Old Jan 11, 2007, 08:36 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Jurgen,
I don't read German but I take it he didn't gain as much roll authority as desired? I would expect this because the polyhedral's roll stability is more difficult to overcome. I'll give it a shot anyways.
Mark,
I don't expect it to roll like an Extra 300 but I would like to have more direct roll control. If it's anything like the Tipsy, the motor is just glued/taped onto it's mounting surface. I plane to do a mod on the mounting method that will allow me to do a quicker/cleaner motor change which utilizes a bearing plate and tie strap instead of adhesive.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Jan 11, 2007, 09:34 AM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Its made from Solidpor. Will this take normal cyano and kicker.
Mark
UPDATE....
Well ok, I picked up mine yesterday. I'm going to run mine on a Tornado 2900KV brushless and a 2s to start with. After that I'll run it on a 3s and see exactly what she'll take ( Its going to be abused a little ). I'm going to place another carbon rod in the wing for extra strength and I'll be using HS-81 servo's. These are a little to big, but I think they'll be better suited for when I run her on the 3s.
I'll build her up on the weekend, but the way the weather is, probably won't get to maiden her.
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Jan 13, 2007, 02:12 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Well I've almost finished the build. Pretty straight forward, and now she's built up she looks pretty nice. I've used Hs-81 servo's. Their a little big but went in ok. The control wires are pretty thin. I hope they'll be up to the job.
Out of the whole kit, my only gripe is the pushrod connectors for the servo horn. They have this plastic nut thats suppose to keep them in place. Horrible, fiddly things that I haven't bothered with. But apart from that everything went together well and hopefully I'll shoot some stills tomorrow.
Maiden flight won't happen until the weather improves
Mark
Old Jan 13, 2007, 02:31 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Mark
Hi Mark,
A brushless motor and HS-81 are overkill for a model like the Elektro-UHU.
Plastic nut at the servo horn? Something's wrong here, as normal Z-bends are to be used.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 13, 2007, 04:00 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Originally Posted by Jurgen Heilig
Hi Mark,
Jürgen
Hi Jurgen,
The Z bends are used on the rudder and elevator horn, but on the arm of the servo they have pushrod connectors. Have they changed this.
I've just gone by the book.
Mark
Old Jan 14, 2007, 03:51 AM
Joined Sep 2000
Hi Jurgen,
Mark
Oops, me bad (language issue ). The expression "Horn" is only used for the flight control surfaces, while "Hebel" (lever) is used on the servo side.
Those are M2 nylon nuts and although a bit fiddly to install, they work fine. (You may want to taper the hole slightly prior to installation).
Jürgen
Old Jan 14, 2007, 04:55 AM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Jürgen
No problem Jurgen,
I've decided not to use them. I've replaced them with a metal nut and washer.
My only concerns are the pushrods. There probably fine for the stock setup, but will they hold up for higher speeds, what do you think ? I'm going to run a 2s lipo for my first couple of runs, but would like to run a 3s just to see what happens.
Looking back I wish I had used the sized rods that come with the Easystar. Its a little late now, and the fact that you glue the sleeve in, makes them impossible to change.
I've used HS-81's simply because I have plenty of them, and that I'd rather have to much than not enough.
The weight I'm saving using the Tornado 400 BM 2900 brushless ( motor and ESC weigh 110g ) instead of the recommended 400 plus ( this weighs 120g ) should balance the extra weight of the 81's.
Mark
Old Jan 14, 2007, 06:59 AM
Joined Sep 2000
Mark
As mentioned before, brushless power is overkill for such a model. It could cause wing flutter and other unwanted effects.
Jürgen
Old Jan 14, 2007, 07:20 AM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Jürgen
Hi Jurgen,
Only one way to find out
I may place another carbon rod in the wing for extra strength.
If nothing else it should handle the 2s lipo surely.
Mark
Old Jan 14, 2007, 10:13 AM
Joined Sep 2000
Hi Jurgen,
Mark
If I wanted a "foamie hotliner", I would have rather chosen the Terry or the Turn-On.
Jürgen
Old Jan 14, 2007, 10:46 AM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Well here she is all finished. Well nearly. I've decided to remove the control rods and replace them with the same size as the Easystar. They go in ok, but I'll have to order another one for the rudder. I didn't bother with the two wing wheels. Can't see them lasting long, and they look a little silly. I cut my canopy in two. I've inserted my ESC into the one half and glued this onto the wing. The other half can be removed as normal. I use a set of small magnets to hold this down. Seems to work well.
Mark
www.rcflights.co.uk
Old Jan 14, 2007, 02:59 PM
Doubletap's Avatar
Joined Jul 2005
Looks good Mark! Can't wait to hear your flight report. What prop are you running? I just received mine yesterday from Hobby Lobby but have a couple of projects in line before the UHU.
Doubletap
Old Jan 14, 2007, 04:28 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Doubletap
Doubletap...
If I use the 2s, I was thinking of a 6x4, although I've found that a 5.5 is about the maximum you can get away with, without having to cut foam away, which is out the question on this bird.
I'll have around 21,000rpm on this setup with the 2s, so the 5.5x4.3 should be fine. If I ever do try the 3s, it'll have to be the 4.7x4.7.
Mark
Old Jan 14, 2007, 06:03 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
So how does the motor stay in place? Is there an actual mount, or just glue or strapping? Very nice bird, hope she handles the extra power.
MKH
MKH is offline Find More Posts by MKH
Old Jan 14, 2007, 06:15 PM
DelUK is offline
Find More Posts by DelUK
Slope convert/addict
DelUK's Avatar
Romford, Essex. UK
Joined Mar 2006
Mark
www.rcflights.co.uk
Mark,
Hope that your EZ*s haven't seen this new 'bird' that you have been spending so much time with lately !
How could you? After all the faithful flights you have spent together! ha ha
Jokes aside, she looks great and I look forward to your flight report. I might also be tempted....
Deryck
DelUK is offline Find More Posts by DelUK
Video New Elektro-UHU from Graupner Jurgen Heilig Electric Plane Talk 1 Jan 09, 2007 08:43 PM
Graupner Elektro-UHU cornj Aircraft - Sailplanes (FS/W) 0 Jan 02, 2005 02:02 PM
FS/FT Graupner Elektro-UHU in box stevesuarez Aircraft - Electric - Airplanes (FS/W) 2 Nov 09, 2002 10:49 PM
WTB - Graupner Elektro-UHU velvis Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2002 09:28 PM
Article Recommendations From an Experienced Elektro-UHU Pilot skranish Electric Plane Talk 0 May 01, 1996 12:00 AM
