Old Apr 06, 2007, 11:18 AM
GeeW is online now
Find More Posts by GeeW
SB-28 UK Display Pilot
GeeW's Avatar
ENGLAND
Joined Jul 2001
Crashard
Glad you had a good day. I've increased my rudder throw by about 30% over stock, which I feel helps. Having said that if full rudder doesn't turn it you are probably flying a bit to slow.
Have fun.
Regards
Gordon
GeeW is online now Find More Posts by GeeW
Old Apr 10, 2007, 02:18 AM
cornel4web is offline
Find More Posts by cornel4web
cornel4web's Avatar
Romania
kit contains...
did the kit contain the motor and spiner as the EZ* did ???
cornel4web is offline Find More Posts by cornel4web
Old Apr 10, 2007, 02:25 AM
MarkJayne is offline
Find More Posts by MarkJayne
Part-Time Super Hero
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
No, there's no motor or spinner included in the UHU kit.
Mark
MarkJayne is offline Find More Posts by MarkJayne
Old Apr 10, 2007, 03:24 AM
cornel4web's Avatar
Romania
so mark...what setup do you recomand for this?...I'm from Romania and here is a lack of hobby shops. I can order some from http://shop.lindinger.at/ ... or if you have time to take a look at www.sierra.ro
10x for your time...
Old May 16, 2007, 03:00 PM
balloonpilot is offline
Find More Posts by balloonpilot
Joined May 2007
New To This - UHU
I just got my UHU and have a few questions before I start putting things together...
1) Does the ESC have a low-voltage cut-off? I heard the EasyStar will cut power when the voltage drops but will allow for the throttle to be reapplied. I plan on using Lipo batteries so Im concerned about draining them too much.
2) I purchased the 'stock' or recommended motor - Included in the case were three capacitors and one diode BUT I can not find any instructions as to what I am to do with them... Any ideas?
3) The 'live' hinges seem very weak - Has anyone tried notching and putting regular hinges in?
4) I've read somewhere about putting clear, plastic packing tape on the undercarriage - Would it help to also put this stuff on the leading edge of the wing and tail section?
balloonpilot is offline Find More Posts by balloonpilot
Old May 16, 2007, 04:38 PM
GeeW is online now
GeeW's Avatar
ENGLAND
Joined Jul 2001
Balloonpilot
The capacitors need to go on the motor....some motors already have 2 preinstalled so its best to check. If you look at the terminals on the back of the motor if there is a little wire soldered there it probably has these and you then only need to solder one capacitor across the two terminals. If no little wires then solder a cpacitor from one terminal to the case, and another capacitor from the other terminal to case as well.
The live hinges as the model comes out of the box work and last very well. I would not recommend trying any other types.
Plastic tape on the forward part of the belly will do no harm iif you fly from gravel or tarmac, if you fly from grass then I wouldn't bother.
Similarly if you aply it to the leading edges it will help resist hangar rash.....I didn't bother and mine still looks pretty good.
Hope this helps
Regards
Gordon
Old May 17, 2007, 04:49 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
The recommended E-UHU drive is the SPEED 400 PLUS 7.4V (motor plus ESC) and it comes ready to use.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 17, 2007, 08:47 AM
Joined May 2007
Jürgen -
The motor I have is the 400 Speed Plus with the ESC mounted on the back. Inlcuded in the box this motor came in was also these 3 capacitors and 1 diode - So Im confused if I need to use these components or not... Where does the diod go?
Hinges - My local hobby store has recommended not installing any 'normal' hinges, but to use hinge tape --- IS this a good idea?
Old May 17, 2007, 10:37 AM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
The UHU hinges are pretty good, but not as good as the Easystar's, so a little hinge tape won't do any harm, just make sure you move them up and down a few times by hand to make sure they move freely.
Mark
Old May 17, 2007, 11:55 AM
Joined Sep 2000
Jürgen -
Strange. Mine did not come with additional capacitors/diodes and you should not need them anyway.
Jürgen
Old May 17, 2007, 03:17 PM
MarkJayne's Avatar
Aberystwyth, UK
Joined Sep 2004
Will the stock 400 speed motor and ESC take a 3s. I can't seem to get anywhere on the Graupner site to find out. Just curious.
Mark
Old May 17, 2007, 04:08 PM
Joined May 2007
"Will the stock 400 speed motor and ESC take a 3s. I can't seem to get anywhere on the Graupner site to find out. Just curious."
According to the info at Hobby Lobby - it is said to be able to handle 3s. The folks at HL advised to 'not' go full-throttle but did not seem to think it would be a problem either way.
I did some searches and most places ref. the 6505 (the Speed 400 plus) as a 7.4 v (2s) system. However, the link at HL:
http://www.hobby-lobby.com/speedplus.htm
Shows it can go up to the 11v of a 3s
Old May 18, 2007, 12:27 AM
Joined Sep 2000
"Will the stock 400 speed motor and ESC take a 3s. I can't seem to get anywhere on the Graupner site to find out. Just curious."...
The motor can take up to 3s, but only up to 10A max. You would exceed this limit with the original folding prop (which also might not be suitable for twice the power) and would need to put a smaller prop on.
Jürgen
Old May 19, 2007, 05:45 AM
Joined May 2007
To Brake or Not to Brake
Reading the ESC setup on the E-UHU, I have a question about the brake option of the ESC. It is my understanding that the brake stops the prop and allows it to fold back with airspeed.
I'm assuming that the 'brake' does some sort of reverse-current operation to hold the prop from its natural tendancy to spin - So my concern is how much current does the brake utilize?
Old May 19, 2007, 12:46 PM
GeeW is online now
GeeW's Avatar
ENGLAND
Joined Jul 2001
Balloonpilot
Most ESC with brake apply the brake for only a couple of seconds when you fully close the throttle, so current draw is negligable. Some brakes are only an effective shorting of the motor wires (which acts as a brake until there is no more rotation, then has no effect).
Without the brake set the prop may never slow enough to fold. If you have the recommended motor/ESC set then set brake to on.
Regards
Gordon
Video New Elektro-UHU from Graupner Jurgen Heilig Electric Plane Talk 1 Jan 09, 2007 08:43 PM
Graupner Elektro-UHU cornj Aircraft - Sailplanes (FS/W) 0 Jan 02, 2005 02:02 PM
FS/FT Graupner Elektro-UHU in box stevesuarez Aircraft - Electric - Airplanes (FS/W) 2 Nov 09, 2002 10:49 PM
WTB - Graupner Elektro-UHU velvis Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2002 09:28 PM
Article Recommendations From an Experienced Elektro-UHU Pilot skranish Electric Plane Talk 0 May 01, 1996 12:00 AM
