This thread is privately moderated by Aio_1, who may elect to delete unwanted replies.
Old Jan 27, 2013, 09:50 AM
MagnusEl is online now
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
A little flying with my Afriel. I`m just a "sunday" flier, but must say that Andycap has done a very well flying model. The first indoor plane I comfortebly does knife edge loopings with. It feels like it`s on rails!!
Thank you Andy!
MagnusEL 2012-12-29 (3 min 15 sec)
Auw with NanoTec 260 2s is ~105 grams.
MagnusEl is online now Find More Posts by MagnusEl
Old Feb 08, 2013, 01:13 AM
allen_g30 is offline
Find More Posts by allen_g30
allen_g30's Avatar
Romania, Bucharest
Joined Sep 2008
Hi guys.
I need your help. I lost plans to morback, where I note-I and COG. I rebuilt all calculations Cog last night and I went out to 70mm from the leading edge, or 77mm. to you like?
Thank you and waiting for a response from you
allen_g30 is offline Find More Posts by allen_g30
Old Feb 12, 2013, 06:54 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
I had CG at carbon spar location in the wing.
ultralajt is offline Find More Posts by ultralajt
Old Feb 17, 2013, 01:44 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
First F3P plane
Here's my Afriel Evo, ~860mm wingspan.
Turned out a bit portly, even with 2mm Depron Aero. Couldn't follow plans exactly, but did the best I could, with available materials. ~136grams all-up without battery.
Confirmed my belief that I'm just a lousy pilot, this is too much plane for me, at least in our indoor space. I'm going to step back for a while and practice more on other planes, before I destroy all this work.
A few of the many things I learned: Using good servos is a treat, been using cheap stuff until this build. Love the shrink-tube control rod connections, solid and super slop-free. Need proper carbon-fiber hardware, light-ply just doesn't cut it at this level. Really good batteries necessary to provide enough power without being too heavy. Too much glue = too much weight.
Many thanks to AndyCap for such a great plane, free plans, and EXCELLENT build instructions.
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Feb 17, 2013, 01:51 PM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Nice work Glen 136g isnt a bad weight at all considering 2mm depron is only a couple fo grams lighter than 3mm depron. Connor flies his Afriel Evo at 185g! does have some pretty meaty servos and an axi race though. Even so its still happy in a single basketball court
Andycap is offline Find More Posts by Andycap
Old Feb 25, 2013, 08:11 PM
pelmen is offline
Find More Posts by pelmen
United States, NJ, Garfield
Joined Mar 2011
Thinking about to start to build Morback F3P. Already have material and carbon. Can anybody suggest what kind of motor, ESC, batteries and servos the best choice for this model? About the servos I can imagine that it should be something like 5 grams, ESC approx. 10A, but what about the motor, battery and prop?
Thanks in advance
pelmen is offline Find More Posts by pelmen
Old Mar 01, 2013, 08:06 AM
pounditracing is offline
Find More Posts by pounditracing
pounditracing's Avatar
Joined Jan 2013
I'm building the index from the first post out of 6mm depron. I'm going to be flying outdoors and need a motor suggestion. I don't really understand the weight and kv mixture that I would need. I'm assuming the the plane will be around 9-12oz flying weight. I'm also using a 3cell. Also are there any changes to the design that I should make?
pounditracing is offline Find More Posts by pounditracing
Old Mar 09, 2013, 01:28 PM
Joined Jan 2013
Bump
Old Mar 15, 2013, 02:08 AM
litehawkdown is offline
Find More Posts by litehawkdown
Joined Mar 2011
I am a heli guy that just discovered VPP. 4D Morback is on the way now! Thanks for the plans!
litehawkdown is offline Find More Posts by litehawkdown
Old Mar 15, 2013, 12:14 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Cool! Post pictures!
Free.
P.S. Are you using a Mamo?
Free is offline Find More Posts by Free
Old Mar 15, 2013, 12:35 PM
ziper_it is offline
Find More Posts by ziper_it
Joined Jan 2007
Another here(newbie from heli), waiting for electronics ...
Description:
ziper_it is offline Find More Posts by ziper_it
Old Mar 24, 2013, 07:55 AM
Andrew Radcliffe is offline
Find More Posts by Andrew Radcliffe
Andrew Radcliffe
Andrew Radcliffe's Avatar
United States, FL, Clearwater
Joined Sep 2011
Simple Sim plans
http://www.rcgroups.com/forums/showt...7#post24502833
simple sym f3p (1 min 49 sec)
Andrew Radcliffe is offline Find More Posts by Andrew Radcliffe
Old May 05, 2013, 10:41 AM
Dylan_Anderson is offline
Find More Posts by Dylan_Anderson
Dylan_Anderson's Avatar
Australia, VIC, Melbourne
Joined Nov 2006
Hello EPPers!
2 or 3 years ago I re-sized and 'tiled' a number of plans including the Afriel which was a great plane. I've been flying F3A mostly but want to build some new Epp's. Are there any favourites out there? Also if you have a rough design, I more than happy to draw it up for you to put on the list.
All the best
Dylan
Dylan_Anderson is offline Find More Posts by Dylan_Anderson
Old Oct 21, 2013, 02:58 PM
Webmaster-F is offline
Find More Posts by Webmaster-F
http://rcmodelflying.tk/
Nederland, Zuid-Holland, Zederik
Joined Jun 2003
Here is a drawings of my own F3P AM design the FOX with this model fly my Aeromusicals at the moment
Here is a picture of the first version
and the free plan of version 1 is found here
Free plan FOX V1.PDF http://home.planet.nl/~vos08757/Downloads/FOX V1.pdf
Free plan FOX V1.DWG http://home.planet.nl/~vos08757/Downloads/FOXV1.zip
Free plan FOX V1.DXF http://home.planet.nl/~vos08757/Downloads/FOXV1d.zip
And here is Version 2
Free plan FOX V2.PDF http://home.planet.nl/~vos08757/Downloads/FOX%20AM.pdf
Free plan FOX V2.DWG http://home.planet.nl/~vos08757/Downloads/FOXV4d.zip
Free plan FOX V2.DXF http://home.planet.nl/~vos08757/Downloads/FOXV4.zip
both planes fly with a Center of gravety of 113mm
and the
ailron trow of 55 tot 60 degrees
elavater trow of 65 tot 70 degrees
Rudder trow als maxium as possible
65% expo on all
Please i like to know which version do you like it and how it is flying
Webmaster-F is offline Find More Posts by Webmaster-F
Old Oct 23, 2013, 09:20 AM
Joined Nov 2006
Love it!!!
Originally Posted by Daniel Z View Post
http://www.youtube.com/watch?v=WkMSQ2KB2nM
My Afriel Evo
hope you like it
Daniel, fantastic flight!
That rudder certainly kicks in. The thing I love about this design is the simplicity, no canalizer or additional vertical surfaces. Granted, it does speed up a little on down lines, (maybe brake the ESC?) but the cleaner the better and you've done a great job. Tell me, does the airbrushing put on much weight? Cheers Dylan
Discussion Depron F3P Plans please, can you Help? Jiffy Indoor Pattern/F3P 18 Aug 20, 2006 11:16 PM
