slower and the handling gets intolerably mushy. In any case, for a slow flier you clearly need a very slow stall. There are two ways to achieve that, and you can use both at once. One is low wing loading, and the other is to use a wing foil that stalls at a high angle of attack. Sweep helps by increasing the stall AoA even further. Flaps help by increasing it further again, and also creating drag so you can run more power at slow speeds (which helps with the mushiness, and allows prop wash to give you some more lift as well).
Old Aug 03, 2006, 06:29 AM
Solid Hit is offline
Find More Posts by Solid Hit
Just call me .... Bill
Solid Hit's Avatar
Greenville/Anderson area of SC
Joined Dec 2005
Joe,
While you are designing your new "water taxi", try flying the Slow Stick flying boat: http://www.rcgroups.com/forums/showt...at#post5379931
I'm flying one off my pond.
Just what you are looking for.
Solid Hit is offline Find More Posts by Solid Hit
Old Aug 03, 2006, 06:41 AM
glydr is offline
glydr's Avatar
Joined Feb 2004
That's the one I was thinking of!
I think the 'sweep' that you speak of is washout (a sort of twist where the trailing edge kicks up a little at the rear). This is a feature of slow flying wings which aids stability / eliminates tip stalling. Not too much or you lose an angle of attack.
Old Aug 03, 2006, 09:14 AM
Buzz Bomb's Avatar
Joined May 2006
Originally Posted by Solid Hit
Joe,
Thanks for the info. But I have already read that thread from front to back. I have stuff to use to make a home made one from old planes. I was trying to avoid buying new equipment (ESC, motor, servos, etc). Especially for something like this.
Old Aug 03, 2006, 12:20 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Aug 03, 2006, 02:54 PM
roidspop is offline
Find More Posts by roidspop
roidspop's Avatar
Joined Apr 2005
Suckiness is in the mind of the belittler. Slow Sticks are fun.
roidspop is offline Find More Posts by roidspop
Old Aug 03, 2006, 02:57 PM
willhaney's Avatar
Joined Feb 2004
First plane I could actually fly on my own. Still have it and fly it. Very relaxing and great for AP or drop box.
Will
Old Aug 03, 2006, 04:07 PM
turn, turn, turn.
Joined Oct 2005
Old Aug 03, 2006, 04:11 PM
willhaney's Avatar
Joined Feb 2004
LOL! Having a bad day kkens4?
Discussion Cannot get my Slow Stick To fly straight KJ7YM Simulators 1 Apr 25, 2006 09:28 PM
I need to make my Slow Stick a Not So Slow Stick Mattydiah Beginner Training Area (Aircraft-Electric) 19 Oct 27, 2004 10:37 AM
Why does my EDF fly so slow now? gfcermak Electric Ducted Fan Jet Talk 4 Aug 14, 2004 01:18 PM
Why does my Zagi Fly Better Now? herc75 Foamies (Kits) 8 Nov 16, 2002 06:09 PM
why does my soarstar climb so much under power? waagbuck Foamies (Kits) 2 Sep 09, 2001 06:55 PM
