Unbelievable but true, the weather this afternoon was good enough for a test flight...
And it works like a charm! With the original motor it took me about 2 minutes to get to reasonable altitude, with the new motor about a minute. Next time i'll increase the endpoint on my transmitter a bit, but so far i'm pretty pleased with it all... Check out the video i shot today:
Huesca, Spain
Joined Aug 2009
My Uhu finally converted to brushless
As the heading says, I finally got round to installing the brushless inrunner I had on hand.
The AUW of the model has gone up by about 30g thanks largely to the ESC. However, if the model now has the extra power that I expect it to have, the extra weight will be countered by having a stronger, shorter climb rate up to altitude. I used the case of the original brushed motor and mounted the inrunner inside using balsa longerons/spacers glued between the two. This way, the motor thrust line remains the same and, I can remove the motor in future if necessary. Finally, mounted the original prop/spinner. I did a quick run-up in the house and it's much smoother and quieter than before. Aesthetically, the model looks no different. Typically, the weather has taken a turn for the worse and the forecast for the next week is not good. But, as soon as I can do a test flight I will report back. In the meantime, I guess I'll just have to start putting together my new Mpx Solius. Steve. |
That sounds like a nice way to hide your little inrunner...
I know what you mean about the weather... Over here its not the wind at the moment, but its the cold... After about 15 minutes my hands start turning blue and numb... I did have a few flights with my Uhu this week though (did put a small vid on youtube again...) I hope the weather clears up soon so you can do your test flight, would love to hear how it went ![]() Have fun putting your Solius together. gr, Sjaak |
| Thread Tools | |
| Video New Elektro-UHU from Graupner | Jurgen Heilig | Electric Plane Talk | 1 | Jan 09, 2007 08:43 PM |
| Graupner Elektro-UHU | cornj | Aircraft - Sailplanes (FS/W) | 0 | Jan 02, 2005 02:02 PM |
| FS/FT Graupner Elektro-UHU in box | stevesuarez | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 09, 2002 10:49 PM |
| WTB - Graupner Elektro-UHU | velvis | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 29, 2002 09:28 PM |
| Article Recommendations From an Experienced Elektro-UHU Pilot | skranish | Electric Plane Talk | 0 | May 01, 1996 12:00 AM |
