This thread is privately moderated by Aio_1, who may elect to delete unwanted replies.
Old Mar 23, 2011, 02:03 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
The power will be more than adequate o hover with the AP05
Andy
Andycap is offline Find More Posts by Andycap
Old Mar 27, 2011, 01:43 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
Proud father!!!
Here's my completed Afriel 560mm with the full-sized one behind. Ended up at 55.7g rtf including AP05 motor, Plush 6A controller, 2.5g Hobby King servos, AR6300 rx and 2s 130mAh Fullriver cells. Had a quick flight in the garden and all seems well.
I was pleased with the weight but you've got to work for it. Milling saved 4g. I removed the hearshrink from the controller and soldered the wires from the motor directly to it...saved a gram. I also replaced the futaba-style servo lead on the esc with a micro jst one and this saved another gram. Fuselage bracing is 0.6mm carbon (horrible stuff to work with) and 1mm for the wings. Pushrods are 0.8mm. Custom horns and motor mount. It'll be nice to get in the sports hall to see how it compares to other small models like the micro Extra and 4-site.
Thanks again to Andy for sharing this great design.
Mike Seale is offline Find More Posts by Mike Seale
Old Mar 28, 2011, 12:27 PM
Dicky Mint is offline
Find More Posts by Dicky Mint
UK
Joined Apr 2007
Wow, 11.3g lighter than mine, nice work Mike. It will be ballistic at that weight Let us know how it goes. I have put some rear fusalage bracing on mine and still working on the c of g.
Richard
Dicky Mint is offline Find More Posts by Dicky Mint
Old Mar 28, 2011, 12:42 PM
Andycap is offline
Andycap's Avatar
Leeds
Joined Mar 2003
55.7g its going to be pretty stunning
Mines 65g wih the Park 180 unmilled and using 4 x dys 3g servos.
Awesome fun in the garden too
Old Mar 30, 2011, 04:27 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
The little Afriel flew very nicely after sorting out the CG and knife edge coupling. Ailerons were way too sensitive at first...you don't need much movement on these little models. Ample power for hovering with plenty in reserve to punch out. After a few flights getting it trimmed I flew the big Afriel and it was strange...really slow and floaty in comparison.
Only issue was in later flights there were horrible glitches. I initially thought it was the elevator servo (poor quality maybe?) but could it be the antenna on the AR6300 receiver touching the carbon bracing? I'll make sure I tape it down so it can't touch any more and hope that fixes it. Oh, and one of the servos was much much slower than the other two. Glad I noticed before the build because I was able to put this on the rudder. Any one else noticing quality control issues with these Hobby King 2.5g servos?
Old Mar 31, 2011, 06:59 AM
UK
Joined Apr 2007
Can you tell me where you have your c of g ?
Richard
Old Apr 11, 2011, 03:24 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
Richard
Sorry for making you wait so long for this little piece of info. My 560mm Afriel balances 152mm back from the nose. Inverted needs a very slight touch of down.
BTW, I taped the receiver down and the glitches stopped, so I was probably right that the antenna touching the carbon bracing caused the glitches.
Old Apr 13, 2011, 06:03 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Did you CNC those control horns?
rcjim11 is offline Find More Posts by rcjim11
Old Apr 13, 2011, 06:42 AM
f5b-uk
Mike Seale's Avatar
Joined May 2002
Yes. Cut on the laser at work.
Old Apr 13, 2011, 10:53 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
I have some small plastic horns, do you recommend using CF pushrods?
Also do you have one or two servos for the Ail control?
JIm
Old Apr 13, 2011, 11:09 AM
f5b-uk
Mike Seale's Avatar
Joined May 2002
My preferred method is to use CF pushrods with heatshrink linkages. Closed loop (pull-pull) using kevlar thread is a little lighter but more fiddly to set up and prone to more trim changes between sessions.
Old Apr 13, 2011, 11:18 AM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Mike, what covering are you using?
BryanEW710 is offline Find More Posts by BryanEW710
Old Apr 13, 2011, 11:20 AM
f5b-uk
Mike Seale's Avatar
Joined May 2002
No covering...it's milled depron.
Old Apr 13, 2011, 11:30 AM
UK
Joined Apr 2007
Thanks Mike, good to hear you sorted your glitching problem
Old Apr 13, 2011, 11:34 AM
BryanEW710's Avatar
Joined Sep 2010
Oh wow
(I'm new to the hobby, forgive me)
Discussion Depron F3P Plans please, can you Help? Jiffy Indoor Pattern/F3P 18 Aug 20, 2006 11:16 PM
