This thread is privately moderated by Aio_1, who may elect to delete unwanted replies.
Old Mar 02, 2011, 02:17 AM
Dylan_Anderson is offline
Find More Posts by Dylan_Anderson
Dylan_Anderson's Avatar
Australia, VIC, Melbourne
Joined Nov 2006
The only prob is Andy, you would have read somewhere that I say "ACTUNG !!! Never rely on page edges, always uses the registration marks" In effect, a tile is always smaller than the piece of paper it is printed on. so if the printer grabs the sheet on a slight angle or something it doesn't matter as the reg marks will hold true. But the page edges will not.That is the tricky bit !
cheers
Dylan_Anderson is offline Find More Posts by Dylan_Anderson
Old Mar 02, 2011, 05:23 AM
Davross is offline
Find More Posts by Davross
Foam's Law
Joined Nov 2004
A good free vector package that reads/write dxf and pdf's is called Inkscape - I use it for all of my plan edits:
http://inkscape.org/
As for tiling, try:
http://www.noliturbare.com/pdf-tools/pdf-tiler
Kev
Davross is offline Find More Posts by Davross
Old Mar 02, 2011, 07:24 AM
Joined Nov 2006
Lovely!!!!
As for tiling, try:
I just tested this and it works an absolute treat!
Literally 3 clicks, so I am cleaning egg off my face! yeah!
It doesn't scale things but I haven't scaled any of the plans anyway, they have all been as posted.
So, go for it
All the best,
Would be great to see in progress pics?
D
Old Mar 02, 2011, 10:00 AM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
Originally Posted by Dylan_Anderson View Post
As for tiling, try:
So, go for it
All the best,
D
You should check out their other pdf utilites. I use them, for my workflow to get a tiled pdf from sketchup. They have one that rotates and scales. And one that crops, particularity useful if the pdf is vector format.
-Kwok
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Mar 02, 2011, 11:05 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
I use PStill. Again pretty much a case of selecting input file, output file and then a dropdown of what you want.
Prints registration marks as well as numbers in corners to help get it all together.
I suggested Draftsight as the OP was asking about opening DXF's. Nice thing about DraftSight is in opens all the binary and ASCII versions out there. Designed as an AutoCad replacement.
CAD is time consuming but for simple work easy enough.
I did the UM Afriel Andy posted above in a couple of evenings from starting CAD to having the cutfiles. That was starting from a JPEG 3 View of the original design. Just a few lines and curves and as everything has real world units things are easy to get right.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Mar 03, 2011, 01:27 PM
Mike Seale is offline
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
Kev
Thanks for sharing this info, Kev. Works perfectly for opening pdf's and saving in other (more useful) formats.
Mike Seale is offline Find More Posts by Mike Seale
Old Mar 03, 2011, 01:38 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
Originally Posted by Andycap View Post
Build instructions are available for those who would like them but are 6mb until I can compress them further. So an Email is required to get them to you.
Thanks for sharing this plan as well as the mini/micro Afriel's. I know that wildpalms rates the full sized Afriel and have also seen his little one fly...very precise using the micro-Spektrum gear.
One question about the full-sized plan though. Can you tell us what these parts are for. I assume some form of reinforcement but cannot see where they would fit.
Many thanks, Mike
Old Mar 03, 2011, 01:45 PM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Left Hand item fits on the underside of the nose
The two right hand Pieces fit either side of the lower fuselage nose area
Instructions on there way Mike
Andycap is offline Find More Posts by Andycap
Old Mar 03, 2011, 01:59 PM
f5b-uk
Mike Seale's Avatar
Joined May 2002
That all makes sense now. Cheers
Old Mar 05, 2011, 09:36 AM
Joined Nov 2006
-Kwok
I use CS5 & Solidworks. Together they are the answer. Bit expensive though if you don't use them professionally.
Old Mar 05, 2011, 12:39 PM
Dicky Mint is offline
Find More Posts by Dicky Mint
UK
Joined Apr 2007
Originally Posted by Dicky Mint View Post
Hi Dylan
Could you produce a tiled version of Andycaps Afriel giving a 560mm wing span
Richard
Hi Dylan
Are you still able to do this for me?
Richard
Dicky Mint is offline Find More Posts by Dicky Mint
Old Mar 05, 2011, 12:49 PM
Joined Nov 2006
No worries mate,
Give me a few days, but you ate on the list
Cheers
D
Old Mar 06, 2011, 04:50 AM
UK
Joined Apr 2007
Cool, thanks
Richard
Old Mar 09, 2011, 09:22 AM
Joined Nov 2006
Dicky! 24 hours and done...
Sorry, heli's got in the way
Cheers
D
Old Mar 09, 2011, 11:50 AM
UK
Joined Apr 2007
Heli's Cheers Dylan, keen to start this project as the gear is waiting
Richard
Discussion Depron F3P Plans please, can you Help? Jiffy Indoor Pattern/F3P 18 Aug 20, 2006 11:16 PM
