Calling all Energizer 2500 mAh AA users.
As many here know when I am cut I leak battery acid. Some also are aware of my Transmitter Battery Pack Thread where I posted test results and some of the problems I have experience with these cells.
http://www.rcgroups.com/forums/showthread.php?t=327288 Also happen to have many post in this Thread. http://www.rcgroups.com/forums/showthread.php?t=437641 Well after having an addational 3 cells in an 8 cell pack drop to less than 1.0 while the other 5 were still wll above 1.1 V. and haveing others contact me who were also experiencing similiar problems I decided to see what EveryReady had to say about this. I wrote: Quote:
As a last minute up date I just place 4 Energizer AA NiMH cells in my LaCrosse at a 500 mA load. The 2300s are over a year old and the 2500 are less than 6 months old I believe.(edit: 11 months old) All cycled two days ago. 2300s one holding 1.17V other holding 1.20V 2500s one at 1.11 and other at 1.10 ( note that in 95% of consumer electronic devices these would have already ceased to work. These numbers after discharging only 30 mAh from the cells. I think that since they are unaware of any problems that we should do our part to imform them. Added a graph with bad # 1 retested fresh off of charge . Charged at 1A ,same rate and same charger as used before. Post with negative results similiar to mine. 5,9,13,23,27,38, 46 ,74,87,90,125 Charles |
Interesting. I have a set of 4 2300s purchased two years ago for digital camera use that are going strong. I recently got an 8-pack of 2500s for the same purpose (we have two Olympus cameras that use 4 AA cells each) to replace the worn out Ray-O-Vac 1700s....so far so good, but I admit I have not done any capacity tests. Perhaps I should.
Latest blog entry: Diverted from R/C to Free Flight (of a...
They are not all bad and I have only had 5 out of one package of 8 and 3 out of another package og 8 go bad. Eight out of 32(number purchased) is only 25% failure rate.
Any of these if charged and used right after charging are fine however I am use to being able to charge my Transmitters and fly for hours on end over a period of days or even sometime weeks. THe Transmitter Pack Thread has a test where Sanyo 2500s powered a Tansmitter non stop for over 5 hours after setting for 58 days. These defective 2500 Energizers are self discharging more per hour than they should per day. Added: Here is a Snip from a post I made 10 days ago in another thread. Quote:
Bothe Transmitter pack which have had cells fail still have some of the original cells which are still doing fine. If it is not a QC problem rhen I am at a lose. Charles |
Gosh man, a friend and I have been experiencing the same thing with these crummy Energizer 2500 NiMH's. We used them for our Aero Ace Tx's and charging. Now I know the that the lower voltage of NiMH's will cause a decrease in range and reaction time of the Tx.
But the real problem lies in how many charges we got out of the 2500's vs regular Duracell Alkalines. We could only get 5 or so charges to the 150mah lipo in the AA with the 2500 Energizer... where as we can get 11-15 or so charges with the Duracells. This failure is among other small problems. Now I know why... -Chris |
Some are very good cells. Here is a recent Graph of a 5 cell battery. These cells are approx. 6 months old so only time will tell.
http://www.rcgroups.com/forums/showp...75&postcount=1 Charles. |
First let me state that I realize that no load volts is not a great indication of remaing capacity. Also the amount of charge from a charger to a Ni cell is not a true indication of mAh (capacity) added / replaced.
It is still possible to spot suspect cells by reading no load volts on cells which have been setting for a while . Cells # 1 and #2 in th above graphs checked low open volts and they droped voots very quickly under an approx. 0.2C. Following the discharges on the first graph (post #1) I recharged all three cells on a La Crosse BC-900. This is a fairly nice 4 channel charger which displaces all data for each cell sperately. Cells # 1 & 2 had a tested discharge capacity of 180 mAh but required 2,290 mAh to recharge. Cell A had a tested capcity of 1710 mAh and required 2460 mAh to recharge. As a comparison check . Eight each Energizer 2500s (a spare Transmitter pack) which was last charged on 7-18-06 ( 15 days ago) and when 4 chossen at random were palced on the La Crosse BC-900 they only required 395 / 510 / 498 / 447 mAh to recharge.This is what I consider normal self discharge. Tested the remaining 4 cells from this group. 441 / 467 / 409 / 418 mAh Charles |
I made up four transmitter packs with these cells (2-Optics, 1-Flash 5X, 1-Flash 4X) and I've had to gut two of the four packs within a couple of months to replace bad cells. Each of the two bad packs had two bad cells. The other two packs are still working great.
And before reading this post I thought it was just me... Jimsky |
I also thought that it was just an isolted case when I had to replace a cell in one of my Trnasmitter packs, but then another,and another and another. I lost five out of eigh in one Trans. pack and 3 out of eight in another.
It is so very nice of Everyready to sendi out form Email letters proclaiming no non problems or such. Quote:
I am sure most are like me and just toss such a cell and take the lose which has allways been my SOP but after about the fourth cell in 5 months or so I started saving them. I truely which everyone would call or email them. Customer Service Representative a call at 1-800-383-7323 http://www.energizer.com/contact/default.asp Charles |
| Thread Tools | |
| Calling All Multiplex MC2020 users. | mwilhelm100 | Radios | 15 | Dec 06, 2006 02:22 PM |
| Question Energizer 2500 mAH AA cells for Speed 400? | w0ace | Batteries and Chargers | 8 | Jul 16, 2005 05:09 PM |
| Calling all BERG/SHULTZE/SOMBRA/IPD users | mattijs321 | Radios | 2 | Apr 17, 2005 06:12 PM |
| Calling all users of the Maxx Products S400 gb | aeropenguin | Power Systems | 6 | Nov 03, 2003 12:26 AM |
