This thread is privately moderated by Aio_1, who may elect to delete unwanted replies.
Old May 07, 2010, 09:32 AM
bluey1982 is offline
Find More Posts by bluey1982
bluey1982's Avatar
Joined Mar 2010
Hi guys hopefully somone can help, in the plans provided is there one that would suit and axi 2208/34 goldline and 3s 800mah lipo? i have this setup on a Great PLanes Flatout Turmoil running a 9x3.8 and flying it inside is a touch exciting to say the least as it has come out over 100g heavier than it should be so its a bit fast! need a model that can handle that power train but be nice and slow.
Was toying with the idea of adding some speed brakes/spoilers to it but id rather have a purpose built model than trying to mod an already overweight plane! either that or start cutting holes all over the poor thing.
many thanks
Just a side note, the total all up weight of the turmoil at the mo is 400g and it will prop hang at a click above half throttle. dont know if that helps!
bluey1982 is offline Find More Posts by bluey1982
Old May 07, 2010, 12:56 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
many thanks
Youre setup is much to heavy for indoor pattern type flying. You'll want to get a smaller motor (such as the EFlite Park 250 or Hacker A10 15S), a 5-10Amp ESC, 2s 350mah Li-Po (or smaller mah) to get a decent setup for indoor pattern. Remember, the lighter you make it the slower it flies. Reducing your component weights is the only way to do this.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old May 07, 2010, 04:14 PM
bluey1982's Avatar
Joined Mar 2010
Hi thanks seth. had a horrible feeling that would be the case!
know of a large-ish outdoor capable shock flyer larger than a turmoil? pretty much resigned to the fact that it will either be that or shell out for a whole new setup. seen vids of variable pictch mid mounted models and have to admit they have caught my eye!
Old May 07, 2010, 04:28 PM
nagayama13 is offline
Find More Posts by nagayama13
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Check this out bluey:
http://www.rcgroups.com/forums/showt...thon+tim+plans
Pitts Python. I made the full fuse version, and it flew great!
nagayama13 is offline Find More Posts by nagayama13
Old May 08, 2010, 06:23 AM
bluey1982's Avatar
Joined Mar 2010
nice one, always liked flying the python on Real flight and a shockie version seems just about right for what i need thanks nagayama! what power setup did you use in yours?
Old May 08, 2010, 12:40 PM
bluey1982's Avatar
Joined Mar 2010
AHA! had a good rummage around and found some goodies! would this setup work on a normal indoor model or around 190g?
Typhoon micro 5/3d
Product information:
- Diameter : 28 mm
- Length : 25 mm
- Shaft Dia. : 3.17 mm
- Weight : 28 grams
- No load current(lo) : 0.29
- Internal resistance : 0.29
- KV : 1030
- Max Current : 10 A
- Max efficiency : 83%
- Power Nominal : 80 Watts
- Recommended Props: APC E 9 X 4.7
castle creations phoenix 10a esc
11.1v 800 mah at 70g or 7.4v 950mah at 75g
4ch 12g rx
and 9g servos all around. some 6g servos but unsure of power/strength
sorry for all the questions been flying the big stuff too long and finding it hard to adjust to the small ones!
again, any help very much appreciated
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
The full fuse version is made with 3mm depron, so it actually comes out much lighter than the 6mm profile. So I ended up using a 370 equivalant. A 400 size outrunner oughta work out great with a 9x4.7 and 3s 800mah. Try to keep the weight less than 14oz.
Old May 08, 2010, 12:43 PM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Just noticed the weight of ur motor.......oops!
What u really need is a Leadfeather Yak made out of EPP!!! Like the 3DEPP.com yak!
With the low kv, might need a 9x6 prop tho.......that should pull a 7 to 9 oz plane plenty good!
Might be able to make the full fuse Pitts too.
Old May 08, 2010, 01:06 PM
bluey1982's Avatar
Joined Mar 2010
just found a 7.4 lipo that comes in at 50g and its 30c too.
i take it 28g is a bit on the hevy side then?
Old May 08, 2010, 03:59 PM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Hmmm ... speaking of EPP Yak55's check out WMParkFLyers.com
This is our standard kit and paint job ... we have all the goodies to go with it as well.
GM
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old May 08, 2010, 10:23 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
That looks sweet! But not EPP is it?
dylantorquerol is offline Find More Posts by dylantorquerol
Old May 08, 2010, 10:28 PM
OSMBuddha
nagayama13's Avatar
KC Mo
Joined Mar 2007
Why does it say "we are currently offering the red white and blue kit above" under the yellow flames #5?
Old May 08, 2010, 10:51 PM
Hawaii
Joined Oct 2009
I don't think they have pics of the one mentioned.
Old May 08, 2010, 10:52 PM
Jenison
Joined Nov 2009
Good catch ... I copied the text for the Orange Blue flame from the kit RWB kit above it ... it is fixed now ... PM me your address and I will send you some free prop saver bands for finding and pointing out the error.
Yes the yaks are 1.3lb EPP ... they bounce when you dumb thumb them into the ground. They are great for learning new maneuvers ... more time on the sticks and less time repairing. There are a lot of guys in our club flying them and applying what they have learned to their balsa planes. They are kind of like a real life simulator with a real life reset button ... just dust em off and throw em back in the air.
Old May 08, 2010, 10:54 PM
Hawaii
Joined Oct 2009
I know, I make my micro 3D planes from EPP, and need lots of carbon, but it is a lot lighter and bouncier.
Discussion Depron F3P Plans please, can you Help? Jiffy Indoor Pattern/F3P 18 Aug 20, 2006 11:16 PM
