This thread is privately moderated by Aio_1, who may elect to delete unwanted replies.
Old Apr 13, 2011, 12:42 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
Some useful info on milling here
Mike Seale is offline Find More Posts by Mike Seale
Old Apr 13, 2011, 12:57 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Thank you. Don't think I'll be able to use it yet (I'm working on my first two builds and those are just ARF's, more or less), but neat info to have!
BryanEW710 is offline Find More Posts by BryanEW710
Old Apr 13, 2011, 02:23 PM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
My preferred method is to use CF pushrods with heatshrink linkages. Closed loop (pull-pull) using kevlar thread is a little lighter but more fiddly to set up and prone to more trim changes between sessions.
How would I go about doing CF pushrods with heatshrink linkages?
Thanks for answering my q's!!
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Apr 13, 2011, 02:32 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
A set of horns like these line up with a CF rod with about 1mm gap. Then use a soldering iron to shrink some tube to bind the two together.
Old Apr 13, 2011, 02:41 PM
BryanEW710's Avatar
Joined Sep 2010
Wow...seems like you'd have to have a pretty cold iron for that, wouldn't you?
Old Apr 13, 2011, 04:22 PM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
I'm thinking a heat gun
Old Apr 13, 2011, 04:27 PM
BryanEW710's Avatar
Joined Sep 2010
That's what I was thinking, which is why I was surprised.
Old Apr 13, 2011, 04:30 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
Think again. Soldering iron at full heat will shrink the tube fine without any damage. A heat gun will melt the depron before it shrinks the tube enough.
Old Apr 13, 2011, 04:32 PM
BryanEW710's Avatar
Joined Sep 2010
Like I said, I'm new at this
Old Apr 13, 2011, 04:36 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
We all were once. Ask me how I found out that the heat gun would melt the depron? Actually, don't bother, I'm sure you can guess And I too was very skeptical of using a soldering iron until I tried it myself.
Old Apr 14, 2011, 03:02 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
I use a heat gun for this but it requires that all the heatshrink is applied before the linkages are in position (i.e. not attached to the airframe or capable of being shrunk without pointing the gun towards any foam). I've used soldering a iron for heatshrinking too but I don't find that method as consistent.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Last edited by Aio_1; Apr 14, 2011 at 04:02 AM. Reason: clarified that gun isn't pointed towards foam
Old Apr 14, 2011, 03:15 AM
Petrik59 is offline
Find More Posts by Petrik59
Petrik59's Avatar
Sverige, Södermanlands Län, Eskilstuna
I use a soldering a iron to. Pointing a heat gun to EPP or Depron have never crossed my mind.
But maybe it works ok.
Petrik59 is offline Find More Posts by Petrik59
Old Apr 14, 2011, 04:01 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
Nope, pointing a heat gun at foam definitely won't work, it would damage the airframe very quickly.
Old Apr 14, 2011, 06:45 AM
BryanEW710's Avatar
Joined Sep 2010
That was my assumption, hence my question about using the soldering iron
Old Apr 14, 2011, 07:12 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Which file is the full sized plans? Is it the Cut file? Does anyone know of a good tiling program or know where there is a tiled full size AEvo?
Jim
Discussion Depron F3P Plans please, can you Help? Jiffy Indoor Pattern/F3P 18 Aug 21, 2006 12:16 AM
